Old Feb 01, 2011, 12:30 AM
Flying Barry is offline
Find More Posts by Flying Barry
Australia, NSW, Sydney
Joined Jan 2007
HK-GT3B AFHDS 2.4ghz 3 Channel Radio System
Hey Guys's just noticed that HK have the HK-GT3B AFHDS 2.4ghz 3 Channel Radio System in stock.....for how long, who knows....
Same as Flysky and Eurgle model.
http://www.hobbyking.com/hobbyking/s...dProduct=16199
Barry
Flying Barry is offline Find More Posts by Flying Barry
Old Feb 01, 2011, 01:57 AM
nick30head is offline
Find More Posts by nick30head
nick 30
nick30head's Avatar
Joined May 2009
thats a goos price from HK, reminds me of the DX3S (10 model memory etc) but much cheaper, be good if they started making other receiver's like spektrum do, certainly give them a run for there money
if anyone has one of these, then lets no how it performs in the field
nick30head is offline Find More Posts by nick30head
Old Feb 01, 2011, 02:08 AM
Joined Jan 2007
I have the Eurgle model from R2Hobbies and it works flawlessly with Gas, Nitro and electric.
http://www.r2hobbies.com/eng/proddet...od=rcps2805004
Oh! The 3 CH RX is compatible between Eurgle, HK and i think Flysky versions also.
Barry
Old Feb 01, 2011, 02:18 AM
nick 30
nick30head's Avatar
Joined May 2009
soounds excellent barry, i had the flysky version but some new receivers would'nt bind so thats why i went with spektrum in the end, like you i've had no problems with mine except frying one
Old Feb 01, 2011, 02:21 AM
Joined Jan 2007
Frying one, how did you do that........
Old Feb 14, 2011, 09:41 AM
witespy is offline
Find More Posts by witespy
Clearwater, FLorida !
Joined Sep 2009
Hello.
I can not find the charging plug polarity in the manual
is the inside + or - ??
anyone know?
can I use this charger .
witespy is offline Find More Posts by witespy
Old Feb 14, 2011, 09:50 AM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
I can't see the markings on the charge plug well enough in those pictures, but it should indicate which part is which polarity.
wparsons is offline Find More Posts by wparsons
Old Feb 14, 2011, 10:15 AM
witespy is offline
Joined Sep 2009
No markings on the charge plug on mine
Old Feb 14, 2011, 11:50 AM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Go HK! Is there anything in the manual? I'll check my GT2 TX when I get home if I remember to see if the manual says anything, or if the case is marked.
Worst case I bet the board inside is marked in some way.
Old Feb 14, 2011, 12:56 PM
Joined Jan 2007
Hi witespy, normally the + inside pin and - outside buy you need rechargeable batteries of course. You can find the manual here for the Eurgle 2.4Ghz 3Ch, same controller just different name and the flysky is the same also.
Barry
Old Feb 14, 2011, 11:16 PM
witespy is offline
Joined Sep 2009
Barry
I know but spectrum stuff is - Inside pin. + outside.
Old Feb 15, 2011, 06:29 AM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Just checked my HK GT2, no marking at all other than "CHARGE"
Old Jun 07, 2011, 09:20 AM
wuudogg is offline
Find More Posts by wuudogg
wuudogg's Avatar
United States, VA, Leesburg
Joined Aug 2002
Spektrum charger didn't work.
Futaba does.
Center inside +
wuudogg is offline Find More Posts by wuudogg
Old Jun 08, 2011, 12:57 PM
785boats is offline
Find More Posts by 785boats
RELAX. You'll live longer
785boats's Avatar
Brisbane- Australia
Joined Jul 2007
Please be careful using rechargeable batteries, with these systems.
They are designed to run on 12V (8 x 1.5V cells) for the Tx & 6V (4 x 1.5V cells) for the Rx.
Rechargeable 1.2V cells will only give you 9.6V at the Tx & 4.8V at the Rx.
As stated in the manual the Tx gives a low voltage warning at 9.5V & I know that a lot of 2.4 gig receivers can lose signal if the voltage drops below 4.5V under load. I've seen it happen with some of our scale guys in the club. Even with Spectrum systems. They have also lost binding because of low voltage. When they changed to 1.5V duracells the problems went away.
If you are going to use rechargeable cells use at least the 2500mah size. That's what I use & it keeps the voltage up over the drop out limit for a lot longer.
If you are going to use rechargeable cells for the Rx, it's best to make up a 5 cell pack to give you 6V
As I always use the BEC in the ESC's that I use for racing I know that the RX is always getting 5V.
I only mention all this to try & help avoid a dead boat or a runaway boat. Seen them both happen.
I'm not saying that all systems suffer from this problem but some will.
Cheers.
Paul.
785boats is offline Find More Posts by 785boats
Old Jun 08, 2011, 09:00 PM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
nimh and nicad cells give way more than 1.2v when fully charged. My DX6i shows about 5.5v on 4 nimh cells when fully charged.
For Sale Traxxas TQ 2.4GHz Link 3-ch radio system mcoccia Cars - Cars and Parts (FS/W) 7 May 14, 2016 09:28 PM
For Sale Exceed RC 2.4Ghz 5 channel Radio system rccrazee Aircraft - General - Radio Equipment (FS/W) 1 Jan 01, 2011 02:23 PM
Help! Exceed RC 2.4Ghz 6-Channel Radio System problem chris10 Radios 1 Dec 31, 2010 10:49 AM
Discussion Correct procedure for reversing servos on FlySky FS-GT3B 2.4GHz radio Little-Acorn Car Talk 0 Nov 20, 2010 12:29 PM
