Old Jun 15, 2011, 08:28 PM
Bobalew is offline
Find More Posts by Bobalew
Denver
Joined Mar 2006
Originally Posted by kilwein View Post
Hi Fritz,
I did the same thing earlier and moved CG way back till V-tail was zero-ed out, I did not like how it flew. If CG is to far back on mine, it tip stalls in tight turns, but flies good in straight and mild turns.
I have mine at 94-95mm back AUW=83oz. Just measured CG this last sunday after Bob - Bobalew flew it. V-tail has just a small bit of up trim, but I am told this is sometimes normal for V-tails. The original one (larrycrash test dummy now has it) has a bit of up V-tail also and flies good. I will get a picture of mine tonight for you.
Bob seemed to like it as is. He commented it may be just a bit nose heavy.
He took the Vulture up and up in light air and when I got the plane back, I fell out of the thermal he had. He did the plane justice, difference between compitition and casual flyer. He can comment further if he see's the post.
I would move your CG forward and go with a bit of up V-tail for flight.
I have to say that after flying the Vulture, I was pleasantly surprized. It is very easy to circle in thermal flight, moves when you want it to, and lands well. But what really surprized me was how well it floats. I believe the model I flew was something like 82 oz. It just goes to show that maybe we shouldn't judge a plane on weight alone, but on overall handling.
A very forgiving sailplane.
BL
Bobalew is offline Find More Posts by Bobalew
Old Jun 15, 2011, 10:19 PM
kilwein is offline
Find More Posts by kilwein
kilwein's Avatar
Joined Jan 2007
This is the trim setting Bob used while thermalling last sunday. I have not move the trims since Bob flew it. Powered the TX-RX up for pic, trims saved in 14mz memory. I had a bit more, but Bob did a little tweaking for me.
Thanks Bob.
R,
Tony
Originally Posted by target View Post
What does the elevator trim look like in themal flight mode??
Is it the same or even with the root?
R,
Target
kilwein is offline Find More Posts by kilwein
Old Jun 22, 2011, 05:53 PM
Radian is offline
Find More Posts by Radian
Pompano Hill Flyers
Radian's Avatar
Coral Springs FL
Joined May 2002
Flown
So I have finally gotten my Vulture finished and flew its first flight last Thursday.
I used many of the "settings" discussed here as a start and I spent the morning tuning it.
I'm not done yet so I'll say the following is very subject to change....
Total AUW came in at 76.7oz.... CG at 95mm
Pro's: It slows down really nicely with its big flaps for landing.
My current settings have is thermal turning really smooth.
Con's: The decalage is definitely off. Too much up trim for level flight. I'll be adjusting the v-tail alignment pin holes over the next couple weeks to get this corrected.
I want to thank Kilwein for his build information as he inspired me to build a similar nose cap for my plane. I'll be looking to add a ballast system like his soon too.
Most of the build was "standard" so I won't bore you with that.... I did use 761 servos for the flaps and 809's for the ailerons. Also used a 5 cell 1700mah battery pack.
One place I did significant changes that might be of interest to many builders is the servo tray.
I did a lot of work to redesign the servo tray to get my servo's way up in the nose to lower total overall weight. It's a two piece tray system.
Below are some pictures of the final servo tray area and also some details of the build in progress.
I like to call this servo tray design the "where's the servo's" modification.....
Radian
www.phflyers.com
Radian is offline Find More Posts by Radian
Old Jun 22, 2011, 08:10 PM
kilwein is offline
kilwein's Avatar
Joined Jan 2007
Hi Radian,
Thanks for the comments. Glad the thread helped.
Like your servo tray mod, it hides the servos in the nose and looks like it reduces the AUW weight a bit.
That green nose is going to be seen for some distance.
R,
Tony
Old Sep 13, 2011, 03:22 PM
slopetrashuk is offline
Find More Posts by slopetrashuk
You must die! I alone am best.
slopetrashuk's Avatar
The Naughty Corner..Find me tweeting @slopetrashuk
Joined Sep 2003
Guys - I've been reading the whole thread with some interest.
Can you please clarify somethings for me?
I think from reading the previous posts that the model is made by MVM Model in Bulgaria which is something to do with both Vasil Milev (Vasil_M) and Nikolay Peichev. I get the Skip Miller / Cody Remington involvement in part at least but I am trying to determine whose design it is, how it is doing in competition and what is the wing section (if that has been made known).
Many thanks in advance.
Andy Ellison
UK
slopetrashuk is offline Find More Posts by slopetrashuk
Old Sep 14, 2011, 09:49 AM
vasil_m is offline
Find More Posts by vasil_m
Joined Jun 2010
Hi Slopetrashuk,
The wing section is MVM model (Vasil Milev) design.For now I will not give more information.
For the competition performance-Cody is the best testimonial.
Vasil Milev
vasil_m is offline Find More Posts by vasil_m
Old Nov 11, 2011, 05:13 PM
RCB757 is offline
Find More Posts by RCB757
Joined Oct 2007
I just won a Skip Miller Vulture sailplane from one of the RC clubs that I am a member of. I look forward to having the time to read this thread completely because I have lots of questions. Thanks to everyone for taking the time to report your progress!
RCB757 is offline Find More Posts by RCB757
Old Nov 11, 2011, 06:28 PM
cody303 is offline
Find More Posts by cody303
cody303's Avatar
Louisville, Colorado
Joined Nov 2003
Congrats on the win! Let me know if you need any help with setup or anything with the model.
The Vulture is a great plane. You are going to love it.
Cody
cody303 is offline Find More Posts by cody303
Site Sponsor
Old Nov 26, 2011, 06:26 AM
Tony Fu is offline
Find More Posts by Tony Fu
Joined Mar 2007
Hey, any one interest in seeing I have a build thread going on the new Vulture E
http://www.rcgroups.com/forums/showthread.php?t=1545664
Tony Fu is offline Find More Posts by Tony Fu
Old Nov 26, 2011, 10:45 PM
laryctdummy is offline
Find More Posts by laryctdummy
laryctdummy's Avatar
colorado
Joined Apr 2009
not me... thats like an engine on a sailboat.
laryctdummy is offline Find More Posts by laryctdummy
Old Nov 27, 2011, 02:27 AM
vasil_m is offline
Joined Jun 2010
Electric Vulture 3500
Everybody has an opinion and style of flying.
"MVM model"
Vasil Milev
Old Nov 27, 2011, 04:21 AM
AlpineDSacro is offline
Find More Posts by AlpineDSacro
registered user
New Zealand, Canterbury, Akaroa
Joined Sep 2008
Haha LOL
I'm with him
Didn't Queen have a moustache ?
AlpineDSacro is offline Find More Posts by AlpineDSacro
Old Nov 27, 2011, 09:25 AM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Yes, but he's dead now.....
Anyway, I'm sure that a build thread of an E-plane will be received well in the electric sailplanes forum, that is what it's for.... A link to it in this forum would be handy for those inclined.
That's my two cents!
R,
Target
target is offline Find More Posts by target
Old Nov 27, 2011, 04:45 PM
kilwein is offline
kilwein's Avatar
Joined Jan 2007
Hi Tony,
Feel free to leave the link to the E-build for who ever is interested in either style.
I feel both have a place.
Will be checking your build out as it progresses along.
I can say this "a certain flyer" likes to fly my AVA-E.
He was on the sticks today as a matter of fact.
Old Nov 27, 2011, 05:47 PM
registered user
Joined Sep 2008
Just making fun, don't take it so swerious x x x moustache wearers . .
For Sale Skip Miller Models Garage SALE! cody303 Aircraft - Sailplanes (FS/W) 9 Mar 11, 2011 11:12 AM
Cool New RnR MXC from Skip Miller Models thermal145 Cross Country Soaring 12 Jan 28, 2011 03:18 PM
For Sale Skip Miller Models Garage SALE! cody303 Aircraft - General - Radio Equipment (FS/W) 0 Jan 21, 2011 06:07 PM
Skip Miller Models Tom Gressman Vendor Talk 5 Jan 19, 2006 03:08 PM
