Old Jan 21, 2013, 09:28 AM
Sir Alex is offline
Find More Posts by Sir Alex
Aleksey Kharlanov
Беларусь, Минская область, Минск
Joined Sep 2011
Originally Posted by trunet View Post
Why you didn't port AP_HAL library?
Because it in developing state. I will start when at least Release Candidate will be available.
Sir Alex is offline Find More Posts by Sir Alex
Old Jan 21, 2013, 10:01 AM
trunet is offline
Find More Posts by trunet
Brazil, São Paulo, Sao Paulo
Joined Nov 2011
2.9.0 were released already and AP_HAL is final now. As diydrones migrated to github, what do you think in do it as well and fork their repository to make it easier to merge between versions?
trunet is offline Find More Posts by trunet
Old Jan 21, 2013, 10:13 AM
Sir Alex is offline
Aleksey Kharlanov
Joined Sep 2011
2.9 does not have HAL. It will be at 3.0
Old Jan 21, 2013, 10:24 AM
trunet is offline
Joined Nov 2011
My bad, I was seeing master branch instead ArduCopter-2.9.
Old Jan 21, 2013, 11:16 AM
AcroFPV is online now
Find More Posts by AcroFPV
we dont NEED roads!
AcroFPV's Avatar
United States, CA, Rocklin
Joined Aug 2012
Is there anybody who has both a MPNG and a AC flight controller and is using both firmwares to compare? I am thinking of getting rid of my MultiWii Pro 2.0 board, and buying a ArduFlyer so I can use the un-ported ArduCopter. I never liked how MegaPirate flew.
I am curious if there are any performance differences between the MegaPirate firmware on a Mega board... and the official AC on a ArduFlyer that would make the switch worth it.
I have been flying with MultiWii for the past couple weeks and I want to go back to using Mission Planner, i Just do not want to go back to how MegaPirate flew.
Patiently waiting for 2.9 (or 3.0.... or whatever you guys are working on)
AcroFPV is online now Find More Posts by AcroFPV
Old Jan 21, 2013, 11:24 AM
trunet is offline
Joined Nov 2011
Well, megapirateng only has support for some more boards/sensors. I think the greatest difference is the MPU6050 acc+gyro support that is I2C and does not support SPI.
The base code is the same, so, it has to fly almost equal. I have both and I can say that both flies well when you tune your PIDs correctly.
Old Jan 21, 2013, 11:36 AM
jy0933 is offline
Find More Posts by jy0933
James not bond
jy0933's Avatar
Joined May 2012
is there a big differences between aiop v1 and v2? it seems to me arduplane branch was not updated since Dec...... I wonder if i can use v1 board config on v2 board
jy0933 is offline Find More Posts by jy0933
Old Jan 21, 2013, 12:11 PM
kinderkram is offline
Find More Posts by kinderkram
OS Sponsor
kinderkram's Avatar
Germany, NRW, Dusseldorf
Joined Jun 2010
MPNG 2.9 R2 based on ArduCopter 2.9-rc5 is in the trunk:
http://code.google.com/p/megapirateng/source/checkout
Tested it yesterday and it flew amazingly well with stock settings. A huge difference against previous versions!
Looks like the ArduCopter team made it better this time. Keep in mind that the copy can't fly any better than the original. They also introduced a new methode to calibrate the ACC in the MegaPlanner. Maybe worth a last shot?
@ Sir Alex: Good job!
Only problem I had: as soon as I re-connected the lipo, the ESCs were beeping as if they didn't get enough juice. Can this also be related to the problem in the motors lib?
kinderkram is offline Find More Posts by kinderkram
Old Jan 21, 2013, 01:35 PM
we dont NEED roads!
AcroFPV's Avatar
Joined Aug 2012
Oh awesome. I did not know 2.9R2 was available. I might have to give that a try here soon
Old Jan 21, 2013, 03:01 PM
lucianozan is offline
Find More Posts by lucianozan
lucianozan's Avatar
Italy
Joined Feb 2009
Porting of ArduCopter 2.9-rc4 almost done. I'm looking for Beta testers!
The MPNG 2.9 R1 (available via SVN) ......
Sir Alex, first of all thank you for your effort in porting this great firmware!
I'm using 2.8R2 and it works great!
How is it going 2.9 beta test? I'd like to give it a try (with a "spendable" quad) but I'm not sure to be able to download from SVN all needed modules. I wonder if you are planning to release a 2.9 beta version in download area.
Thanks again!
Luciano
lucianozan is offline Find More Posts by lucianozan
Old Jan 21, 2013, 05:53 PM
Sir Alex is offline
Aleksey Kharlanov
Joined Sep 2011
I'm just updated SVN. MPNG 2.9 R3 available for testing.
I'm restored AP_Motors, so HEXA's and other configurations must work well.
There is also minor fixes in code.
Old Jan 21, 2013, 06:59 PM
Adilson is online now
Find More Posts by Adilson
Discovering the joys of flying
Adilson's Avatar
Brazil, SP, São Paulo
Joined Aug 2012
Damn, just uploaded 2.9 to my quad just before you commit the last changes. Well, back to svn
Anyways, thanks a lot Sir Alex
Adilson is online now Find More Posts by Adilson
Old Jan 22, 2013, 01:08 PM
jimbobsi is offline
Find More Posts by jimbobsi
Joined Nov 2012
Thank you, Motors are running now on my Octa Quad but I have some weired twitches in motor rpm while holding the copter on the ground without moving it. I have to make some more tests.
jimbobsi is offline Find More Posts by jimbobsi
Old Jan 22, 2013, 01:21 PM
Sir Alex is offline
Aleksey Kharlanov
Joined Sep 2011
Check the AHRS_GPS_GAIN parameter, it must be set to 0.
I'm recommend for all users to ERASE all settings before first use. (Go to CLI ->setup -> erase)
Old Jan 22, 2013, 01:45 PM
OS Sponsor
kinderkram's Avatar
Joined Jun 2010
I always erase the EEPROM before I flash new firmware.
btw: my problem with beeping motors still isn't solved with R3. As long as I don't unpower the board after flashing, all is good. As soon as I unplug/replug the lipo the ESCs beep as if they didn't get a throttle signal. Doesn't happen on 2.8 or with MWC.
What could it be?
Discussion JR Indoor Photo Coverage - Higher Plane Productions JR Indoor Jim T. Graham JR Indoor Electric Festival 21 Dec 06, 2010 07:51 AM
Discussion We proudly present: brandnew Lubach F16 f. 90mm fan ost Electric Ducted Fan Jet Talk 17 Oct 03, 2010 11:46 AM
Poll nevermind pirates vs. ninjas Karl B² Life, The Universe, and Politics 3 Sep 05, 2010 10:59 PM
Hobbico - Futaba Apparel and Accessories - Wear your Futaba orange proudly! Dave Lauck Product Announcements 0 Apr 18, 2005 05:13 PM
