Old Feb 17, 2011, 03:36 AM
hendryc is offline
Find More Posts by hendryc
Australia, VIC, Boronia
Joined Feb 2011
SKARTEC 705 TX Issue... resolved?
Thanks Mark.
As they say... 'beggars cant be choosers'.
At the very least this will get me, and I dare say others, out of the $&*7 in the short term.
I will continue to investigate and if I come across any other feasable solutions I will pass them on here.
Cheers
HendryC
hendryc is offline Find More Posts by hendryc
Old Feb 17, 2011, 12:06 PM
Parkflying is offline
Find More Posts by Parkflying
United States, MI, Auburn Hills
Joined Dec 2008
Originally Posted by markf007 View Post
Hi hendryC,
The home made cable I made for my SKY-705 is able to configure the SKY-705 unit and also works with simulator programs.
Unfortunately the 'over-run' problem is not resolved with this cable.
Cable details attached. Use this information at your own risk.
Regards,
markf007
very nice drawing; btw what graphics program did you use to create this drawing from?
On the cable front; yes you are correct; the over run problem is in the firmware of the circuit and is not a cable problem. The only solution at this time is to use the Sky Flight Simulator Cable designed for earlier Transmitter models.
Max
Parkflying is offline Find More Posts by Parkflying
Site Sponsor
Old Feb 17, 2011, 07:18 PM
markf007 is offline
Find More Posts by markf007
Australia, VIC, Melbourne
Joined Jan 2011
Hi Max,
Windows 7 Paint.
Basically I extracted the connector images from google images, pasted the images into Windows 7 Paint and added the coloured connections between connectors.
Simply and very effective.
BTW thanks for all your assistance to date.
Regards,
Mark
markf007 is offline Find More Posts by markf007
Old Feb 18, 2011, 07:38 AM
hendryc is offline
Joined Feb 2011
Skyartec 705 TX USB Cable.
Hi Mark,
Yes I echo that praise re your diagram... It has driven me to action and I have just purchased the required items from JayCar - cost $A6.60 inc Solder (which I can never find when I need it) - and will be proceeding forthwith.
At the risk of being pedantic, may I clarify the orientation of the USB plug in your diagram?
Looking from the front (as you say) the 'plastic' bit with the 4 imbeded rails is in the bottom half of the plug - is that correct?
HendryC
Old Feb 18, 2011, 04:18 PM
markf007 is offline
Joined Jan 2011
Hi HendryC,
Yes that is correct.
Regards,
Mark
Old Feb 18, 2011, 05:37 PM
markf007 is offline
Joined Jan 2011
Building the cable
Hi,
In my case I purchased a USB printer cable and replaced one end with the 5 pin DIN connector. This approach will save on effort as you only need to solder up one end of the cable.
I also used 'Liquid electrical tape' within the 5 pin DIN to ensure nothing shorts out (even a short to the shield or outer portion of the 5 pin DIN could cause issues).
The cable colours used in the diagram are standard (if you end up buying a printer cable) with the following exceptions--->. On some pre built cables the yellow might actually be a green cable. The grey cable within the diagram signifies a white cable.
Just a few helpful hints for anyone undertaking the job.
Regards,
Mark
Old Feb 21, 2011, 10:43 AM
hendryc is offline
Joined Feb 2011
Repalcement Cable - SUCCESS!
Hi,
Regards,
Mark
Hi All and in particular markf007
Guided by the pin out diagram above, courtesy if the afore mention markf007
I proceeded to make up my own replacement cable for the 'inferior' specimen provided with my otherwise reasonable SKYARTEC Cessna 182 RTF kit.
The original cable gave up the ghost after approx 4-5 hours of sedate use - it could have been an isolated failure - except all the posts here are probably subject to the same sort of failure - most likely caused by inferior materials or poor QC.
Non the less, as I indicated above I decided to give it a go - utilising a spare USB printer cable as suggested, and a 5 pin 180 deg. Din plug (cost $A1.00) and even after the 'sloppiest' solder job I have ever had the misfortune to perform, I now have a FULLY functional cable - it responds to the SKYARTEC V2.1 Exe file, allowing programming of the TX (which was my prime concern) and is FULLY functional with the FMS simulator supplied with the kit.
I suspect - but can't verify firsthand - that it will function with any other simulator the original cable would have worked with.
Once again - many thanks to markf007 for his cheap, (cheaper than another garbage cable) and easy (if I did anyone can do it) solution to an unnecessarily frustrating issue.
Highly recommended to anyone finding themselves in this position. (see above in posts by markf007 for the details)
Cheers
HendryC
Old Feb 23, 2011, 07:35 AM
markf007 is offline
Joined Jan 2011
FYI...It seems that not all SKY-705 Transmitters have the overrun issue. I purchased a new Skyartec Cessna 182 today and the SKY-705 Transmitter does not have the overrun issue.
Regards,
Mark
Old Mar 19, 2011, 05:29 PM
vandino is offline
Find More Posts by vandino
Coventry. England.
Joined Jan 2011
Ive got 2 wires come off my 703 transmitter 5 pin din. Any idea on this pin config Mark? I believe several of the pins are linked by the looks of it. I'm going to post a general request on the forum.
vandino is offline Find More Posts by vandino
Old Mar 19, 2011, 07:57 PM
markf007 is offline
Joined Jan 2011
Sorry Vandino. I don't own a 703.
But if you note Max's comments in this forum thread he does state that:
The "programming" cable with the simple USB plug has not changed for any of the versions of Skyartec Tx models 703 or 705.
If you do have access to your dealer then this should always be your first port of call and especially if the unit is under warranty.
Old Mar 20, 2011, 08:23 AM
vandino is offline
Coventry. England.
Joined Jan 2011
Yep, I agree with what you're saying but this make is only available via tinternet AFAIK. Its a simple wiring job but I don't want to burn anything out of course. Looking at your diagram I noticed only 4 of the 5 pins are used. For sure, I have 5 wires. That is unless one was unconnected and just tucked into the plug BUT it was cut back which made me think it had been 'soldered' on. Also, it appears that several pins are bent and connected together. Someone will whip the back off theres I'm sure. Fortunately the tx side is fine so I had a little hover this morning. YAY.
Great Planes basic simulator FOAM---NO Simulator MUSTANGP51LOVE Non R/C Items (FS/W) 7 Mar 01, 2011 08:41 AM
Help! SKY705 issues jkaxford Skyartec 15 Feb 02, 2011 02:04 AM
Discussion DYNAM Simulator usb r/c flight simulator unleaded218 Simulators 3 Jan 12, 2011 02:41 AM
Help! Blade Mcx Battery Issues and Charger issues? FASTALJR Micro Helis 2 Dec 18, 2008 10:17 AM
Discussion HL revo issues (yes more issues) highflier Mini Helis 7 Sep 18, 2006 09:50 PM
