Old Dec 26, 2012, 06:12 PM
TheFernMan is offline
Find More Posts by TheFernMan
Too Many Thread Subscriptions
TheFernMan's Avatar
United States, FL, Miami
Joined Jul 2012
Originally Posted by Adilson View Post
I'm having problems to compile latest MPNG to Black Vortex. With Arduino 0.23 I have th error /home/adilson/arduino-0023/libraries/AP_Baro/AP_Baro.cpp: In member function ‘float AP_Baro::get_altitude()’:
If I try 1.0 or anything above I have several complains about the serial library. Unfortunately, I can't paste the exact error now but the program stops at FastSerialPort2(Serial2); // GPS port
Any clues? The 2.7 R4 compiles cleanly.
Did you replace the library of Arduino with MPNG? Maybe download a new copy of both Arduino and MPNG.
TheFernMan is offline Find More Posts by TheFernMan
Old Dec 26, 2012, 06:35 PM
Adilson is offline
Find More Posts by Adilson
Discovering the joys of flying
Adilson's Avatar
Brazil, SP, São Paulo
Joined Aug 2012
Yes, new copies on both versions of Arduino.
Adilson is offline Find More Posts by Adilson
Old Dec 26, 2012, 06:38 PM
Adilson is offline
Adilson's Avatar
Joined Aug 2012
BTW, I just tried a new copy of everything, Arduino and Megapirate, didn't change anything, just hit compile and I got this errors:
/home/adilson/arduino-1.0.3/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/../../../avr/bin/ld: region text is full (ArduCopter.cpp.elf section .text)
Now looks like a avrcc issue?
Old Dec 26, 2012, 06:51 PM
Adilson is offline
Adilson's Avatar
Joined Aug 2012
Ok, I found the error. I have selected the wrong board by mistake and the target MCU simply do not have enough memory but now I'm hitting a lot of out of range warnings.
Old Dec 26, 2012, 07:12 PM
Adilson is offline
Adilson's Avatar
Joined Aug 2012
Ok, fixed. Looks like the whole issue was caused by selecting the wrong board. I don't know why but looks like arduino is keeping some sort of intermediary files or configurations that mess the things up if you have this kind of error. I just erased everything, downloaded a clean 1.0.3 arduino ide, put everything on a separate directory and it worked.
Old Dec 27, 2012, 07:27 AM
Adilson is offline
Adilson's Avatar
Joined Aug 2012
Does anyone use failsafe? I see it's disabled in the source code. I wonder if I can enable it and how to use it. My plan if to engage RTL if possible but I'm open to suggestions.
Thanks in advance.
Old Dec 30, 2012, 07:37 AM
Fester 1 is offline
Find More Posts by Fester 1
ProFester
Fester 1's Avatar
United States, NY, Wallkill
Joined Feb 2008
Originally Posted by albx View Post
frame http://www.goodluckbuy.com/reptile55...skid-gear.html
without the landing skid
motors are SunnySky X2212
props 10x4.5 GF
escs Hobbyking F-30A flashed with latest simonk firmware
and the FC is the Crius AIO PRO V1.1
with a 2200 3s turnigy battery
started with default, impossible to fly, lowered it, a little better, but seems the I term do nothing... for me in Acro is like fly stable, if i release the stick the quad go back at the level position... and I found maybe a bug I think in the mavlink, tried to lower the D-rate to 0, saved, read to see if it was saved and are ok.. read 0.. disconnect, reconnect and I found again 0.40...
How does it fly now ?
Fester 1 is offline Find More Posts by Fester 1
Old Dec 30, 2012, 08:00 AM
albx is offline
Find More Posts by albx
albx's Avatar
Italy
Joined Jun 2007
I gave up for now, I'm using multiwii...
btw... I'm using this http://www.multirotorforums.com/show...ator-for-Gopro for anti vibration with my RD32II with very good results.. no jello 1080@30fps... just tuned a bit the rope to don't be too much stiff and only 8 instead of 12 wires, only some micro vibrations that I think I can't remove, seems just my camera+board+multiwii+props... I'll try to change props for APC and see how it is... not going to buy a Naza right now... too expensive...
DIY Wire Rope Isolator for Gopro Camera (1 min 36 sec)
albx is offline Find More Posts by albx
Old Dec 30, 2012, 08:09 AM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Any idea if S-Bus is considered as RC input instead PPM for a future AC release ?
renatoa is online now Find More Posts by renatoa
Old Dec 30, 2012, 08:24 AM
Sir Alex is offline
Find More Posts by Sir Alex
Aleksey Kharlanov
Беларусь, Минская область, Минск
Joined Sep 2011
Sorry, maybe someone who have this receiver will make code for MPNG...
Sir Alex is offline Find More Posts by Sir Alex
Old Dec 30, 2012, 02:10 PM
Joined Sep 2007
No need for receiver, protocol is known, I can provide links for initial implementation, and will find testers for sure.
As a few guidelines, at hardware level it's a rs485 derived serial, 100kbaud, 2 stop bits, and at logic level the endianness is unusual, reversed versus the most used standard.
Asking because once Frsky will start PXX, there are hints they can drop CPPM in favor of S-bus. See recently launched S-Bus devices, at HiModel.
Old Jan 01, 2013, 12:14 PM
Paku is offline
Find More Posts by Paku
Poland, Mazowieckie, Warsaw
Joined Jan 2009
MultiiWii project has the SBUS libs as I know
Paku is offline Find More Posts by Paku
Old Jan 01, 2013, 09:33 PM
AcroFPV is online now
Find More Posts by AcroFPV
we dont NEED roads!
AcroFPV's Avatar
United States, CA, Rocklin
Joined Aug 2012
so i am hearing very good things from people beta testing ArduCopter 2.9
any chance theres work being done to get a MPNG 2.9?
AcroFPV is online now Find More Posts by AcroFPV
Old Jan 02, 2013, 11:20 AM
we dont NEED roads!
AcroFPV's Avatar
Joined Aug 2012
guess not??
Old Jan 02, 2013, 11:25 AM
jy0933 is offline
Find More Posts by jy0933
James not bond
jy0933's Avatar
Joined May 2012
really ? this man just done porting 2.8 a week ago.... say THANK YOU and GIVE HIM A BREAK
jy0933 is offline Find More Posts by jy0933
Discussion JR Indoor Photo Coverage - Higher Plane Productions JR Indoor Jim T. Graham JR Indoor Electric Festival 21 Dec 06, 2010 07:51 AM
Discussion We proudly present: brandnew Lubach F16 f. 90mm fan ost Electric Ducted Fan Jet Talk 17 Oct 03, 2010 11:46 AM
Poll nevermind pirates vs. ninjas Karl B² Life, The Universe, and Politics 3 Sep 05, 2010 10:59 PM
Hobbico - Futaba Apparel and Accessories - Wear your Futaba orange proudly! Dave Lauck Product Announcements 0 Apr 18, 2005 05:13 PM
