Old Jul 31, 2003, 03:07 AM
Andries Michielen
Andries Michielen
Guest
n/a Posts
Re: [EFLT] v-tail deflection vs. aileron deflection
This message from "Andries Michielen" <flyingdries@hotmail.com> brought to you by EFLIGHT!
This is a good reason to use more up than down movement on your v-tail. But
it was only found out after flight testing, I think you should start with an
equal movement to both sides and try to find out how much up or down
elevator you need in turns.
The reason why ailerons use more up than down has to do with side effects.
As you probably know increasing lift also increases drag (induced drag).
What you do with ailerons is create more lift on one wing and less on the
other which causes the aircraft to bank. Problem with this picture is that
you increase lift on your outboard wing and also create more drag which
causes the aircraft to yaw to a direction opposite to the turn, the reason
why especially gliders (large wingspan) need a mix of aileron and rudder in
a turn (the rudder counters the side effects of aileron deflection). With a
small down deflection the increase of lift and thus drag on the outboard
wing is minimized while the decrease of drag on the inboard wing is
countered by a larger deflection. Larger models still need some rudder input
in an turn.
Andries Michielen.
www.aeroclubkennemerland.nl
>From: "The Tellurian" <thetellurian@sympatico.ca>
>Reply-To: eflight@ezonemag.com
>To: "eflight@ezonemag.com" <eflight@ezonemag.com>
>Subject: Re: [EFLT] v-tails
>Date: Wed, 30 Jul 2003 16:31:26 -0400
>This message from "The Tellurian" <thetellurian@sympatico.ca> brought to
>you by EFLIGHT!
>On my scratch built E.G.O.R.E. electric glider I found that more down
>tended to make the glider lift it's tail in turns losing altitude in
>the process. Putting in more up than down helped by keeping the nose up
>and making my turns flatter. I didn't need to work the elevator so much
>in the turns. E.G.O.R.E. is RET only, spans 70" and is 28 oz AUW.
>On Wed, 30 Jul 2003 15:02:41 +0100, Roger wrote:
> >This message from "Roger" <e-flier@ntlworld.com> brought to you by
>EFLIGHT!
> >I'm currently toying with/starting to build a home brewed v-tailed
>glider.
> >1] Is there any advantage in having more up than down as is the way with
> >ailerons?
> >(or more down than up even!)
> >2] I hope to use a tubular fuz, and would much prefer to bring the
>pushrods
> >out through the tube, i.e. underneath the vee.
> >Every picture in every magazine I have has carefully got this all
>important
> >bit out of focus, or otherwise hard to see.
> >One case where a good drawing of the linkage is worth a thousand
>pictures!
> >Anyone?
> >TIA :-)
> > Roger (Cambridge UK)
> >...advice is free, you don't *have* to take it!
> >Archive: http://muffin.indexdata.dk/elist/
>Richard
>*** Any complaints or problems? Send an email to monitor@ezonemag.com
>*** For help with list commands go to
>http://www.ezonemag.com/pages/mailhelp.htm
>*** For the list rules go to http://www.ezonemag.com/pages/mailrule.htm
__________________________________________________ _______________
The new MSN 8: advanced junk mail protection and 2 months FREE*
http://join.msn.com/?page=features/junkmail
*** For help with list commands go to http://www.ezonemag.com/pages/mailhelp.htm
Old Aug 02, 2003, 03:02 AM
Johan Beyers
Johan Beyers
Guest
n/a Posts
RE: [EFLT] v-tail deflection vs. aileron deflection
This message from "Johan Beyers" <jbeyers@juizi.com> brought to you by EFLIGHT!
This got me thinking:
Would the least drag not be achieved by just lifting the inboard aileron,
getting both the bank and desired yaw with minimal control surface movement?
I realise that you might need some up elevator, but would this not be
preferable to using both ailerons?
I know that some computer radios should be able to do this.
BTW, since my flying skills are newbie/Gentle Lady class, there's no way I
can test this for myself.
Johan Beyers,
Stellenbosch, South Africa
-----Original Message-----
From: owner-eflight@ezonemag.com [mailtowner-eflight@ezonemag.com]On
Behalf Of Andries Michielen
Sent: 31 July 2003 07:22
Subject: Re: [EFLT] v-tail deflection vs. aileron deflection
you by EFLIGHT!
in an turn.
Old Aug 04, 2003, 03:02 AM
Bob and Rose
Bob and Rose
Guest
n/a Posts
This message from "Bob and Rose" <anpetu@dcdi.net> brought to you by EFLIGHT!
Johan wrote :"would the least drag not be achieved by just lifting the
inboard aileron---"
When I build an RC model with ailerons , I always tweak the linkage so
that I have considerable differential up-down between the two suffices .
Turns are nice and usually require no rudder input , but don't even think
about doing an aileron roll . Definitely not the way to go if you enjoy
aerobatics ; it is kinda like flying with only one aileron but it makes a
nice turning airplane .
"OUT"
AceRobert
Help - Prism 7x and V-Tail Mixing with aileron differential (channel 1 and 6) Cash Traylor Electric Plane Talk 9 May 20, 2001 10:31 PM
