Old Feb 21, 2011, 04:36 PM
kinderkram is offline
Find More Posts by kinderkram
OS Sponsor
kinderkram's Avatar
Germany, NRW, Dusseldorf
Joined Jun 2010
Production Run of Paul's Flyduino Mega
Paul just started a list for pre-orders on his Flyduino Mega:
http://www.rcgroups.com/forums/showthread.php?t=1381577
His 5x5cm Flight Controller comes at 55$ (+ decent shipping fees) based on a ATMega 1280 with all bells & whistles pinned out!
kinderkram is offline Find More Posts by kinderkram
Old Feb 21, 2011, 04:47 PM
bob4432 is offline
Find More Posts by bob4432
bob4432's Avatar
United States, AZ, Phoenix
Joined May 2010
is this going to be used instead of the seeedstudio mega that is similiar in dimensions to the Duemilanove/Uno?
bob4432 is offline Find More Posts by bob4432
Old Feb 21, 2011, 05:35 PM
Goofy23 is offline
Find More Posts by Goofy23
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
Yes this is thought as a Seeeduino replacement its smaller and you can connect everything directly to it.
It have these common 4.5x4.5cm holes.
It have no sensors on board like the seeeduino. You will need a FTDI for it cause for weight and size reasons its not on board.
First the Beta Test has to be completed, but the production run seems to be near.
Goofy23 is offline Find More Posts by Goofy23
Old Feb 21, 2011, 06:02 PM
JussiH is offline
Find More Posts by JussiH
Friend is a 4 letter word...
JussiH's Avatar
3rd stone from the sun
Joined May 2007
The Seeed Mega will still be an option
And the new shield will be available inside the next 2 weeks...
JussiH is offline Find More Posts by JussiH
Old Feb 21, 2011, 06:29 PM
bob4432 is offline
bob4432's Avatar
Joined May 2010
so then the same method as programming the pro mini can be used? its all good - the speed at which these things are coming out and the quality is very impressive. keep up the excellent work
just to verify this unit will work to program - http://www.sparkfun.com/products/9716
Old Feb 21, 2011, 08:40 PM
Goofy23 is offline
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
Yes i use a FTDI Basic 5V too for the flyduino
Old Feb 22, 2011, 05:29 AM
titeuf007 is offline
Find More Posts by titeuf007
Joined Jun 2006
this board is very beautiful i like it
it will be perfect if you open a website with a complete kit(you board+freeflight imu)
what is the difference between seeeduino mega and your beautiful board??
if i understant we don t have need to soldering something for use it??
titeuf007 is offline Find More Posts by titeuf007
Old Feb 22, 2011, 08:12 AM
Goofy23 is offline
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
My Board as the Seeeduino Mega are basicaly ATMEGA1280 arduino boards, without Sensors.
Both will work.
The Flyduino is smaller and you can plug everything you need directly.
The holes have 4.5x4.5cm which is a common standard in the Multirotor scene.
You will need a FTDI for the Flyduino, the Seeeduino have USB on board.
For the Seeeduino its better to get a shield to make the connector adaptions, this is not needed for the Flyduino.
I will offer a Flyduino Kit, which means a preassembled PCB with all hard to solder SMD mounted, you only need to solder, the in the Flyduino Kit, supplied Pinheaders on your own.
The Flyduino is designed to work together with Jussis FF_IMU (but of course you can choose any other sensor combination).
Give us some time to offer more complete kits, this is not worked out now.
Old Feb 22, 2011, 10:07 AM
Geni is offline
Find More Posts by Geni
Schweiz
Joined Apr 2008
Hi Paul,
works of these mini-USB adapter with the Flyduino?
Thanks Geni
Geni is offline Find More Posts by Geni
Old Feb 22, 2011, 02:25 PM
Goofy23 is offline
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
Every ftdi adaptor works, this one is also FT232 based like most of them.
It should be fine, in worst case sceanrio you have to shorten the reset pins before uploading.
But i think this one have the auto reset function as well.
Old Feb 22, 2011, 06:07 PM
rimshotcopter is offline
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
Will one of these work also?
http://cgi.ebay.com/USB-To-TTL-COM-C...62896231618131
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWAX:IT
rimshotcopter is offline Find More Posts by rimshotcopter
Old Feb 22, 2011, 07:24 PM
Goofy23 is offline
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
@ reverendrichie
i am not sure about those
will have to investigate further
But those FTDI Chips are very common.
Lots of mobile phone data cables use them.
You can easily adapt an old data cable from your old phone (or any cheap ebay offer)
if the right chip is in it.
I think then you will need the manual reset function, but it should be possible to add that on the datacable too.
Maybe those you choose are working, dont know exactly, but i think the autoreset will not work.
Old Feb 22, 2011, 08:08 PM
Joined Aug 2009
Thank you, I was just curious and exploring other options.
Old Feb 23, 2011, 04:48 AM
OS Sponsor
kinderkram's Avatar
Joined Jun 2010
Thanks for all your explorations, Reverend!
A 5$ alternative for the Sparkfun 15$ FTDI/USB isn't too bad.
Go on fishing for pearls - if I remember correctly you were the one who found the ELV BMA020, right?
Old Feb 23, 2011, 05:18 AM
Joined Aug 2009
No, it was not me that discovered the BMA020.
Discussion JR Indoor Photo Coverage - Higher Plane Productions JR Indoor Jim T. Graham JR Indoor Electric Festival 21 Dec 06, 2010 07:51 AM
Discussion We proudly present: brandnew Lubach F16 f. 90mm fan ost Electric Ducted Fan Jet Talk 17 Oct 03, 2010 11:46 AM
Poll nevermind pirates vs. ninjas Karl Bē Life, The Universe, and Politics 3 Sep 05, 2010 10:59 PM
Hobbico - Futaba Apparel and Accessories - Wear your Futaba orange proudly! Dave Lauck Product Announcements 0 Apr 18, 2005 05:13 PM
