This thread is privately moderated by Sandancer, who may elect to delete unwanted replies.
Old Feb 02, 2011, 01:25 AM
Sandancer is offline
Find More Posts by Sandancer
"Auntie Samantha"
Sandancer's Avatar
USA, MO, Clever
Joined Dec 2009
Build Log
B-25 Mitchell "TONDELAYO": The Wing mods.
Once again I had to get in there and change out all that fiberglass with Carbon Fiber.
First I cut to length the two .394 CF rods to replace the fiberglass wing spars.
Tip: I found that if I tapered the tips of the CF rods, they will slide into those wing clamps much better and with less friction.
Once I got the two spars cut and tapered, I proceeded to remove the flat fiberglass spar and replace it with .325 x .125 CF using GG as the bonding glue. Once the glue had dried I filled the seams with Squadron putty, sanded and re-painted the wings with a mix of MM Azure blue and white to match the blue underside of the wings and nacelles.
Sandancer is offline Find More Posts by Sandancer
Found Hangar 9 or Top Flite B-25 Mitchell John Boy Aircraft - Electric - Airplanes (FS/W) 1 Oct 03, 2010 01:16 AM
Found Hangar 9 or Top Flite B-25 Mitchell John Boy Aircraft - Fuel - Airplanes (FS/W) 1 Sep 06, 2010 06:17 PM
