Old Mar 15, 2013, 01:21 PM
Adilson is offline
Find More Posts by Adilson
Discovering the joys of flying
Adilson's Avatar
Brazil, SP, São Paulo
Joined Aug 2012
Originally Posted by subaru4wd View Post
Is anybody using a MinimOSD with their MPNG install?
I am curious if the instructions are the same with ArduCopter or if any changes need to be made to the sketch??
Thanks guys
I did not fly with it but I did test on my workbench and worked fine.
Adilson is offline Find More Posts by Adilson
Old Mar 15, 2013, 01:33 PM
lakis21 is offline
Find More Posts by lakis21
lakis21's Avatar
Greece, Makedonia Thraki, Nikiti
Joined Dec 2006
Hello I am using MegaPirateNG 2.9 R6 on an Crius AIO 1.1. And I enabled Copter Leds (LED_MODE through MP) for arming and GPS and they are working great!!
Does anybody knows if the MegaPirateNG 2.9 R6 support piezo buzzer and how on CRIUS AIO ?
Thanks in advance!
lakis21 is offline Find More Posts by lakis21
Old Mar 15, 2013, 01:47 PM
fireslayer26 is offline
Find More Posts by fireslayer26
My Karma ran over my Dogma
fireslayer26's Avatar
United States, FL, Jacksonville
Joined Feb 2010
Originally Posted by Paku View Post
google >> motor mapping ...
Ok, I think I got it.
fireslayer26 is offline Find More Posts by fireslayer26
Old Mar 15, 2013, 01:53 PM
Sir Alex is offline
Find More Posts by Sir Alex
Aleksey Kharlanov
Беларусь, Минская область, Минск
Joined Sep 2011
Show us how you connected motors and propellers rotation direction.
Sir Alex is offline Find More Posts by Sir Alex
Old Mar 16, 2013, 04:41 PM
Paku is offline
Find More Posts by Paku
Poland, Mazowieckie, Warsaw
Joined Jan 2009
Hi,
This time we need some testers !!!
At the moment I am looking for people able to test AIO v1 + PPM Rx.
It does not have to mounted on the bird. Just board, connected PPM Rx and Mission Planner on the USB.
The most interesting would be FrSky 27ms flashed Rx but any PPM configuration is ok. If someone has 4ch,10ch or 12ch(!!!) Rx it would be great as well
You need 10-15 minutes to be done with tests.
pls PM me if you can help ....
No tests - no good code .... do not cry later
Paku is offline Find More Posts by Paku
Old Mar 16, 2013, 09:40 PM
Joined Feb 2010
I used the HEXA + setup show here: https://code.google.com/p/megapirateng/wiki/confighw
She's up and flying, but when I use Altitude hold or Loiter she bounces up and down. I'm guessing this has to do with the barometer. The whole board is enclosed, but I will try covering the baro as well.
FYI- Here is a great flight mode setup video. He is using the Crius AIOP and a Turnigy 9X.
CRIUS AIOP V1.1 Project Part 15 - Flight Modes (31 min 50 sec)
Old Mar 19, 2013, 08:38 PM
Joined Feb 2010
So I adjusted the PID's and she is alot better. But one weird thing that happened... I had it in Loiter mode and it was fine, but when I switched to RTH it turned back towards me but then came straight at me like a bullet and went to the ground. Any thoughts?
Old Mar 21, 2013, 04:45 PM
jy0933 is offline
Find More Posts by jy0933
James not bond
jy0933's Avatar
Joined May 2012
datalogging
I found that the data logging isnt really giving any data....(or say missing a few colums even they are set)... something is missing i guess?
jy0933 is offline Find More Posts by jy0933
Old Mar 22, 2013, 01:35 PM
NoRcExperience is offline
Find More Posts by NoRcExperience
Joined Jan 2013
Anyone tried r299 yet?
NoRcExperience is offline Find More Posts by NoRcExperience
Old Mar 27, 2013, 12:31 PM
lucianozan is offline
Find More Posts by lucianozan
lucianozan's Avatar
Italy
Joined Feb 2009
Region Of Interest - ROI
I'm using MegaPirateNG 2.9 R6 and up to now everything seems OK but one event in mission planning is not working as before (2.8): event ROI is not working anymore.
If you set a ROI after the event copter just rotate yaw to face ROI for one second but then it continue flying with yaw at next waypoint. It's too bad as ROI was a good function.
It seems to be an Arducopter bug and in DIYdrones forum Randy is suggesting to set YAW_OVR_BEHAVE=1
With YAW_OVR_BEHAVE=1 after ROI command yaw points correctly to ROI location ...but before ROI command yaw doesn't point anymore to next waypoint..
Have you got some experience in this area? Any suggestion?
Luciano
lucianozan is offline Find More Posts by lucianozan
Old Mar 28, 2013, 06:58 PM
Paku is offline
Joined Jan 2009
Hi,
I think it's more ArduCopter then mpNG related. If there is no solution on ArduCopter forum ... we have to wait for them to find it
I would not change anything what is not poorly board hardware related ...
Old Mar 31, 2013, 03:49 PM
DanielCV is offline
Find More Posts by DanielCV
Joined Feb 2010
Hello,
I have a problem with my receiver and failsafe not working which seems to be exactly this issue which has been solved some months ago:
http://code.google.com/p/arducopter/.../detail?id=471
So my question: is it possible to implement this in the next version of MPNG ?
Or will this only be done in the 2.9 arducopter port ?
Best regards,
Daniel
DanielCV is offline Find More Posts by DanielCV
Old Mar 31, 2013, 04:50 PM
etheli is offline
Find More Posts by etheli
ETFD2 Creator
etheli's Avatar
Worcester, MA
Joined Feb 2007
Originally Posted by DanielCV View Post
Hello,
Best regards,
Daniel
Looks like this is already implemented in the MPNG beta in SVN. See line 17 of "control_modes.pde" here. So it will be in the next release of MPNG. In the meantime, you could do the same modification to your local copy of "control_modes.pde".
--ET
etheli is offline Find More Posts by etheli
Old Mar 31, 2013, 08:08 PM
DanielCV is offline
Joined Feb 2010
Hello, thanks for your help.
Could it be possible just to replace the entire control_modes.pde file from your link given, for version 2.7R4 or for version 2.8R3 ?
Old Apr 01, 2013, 03:16 AM
etheli is offline
ETFD2 Creator
etheli's Avatar
Worcester, MA
Joined Feb 2007
There are too many other changes in the new version of the file. If you modify the 'read_control_switch()' function in the MPNG 2.8R3 version of "control_modes.pde" to make it look like this I believe it will do what you want:
Code:
static void read_control_switch()
    static bool switch_debouncer = false;
    byte switchPosition = readSwitch();
    if (oldSwitchPosition != switchPosition) {
        if(switch_debouncer) {
            oldSwitchPosition       = switchPosition;
            // ignore flight mode changes if in failsafe
            if( !failsafe ) {
                set_mode(flight_modes[switchPosition]);
                if(g.ch7_option != CH7_SIMPLE_MODE) {
                    // set Simple mode using stored paramters from Mission planner
                    // rather than by the control switch
                    do_simple = (g.simple_modes & (1 << switchPosition));
        }else{
            switch_debouncer        = true;
--ET
Discussion JR Indoor Photo Coverage - Higher Plane Productions JR Indoor Jim T. Graham JR Indoor Electric Festival 21 Dec 06, 2010 07:51 AM
Discussion We proudly present: brandnew Lubach F16 f. 90mm fan ost Electric Ducted Fan Jet Talk 17 Oct 03, 2010 11:46 AM
Poll nevermind pirates vs. ninjas Karl B² Life, The Universe, and Politics 3 Sep 05, 2010 10:59 PM
Hobbico - Futaba Apparel and Accessories - Wear your Futaba orange proudly! Dave Lauck Product Announcements 0 Apr 18, 2005 05:13 PM
