Old Sep 28, 2011, 12:12 PM
wparsons's Avatar
Canada, ON, Markham
Joined Aug 2008
So, the hack kit, bearing and new voltage regulator showed up yesterday.
It took me about an hour total to disassemble it, remove the old voltage regulator, cut the casing for the programming plug, ream out the housing for the bearing, install the new regulator (and solder to existing posts), install and solder the posts for the programming plug, reassemble everything and upgrade the firmware.
Definitely not a hard upgrade at all, and I like the upgraded firmware better. One interesting thing to note is that messing with the firmware DOESN'T affect previously stored settings. I hadn't been changing much because I didn't want to have to redo it all, but it kept existing trim/dr/expo/etc settings for every model.
I changed the trim button settings so you have to press it for each step instead of just holding it down like stock, MUCH easier to fine tune the settings now. The finer and increased trim range is also nice.
If I were to do it again, I would skip the bearing upgrade on the steering wheel. It's a bit annoying to ream out the hole to get a snug fit for the bearing, and it doesn't really feel any different IMO. The bearing was only $4 so I'm not upset, but I don't notice enough of a difference to justify the 10 minutes it took to do that part.
If there's anyone local that wants to use my programming card you're more than welcome, but you'll still need the pins that go into the board soldered in first. Not sure where to source those as they came with my programming kit.
wparsons is offline Find More Posts by wparsons
Old Sep 28, 2011, 09:13 PM
Can we lift the embargo?
kenstogie's Avatar
menands flats, NY
Joined Dec 2006
Been using this radio for a few weeks and for the money I don't think you can beat it. Could some one explain the hook to set up dual rates? (Never did get the manual ) thanks!!!
kenstogie is offline Find More Posts by kenstogie
Old Sep 29, 2011, 07:28 AM
wparsons's Avatar
Canada, ON, Markham
Joined Aug 2008
I'm a little confused as to the dual rates, since there isn't a switch to turn it on/off. Normally dual rates set overall throw based on a switch position, but dual rate on this seems a little useless since it has EPA (end point adjustment) as well.
You can find the manual here: http://site.hobbypartz.com/manual/FS-GT3B-Manual.pdf
Old Sep 29, 2011, 08:17 AM
siberianhusky's Avatar
Canada, ON, Peterborough
Joined Nov 2009
Is there a timer of some kind? I time all my runs, no eagletree so accurate timing and mah put back into the pack gives me my average amp draw.
siberianhusky is offline Find More Posts by siberianhusky
Old Sep 29, 2011, 10:18 AM
kenstogie's Avatar
menands flats, NY
Joined Dec 2006
Thanks Wparsons! I don't think there is a timer but wish there was, please correct me or confirm
Old Sep 29, 2011, 10:57 AM
wparsons's Avatar
Canada, ON, Markham
Joined Aug 2008
Nope, no timer on it.
I'm mostly using mine for cars/trucks, so I don't really care about timing runs. I'm ready for a break long before the packs are half dead!
Old Sep 29, 2011, 11:18 AM
kenstogie's Avatar
menands flats, NY
Joined Dec 2006
i've noticed car runs seem alot longer than airplane runs, not sure if they are but they sure seem it.
Old Sep 29, 2011, 02:39 PM
wparsons's Avatar
Canada, ON, Markham
Joined Aug 2008
Cars on average draw a lot less amperage compared to their battery size than planes do. Planes tend to carry smaller batteries to save weight, where cars benefit from some weight for stability.
Boats are the worst, they're amp hogs x 100.
Old Sep 30, 2011, 01:08 AM
Joined Aug 2008
Hi guys
got mine and need some help please
I keep getting the Low Voltage warning and the beep beep (lower than 9.5v) even with freshly charged batteries.
Does anybody else have this issue?
JC
jerome888 is offline Find More Posts by jerome888
Old Sep 30, 2011, 07:39 AM
kenstogie's Avatar
menands flats, NY
Joined Dec 2006
I know that the voltage of the rechargable NIMH's is 1.2 per cell not the typical 1.5 of the alkaline type, perhaps that's it. Also maybe you have a bad battery in the mix. Just ideas maybe I am totally off, but maybe not.
Old Sep 30, 2011, 09:12 AM
Joined Aug 2008
That's what I thought also......
However I used the sme battery in my Futaba FM transmitter and everything is fine. The Futaba transmitter shows a voltage of 10.6v where as the FS shows 9.2v.......
What type of batteries do you guys used? Does anybody use a battery pack?
I have always used rechargeable NIMH ones for my old FM transmitter without any problem......
JC
Old Sep 30, 2011, 09:44 AM
wparsons's Avatar
Canada, ON, Markham
Joined Aug 2008
My 6 month old (with lots of use) alkalines are showing 10.6v on mine, BUT I replaced the voltage regulator. I've read that the stock one kills batteries in a hurry, and also heats up with prolonged use.
Old Sep 30, 2011, 09:50 AM
kenstogie's Avatar
menands flats, NY
Joined Dec 2006
How much of a pain is this to do? Not a electronic wiz. Thanks
EDIT: HERE'S THE INSTRUCTIONS FOR THE VOLTAGE REG CHANGE http://www.overkillrc.com/GT3B/GT3B%...all%20v1.0.pdf
Old Sep 30, 2011, 12:55 PM
wparsons's Avatar
Canada, ON, Markham
Joined Aug 2008
The whole process of tearing mine apart, installing the new VR, plug for the programming cord and bearing on the wheel and reassembling took less than an hour.
If you're comfortable soldering small wires in tightish spaces then you'll be fine. If not, maybe you don't want to try it.
The problem is that you have to snip the old one out, so if you can't get the new one soldered in the radio is useless unless you can find someone to do it for you.
I didn't find it too bad at all though, and I'm by no means a pro when it comes to soldering on circuit boards.
Old Sep 30, 2011, 01:39 PM
kenstogie's Avatar
menands flats, NY
Joined Dec 2006
Thanks WP, does it make that much of a diff. In your experience?
For Sale Traxxas TQ 2.4GHz Link 3-ch radio system mcoccia Cars - Cars and Parts (FS/W) 6 Feb 16, 2011 11:19 PM
For Sale Exceed RC 2.4Ghz 5 channel Radio system rccrazee Aircraft - General - Radio Equipment (FS/W) 1 Jan 01, 2011 02:23 PM
Help! Exceed RC 2.4Ghz 6-Channel Radio System problem chris10 Radios 1 Dec 31, 2010 10:49 AM
Discussion Correct procedure for reversing servos on FlySky FS-GT3B 2.4GHz radio Little-Acorn Car Talk 0 Nov 20, 2010 12:29 PM
