Old Feb 04, 2011, 06:59 PM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Happy to help, one builder to another.
target is offline Find More Posts by target
Old Feb 04, 2011, 08:38 PM
kilwein is offline
Find More Posts by kilwein
kilwein's Avatar
Joined Jan 2007
Hi Target,
Went with small plastic tubing, 1/8 tubing is close on one side.
I used some CA on the ends to seal and strengthen some.
Will use some small carbon tow on edges to strengthen a bit.
Now for some yellow tape.
EDIT:
Weighed the parts, added under 0.2grams including glue and 1/4 strip tape on outside..
kilwein is offline Find More Posts by kilwein
Old Feb 04, 2011, 09:31 PM
Philip Hallford is offline
Find More Posts by Philip Hallford
United States, CA, Santa Clarita
Joined Feb 2011
Hi Tony,
After trying different configurations on the wiring harness and the d9 connector, I found this to work very well without removing excessive
material or impacting the top skin of the center section as there is not
much space between the recessed cutout and the top skin, just one of
many ways I am sure it could be done, hope this helps you.
Phil
Philip Hallford is offline Find More Posts by Philip Hallford
Old Feb 04, 2011, 09:38 PM
kilwein is offline
kilwein's Avatar
Joined Jan 2007
Hi Phil,
We are thinking the same. I put some epoxy under-around the connector to beef up a bit. Wiring harness is done at DB9 and checked out on the flaps.
Working the tip connectors tomorrow.
Originally Posted by Philip Hallford View Post
Hi Tony,
Phil
Old Feb 04, 2011, 10:32 PM
lktroiani is offline
Find More Posts by lktroiani
"Get 'er Up"
lktroiani's Avatar
Wichita, KS
Joined Nov 2008
Watching with interest as I start my Vulture build. Thanks for the info.
lktroiani is offline Find More Posts by lktroiani
Old Feb 04, 2011, 10:43 PM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Looks good; I like the fuse cap, that is what I had in mind roughly. Great job.
R,
Target
Old Feb 04, 2011, 10:46 PM
rshelby is offline
Find More Posts by rshelby
Team Horizon
United States, CA, Montague
Joined Jan 2004
I have one of these as well. I flew it for the first time a couple of weeks ago on a solid overcast day at Visalia. It was generally buoyant air with occasional very weak thermals. I had not seen any set up documentation so I started from scratch with the cg and surface throws. It only took a few flights to get it probably 80% dialed in. I was very impressed with how coordinated and balanced the plane was. When put in a thermal turn, it did not require much correction to keep it there. I neither fell out nor into the turn. With those huge control surfaces, you don't have to move them very far to get a response. It was very responsive and fun to fly.
I have not yet flown it in active air, so I must reserve my final judgement until that time. I may have to move the cg forward when the air gets bumpy as it is currently back at the tow hook and the tow hook is as far back as it will go. I think that is about 105 mm which is considerably behind the recommended cg. I am not one of those guys that typically likes a rearward cg, so that may just go to show how large the tail is that I can fly it that far back. I will say that it has the most effective rudder of any TD plane I have ever flown.
Quality wise, it is about what I expected. Not great, but not bad either. The wing panels and tails fit much better than I expected and the wing joiner fit was perfect. (The joiners were marked for where they go so they had obviously been hand fitted.) I would prefer the flap and aileron control horns to be longer as I am using the shortest horns on JR 378 servos and still not using much travel. The wings are all glass behind the spar with carbon spars. I can't really see how it is constructed if front of the spars.The fuselage is glass in front of the wing and carbon from the wing saddle back. Other than the wing and tail skins being relatively easy to ding, the plane appears to be very strong.
Hopefully I can get out this weekend to fly it in some active air so that I can make some fair comparisons with other planes. It feels great to be flying a v tail again, it just looks so cool in the air.
Rick
rshelby is offline Find More Posts by rshelby
Old Feb 04, 2011, 10:51 PM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
What is your RTF weight, Rick?
Old Feb 04, 2011, 10:56 PM
rshelby is offline
Team Horizon
Joined Jan 2004
I have no idea. Maybe I'll weigh it this weekend. It feels like a real lump when I pick it up but flies really light.
Old Feb 05, 2011, 03:13 AM
rshelby is offline
Team Horizon
Joined Jan 2004
Weighed on my triple balance beam gram scale, my Vulture currently weighs 2258 grams or 79.6 ounces. It has about 4 ounces of lead in the nose now and may need another ounce when I finally get to fly it in some turbulent air. I made no attempt to build light, it was just a quick build using whatever I already had laying around in the shop. I bought this plane so I would have something to fly locally. The ground here in SoCal is about the same consistency as concrete 9 months of the year. So I wasn't concerned with building a perfect model since it is going to have such a rough life. And the plane is inexpensive enough that if I really like it, I can just buy another one to be my perfectly constructed, big time contest plane.
Rick
Old Feb 05, 2011, 10:31 AM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Roger, Rick.
That's not too bad. Servo selection etc, does add up too, but it's nice having brawny servos in a plane that you know will not have to be touched, too.
Maybe they can get different lighter tips for it in the future, as well, who knows.
I'm glad to see all the planes coming out that are made to save us money and still perform reasonably well. Its good for us, for sure, never a bad thing.
Thanks for taking the time to put her on the scale. It will be interesting to see what Tony's weighs when completed. Usually the first planes of any batch are heavier, and they get lighter as they progress a bit in production.
R,
Target
Old Feb 05, 2011, 12:56 PM
kilwein is offline
kilwein's Avatar
Joined Jan 2007
Installing the wing tip servo's.
Cut the control rod slots and rear spars, added carbon strips at the rear spar cuts. Sanded the slots and added CA to inside edges to seal up after the pictures taken. Now to glue servos in and let set until cured.
I cut the servo mount towards the main spar off, this is so I can get the servo as far forward as possible, this helps the top cover fit flush.
I used a 2-56 tap to clean threads on the clevaces. Makes the fine adjustments later easy.
Clean out the control horn holes, sacrifice a clevace for fit checks. see tool picture. I used a 0.060 drill, same size as the clevace's I am using.
Old Feb 05, 2011, 02:06 PM
Lite2bolt is offline
Find More Posts by Lite2bolt
S.E. Mi. arm pit of MI
Joined Jun 2004
Wish they made this in a cross tail version.
Lite2bolt is offline Find More Posts by Lite2bolt
Old Feb 05, 2011, 02:18 PM
fnnwizard is offline
Find More Posts by fnnwizard
RIP MC
fnnwizard's Avatar
United States, CA, Midway City
Joined Dec 2003
Kilwein, Nice job so far. Just one area I think you can improve upon. The ail control arm, for best results, the hole for the clevis should line up with the hingeline more in the vertical axis if you are going to mount the servo more towards the leading ede.
If you drew a line from the hingline to the ail arm clevis hole, that line should be close to 90 degrees with the control rod for optimum performance.
It looks like the ail arm is already glued in , so I would recommend mounting the servo more towards the trailing edge and block it with some ply to tie it into the spar.
From the looks of it right now, you will get more down te than up te for the same amount of servo throw each direction and it will be more prone to flutter when you are in reflex.
Try to get at least 2:1 servo throw/ail throw relationship. 3:1 even better.
Thanks for taking the time to show us your build!
This is for strong winching/f3j towing.
fnnwizard is offline Find More Posts by fnnwizard
Old Feb 05, 2011, 03:20 PM
mikelsfv is offline
Find More Posts by mikelsfv
United States, CA, Novato
Joined Jun 2008
Wow,
I posted a simple question yesterday and got a great response. Thank you all. I'm eager to get mine flying.
mikelsfv is offline Find More Posts by mikelsfv
For Sale Skip Miller Models Garage SALE! cody303 Aircraft - Sailplanes (FS/W) 9 Mar 11, 2011 10:12 AM
Cool New RnR MXC from Skip Miller Models thermal145 Cross Country Soaring 12 Jan 28, 2011 02:18 PM
For Sale Skip Miller Models Garage SALE! cody303 Aircraft - General - Radio Equipment (FS/W) 0 Jan 21, 2011 05:07 PM
Skip Miller Models Tom Gressman Vendor Talk 5 Jan 19, 2006 02:08 PM
