Katy, TX
Joined Dec 2009
I have friends who refuse to use sport props, they think sport props are to heavy for electric powered planes.
Anyhow new DF ordered will try to get it built ASAP FCA As for the gear remark, some think a simple prop change is gonna take them from 70 to 150mph, Or going from a 20C pack to a 30C will do the same. Lol I need one of those props |
Can't qiute get my head around a sport prop being too heavy for an eleccy plane.
Ok, maybe on certain planes I can... e.g. microjet, but I'd have though that the prop wouldn't be suitable for smaller motors, with small dia shafts and iddy diddy bearings, not eleccy planes generally. After all, there's some pretty big eleccy planes available. |
Speedblind
Hi.
Thanks for your suggestions I got several flights on 3s and 4s monday and was a bit disapointed in the speed, - or lack thereoff so to speak. I had my experience from my maiden on 4s yesterday fresh in mind and somehow mentaly expected higher topspeed. - The mind sometimes play tricks on you The fluttering and vibration is still present on my plane after I have fibered it up, - glued wing to the fuselage ect, - tightened the motormount adjustment screws. (didnt permafix it but strengthened the plastics and fibered the EPP on the outside) But now the vibration / fluttering is also present at 3s (perhaps after i have messed with the adjustment screws on the motormount) My 8*8 prop is accurately ballanced and I am leaning towards that the plastic sidemounts that the aluminum motormount mounts to simply is'nt up to the task !! Futhermore the fluttering only happens in flight, - not in stactic where there only is a small vibration from 3/4 throttle and up. Its sounds as if something goes in to violent resonance in flight. One of my fellow clubmembers think that my problem could be that it is the controlsurfaces that resonates at high speed?, -they are alle stock with MPX nano servos (RR version) with the thin metalrod connecting to my heavyly reinforced controlhorns.. - Could this be a posibility, - in my view it should then behave erratically and probably damage the servos almost instantlty? Running Hyperion HS3026-1600 with 40C 3s and 4s 2200 lipos Cheers C |
Try beefing your control rods up if you're using the stock ones. I wouldn't/didn't use them myself, and with HS65's I don't get any flutter. Wing/fuse isn't glued on mine either.
Tend to agree about the plastic motor mount sides, not the best way of doing it IMO, I stripped one side accidently and have had to get some different screws to hold the metal mount in place. |
....http://www.smallpartscnc.com/
Thanks Mal |
Auckland - New Zealand
Joined Dec 2010
There is nothing wrong with the included alloy motor mount If you have any play in your servo linkages you will get flutter at high speed I used ball links all round,and 11g digital 2.5kg servos My current setup is drawing big amps I puffed up a couple of 4s nanos 2650mah 35-70c this weekend I'm now waiting for some 2700 90-130c Still my favorite plane
Joined Oct 2007
Dogging
I'm no engineer but I doubt this plane was designed for 150 mph speeds all the time...things are just going to loosen up and fail....unless altered. The stock plastic fuse side mounts seem adequate for these speeds. My new in the box doggie will have upgraded hardware rods and connectors, extra carbon rods, additional taped hinges, strong servos, and a powerful motor yet to be determined. I guess I'd like to have one of the hyper or scorp 3026 class motors..any other mills similar to those to consider? What about a Cobra motor? Anyone ever try a Cobra..on anything... |
Joined Mar 2012
good replacement motor
i would appreciate if someone can help me with this.
i purchased a dogfighter with the multiplex Hi-pref power pack from towerhobbies a while ago. last time i flew it was a strong wind day and had a bad luck during the hand launch. The plane went down and hit the nose and the motor got burnt. but the ESC is still good I believe. I want to buy the replacement motor from towerhobbies because they give me discount but I cant find the Himax motor sold separately without the kit. I just need the motor. Does tower sell that motor separately on their site? if not what is a good equivelant motor to get from that site (and works perfectly with the stock ESC)? Thank you for your help |
Katy, TX
Joined Dec 2009
Well finally ordered another DF, I was planning on installing a MEGA 600/30/4 Outrunner, but decided to go with a custom order instead, so hopefully in the coming weeks I will have a new Mega 600/30/3 this one will have a higher Kv, 100,000 RPM bearing, extended shafts on both ends, the WORKS
![]() I've added a few pics of the MEGA 600/30/4 next to my old P25 for comparison, the P25 1250Kv with 8x8 sport on 5S was a good setup, I pushed it close to the max burst rating of 58A. Hopefully this new MEGA outrunner with a higher Kv will allow me to go past 80Amps, we will see ![]() Have Fun, FCA |
| Thread Tools | |
| Question Kyosho Phantom Reno Racer Motor Selection | Cincy E-Flyer | High Performance | 6 | Aug 12, 2011 03:35 PM |
| Discussion Multiplex news 2011: Reno-style DOGFIGHTER etc | mopetista | Foamies (Kits) | 0 | Feb 01, 2011 06:09 AM |
| Sold Cox Corsair II Reno Racer CL RTF | skylane42 | Aircraft - Fuel - Airplanes (FS/W) | 0 | Dec 11, 2010 10:45 AM |
| For Sale Hacker Reno Racer-Cosmic Wind | Doug Hinkel | Aircraft - Electric - Airplanes (FS/W) | 1 | Sep 02, 2010 01:02 PM |
