Old Jun 13, 2011, 04:53 PM
JussiH is offline
Find More Posts by JussiH
Friend is a 4 letter word...
JussiH's Avatar
3rd stone from the sun
Joined May 2007
I reread the release notes, made the changes for HMC5843 and Xquad and I got the Mission planner 1.0.0 running now in AC2 mode. The artificial horizon is working and I can see the PIDīs
When I enter setup in the CLI, it tells me compass is disabled when I try to calibrate it. I also get bogus values for GPS and Rawgps under "Test"
I am using the FMP04 module on one of Paul Bakes BOBīs. I have this in Apm_config.h:
Code:
#define GPS_PROTOCOL GPS_PROTOCOL_AUTO
#define MAG_ORIENTATION		ROTATION_YAW_270
This is what the release notes state:
*** Do not forget to select your GPS type in the APMconfig.h Options are GPS_NMEA, GPS_MTK, GPS_UBLOX
Here is the output from the GPS and RAWGPS test:
Code:
Test Mode
test] gps
Hit Enter to exit.
G*?G*?G*?G*?.G*?G*?G*?G*?.
G*?G*?G*?G*?.test]
test] Rawgps
Hit Enter to exit.
Error reading com port
??n??'????????? 8?R??D @WP?C?????
?r??w?H????@ ??????% 8
?kUP?C?%3?P??#??????#??
test]
test]
Slightly confused still, but making progress.... What am I overlooking/misunderstanding
JussiH is offline Find More Posts by JussiH
Old Jun 13, 2011, 04:59 PM
kinderkram is offline
Find More Posts by kinderkram
OS Sponsor
kinderkram's Avatar
Germany, NRW, Dusseldorf
Joined Jun 2010
Originally Posted by JussiH View Post
Code:
In CLI type "setup" -> "compass on" then "compass offsets" and do your voodoo dance until the values in the right rows don't move any longer.
I'm also struggeling with the GPS unit atm.
Someone else got it running ... some pages ago ...
kinderkram is offline Find More Posts by kinderkram
Old Jun 13, 2011, 05:11 PM
helicoblast is offline
Find More Posts by helicoblast
Geneva, Switzerland
Joined Jan 2009
Help needed please
Hi guys,
I'm needing your help!
I'm still unable to use the mission planner, and I'm quite bored with this situation!!
I'm using Flyduino and FFIMU.
I'm able to upload the code with Arduino, but then:
- I can't connect the boards to the planner. I'm sure that the Baud rate is the right one and the COM port, too.
- I can connect the boards with the terminal (into planner or into Arduino), but I need to disconnect and reconnect the FTDI to enter in the setup menu.
- When I look at the compass, it seems that there are no datas transmitted to the planner.
Could someone here help me to sort this out?
Any help would be really appreciated!
@Norbert, and everybody interested by: What do you think about the wiki, would we create a new section in the actual ArduPirates wiki, or create a new google code project, and start a new wiki there?
helicoblast is offline Find More Posts by helicoblast
Old Jun 13, 2011, 06:20 PM
OS Sponsor
kinderkram's Avatar
Joined Jun 2010
Originally Posted by helicoblast View Post
Hi guys,
Ok, seen that already.
Sometimes I need to disconnect and/or restart the APMP to get the COM port running. Had similar probs with the old one.
But you could try the version that comes with Olegs B8+
Second picture: did you calibrate the mag? "compass offsets" in CLI
Oh and your last question: I prefer a new section in the ArduPirates Wiki.
Old Jun 13, 2011, 06:33 PM
JussiH is offline
JussiH's Avatar
Joined May 2007
Norbert, thanks...Mag responding now!
I will also try a DIYD MT3329 GPS module... but those FMP04 modules caused quite a commotion in the crowd, so it would be nice to see one actually work on a copter soon... If anyone had success with those modules, pls share the magic....
@ Joebarteam: Which exact DIY Drones GPS module did U use...?
Edit: I have the MT3329 DIYD module sitting on my table right now reading my home position
Thanks, Guess I will be testflying tomorrow!
Old Jun 14, 2011, 01:18 AM
joebarteam is online now
Find More Posts by joebarteam
J'ai remis la purée
Netherlands, ZH, Zoetermeer
Joined Mar 2011
Hi Jussie,
The Mediatek mt3329 10hz.
I've seen this before...
G*?G*?G*?G*?.test]
test] Rawgps
Hit Enter to exit.
??n??'????????? 8?R
Baudrate settings and / or swapping GPS-TX/RX connector did do the trick for me.
Menno
joebarteam is online now Find More Posts by joebarteam
Old Jun 14, 2011, 02:13 AM
Geneva, Switzerland
Joined Jan 2009
Thanks Norbert,
My problem is that I need to disconnect the APMP every time to get the COM port running, and it works only in the terminal mode, I can't get the COM port running in other modes, so I can't change PID's, for example.
It's the same situation with Oleg's B3 and B8+.
I tried to calibrate the mag offsets, but it only return those 0.000; 0.000; 0.000...
would that say that I've a problem with the FFIMU?
Old Jun 14, 2011, 07:35 AM
Gaza07 is offline
Find More Posts by Gaza07
Gaza07's Avatar
United Kingdom, England, Nottingham
Joined Nov 2002
Is there anyone with the Flyduino and Allinone combo using mega pirate B8, Iam still having problems and it is not to do with expo, when I tilt the quad in the APM forwards and right this is what the APM shows and it looks to me that the pitch is right but the roll is the wrong way, Iam just about ready to give up on this and just leave multiwiidev installed as it flys perfect with it but no GPS yet
Gaza07 is offline Find More Posts by Gaza07
Old Jun 14, 2011, 07:53 AM
Syberian is offline
Find More Posts by Syberian
Oleg
Syberian's Avatar
Joined Dec 2008
Gaza07
I got something for you.
This is an archive with Arduino libraries am using with Allinone.
TO ALL the pirates
I just finished an initial build of the pirated ArduPilot Mega for planes. The same flyduino, the same pins, sensors, and mode switch.... the PLANE functionality (fly by wire, waypoints, xbee etc).
How`d we call him?
MegaPirate Pilot?
Syberian is offline Find More Posts by Syberian
Old Jun 14, 2011, 08:51 AM
OS Sponsor
kinderkram's Avatar
Joined Jun 2010
Originally Posted by Syberian View Post
Gaza07
TO ALL the pirates
How`d we call him?
MegaPirate Pilot?
Hmmmm ... what about MegaPirate Plane? Simple, eh?
Old Jun 14, 2011, 09:01 AM
Syberian is offline
Oleg
Syberian's Avatar
Joined Dec 2008
MPP sounds definitely good! Thanks!
Old Jun 14, 2011, 10:20 AM
capt is offline
Find More Posts by capt
capt's Avatar
Nevada, USA
Joined Sep 2007
That is a correct display for pitch down and right roll, the little symbol is your copter, horizon in background.
Not my vid clip but for demonstration.
FlightGear driving an EFIS display. (1 min 11 sec)
capt is offline Find More Posts by capt
Old Jun 14, 2011, 10:45 AM
OS Sponsor
kinderkram's Avatar
Joined Jun 2010
Before you ask again: I made some more tests with my Hexa and the MP B8+ with baro settings.
Best results so far I get with these Baro Throttle PID settings:
P = 0.1
I = 0.01
D = 0.03
INT_MAX 50.0
When I activate the alt_hold for the first time the Hexa goes down about 1m.
I deactivate it then and hover it for some seconds before I activate it again.
Et voilá: it stays in a pretty small height window of about 50cm - 1m depending on the moves I make.
Hope it helps.
Old Jun 14, 2011, 10:55 AM
Syberian is offline
Oleg
Syberian's Avatar
Joined Dec 2008
HUGE thanks to you Norbert!
Im glad we pulled this info from you at last
I`m still waiting for b24 acm update with sonar transition fixed. Neither b23 nor repo doesnt contained that fix yet.
Old Jun 14, 2011, 11:07 AM
OS Sponsor
kinderkram's Avatar
Joined Jun 2010
Yep!
It's best to wait a little longer. Didn't dare to fly the 2.0.24 on my big ArduHexa after reading the probs others have with the new code.
That's why Jason states the 2.0.24 is !ALPHA!
Maybe next weekend...
Discussion JR Indoor Photo Coverage - Higher Plane Productions JR Indoor Jim T. Graham JR Indoor Electric Festival 21 Dec 06, 2010 07:51 AM
Discussion We proudly present: brandnew Lubach F16 f. 90mm fan ost Electric Ducted Fan Jet Talk 17 Oct 03, 2010 11:46 AM
Poll nevermind pirates vs. ninjas Karl Bē Life, The Universe, and Politics 3 Sep 05, 2010 10:59 PM
Hobbico - Futaba Apparel and Accessories - Wear your Futaba orange proudly! Dave Lauck Product Announcements 0 Apr 18, 2005 05:13 PM
