Old Aug 06, 2011, 06:45 PM
M4d_D is offline
Find More Posts by M4d_D
M4d_D's Avatar
Joined Dec 2006
hi,
ive got a problem with my hexa ... the light which shows that the motors are armed just blinks but i cant arm the motors. the gui isnt showing anything... as if the model wanst there
any ideas `?
PROBLEM SOLVED ... broken connection to the wm+ and a problem with the com port on the computer
M4d_D is offline Find More Posts by M4d_D
Old Aug 06, 2011, 09:56 PM
Goofy23 is offline
Find More Posts by Goofy23
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
man, you scare me twice a day
But i am releafed, you got your formula one car working, nice.
The octo seems to be pretty stable you fly.
Goofy23 is offline Find More Posts by Goofy23
Old Aug 07, 2011, 03:31 AM
larsm is offline
Find More Posts by larsm
larsm's Avatar
Germany, NRW, Münster
Joined May 2011
Originally Posted by Goofy23 View Post
i am curently working on it, one good news, i will support also a european GPS module avaiable here from germany.
Are there different GPS modules for different countries? Can I use FMP04-TLP GPS module in germany?
larsm is offline Find More Posts by larsm
Old Aug 07, 2011, 04:58 AM
M4d_D is offline
M4d_D's Avatar
Joined Dec 2006
i was scared too...
today is a presentation at our flying field and i wanted to do some aerobatics with the hexa ( we even bought smoke so it looks like an aerobatics plane ^^)
Old Aug 07, 2011, 05:52 AM
aBUGSnightmare is offline
Find More Posts by aBUGSnightmare
Joined Jul 2011
Originally Posted by warthox View Post
the mwc board from flyduino.com equipped with wmp; ready for flying
i love the color
Well done warthox (and Paul)
By the way: what kind of tape do you use for GYRO mounting (WM+)? I'm using the microbeast pads from freakware and would like to have a cheaper alternative.
aBUGSworstnightmare
aBUGSnightmare is offline Find More Posts by aBUGSnightmare
Old Aug 07, 2011, 06:21 AM
warthox is offline
Find More Posts by warthox
Joined Aug 2009
aBUGSworstnightmare
thanks
sorry i dont have the packing any more. so i cant tell u the right description atm.
its mirrortape from 'tesa'. 3 layers are perfect.
warthox is offline Find More Posts by warthox
Old Aug 07, 2011, 06:49 AM
Alexinparis is offline
Find More Posts by Alexinparis
Alexinparis's Avatar
Paris, France
Joined Jun 2009
heres the finished quad with the mwc board and centerplates from paul.
will test the new mwc fw 1.8 with it.
It's a very clean built.
I'm thinking about this center plate for my next proto.
I notice you didn't use the power distribution directly on the PCB.
Is there a reason for this ?
I think you could save a little bit the build time by avoiding one hole under the motor axis, and cut instead the unused part of the axis with a dremel. (and save something like 5g )
Alexinparis is offline Find More Posts by Alexinparis
Old Aug 07, 2011, 08:56 AM
jonnypaletta is offline
Find More Posts by jonnypaletta
Switzerland
Joined Jun 2011
It's possible with Multiwii_1.7 or Multiwii_1.8 stabilize the CAM PITCH and CAM ROLL and at same time control the CAM Pitch or Roll with a potentiometer on my TX for find a correct angle of view?
jonnypaletta is offline Find More Posts by jonnypaletta
Old Aug 07, 2011, 09:43 AM
Joined Jul 2011
Hi,
yes, it's possible with V1.8. You need to uncomment the SERVO_TILT which is in config.h.
change:
Code:
/* The following lines apply only for a pitch/roll tilt stabilization system
   On promini board, it is not compatible with config with 6 motors or more
   Uncomment the first line to activate it */
//#define SERVO_TILT
to:
Code:
#define SERVO_TILT
Be shure you have enough channels on your TX!
Rgds
aBUGSworstnightmare
Old Aug 07, 2011, 11:17 AM
Goofy23 is offline
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
I also dont know why he didnt used the onboard distri.
Alex i will send you a set, no prob, will be glad to see it in your hands.
Old Aug 07, 2011, 11:41 AM
flow23 is offline
Find More Posts by flow23
Deutschland
Joined Jul 2011
Hi, I'm using the flyduino warthox board and I don't get any reading from the wmp and nunchuk. Maybe I wired it wrong. Can someone help me please?
Infos:
MultiWii_1.8 code with changed flight mode -> HEX6X
No others changes.
flow23 is offline Find More Posts by flow23
Old Aug 07, 2011, 11:54 AM
Goofy23 is offline
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
on the pics from warthox you should be able to see how it should be.
Your WMP looks correct, you may should try with the WMP only first and its may a good idea to connect your acc directly to the I2C line as its possible now.
Old Aug 07, 2011, 12:08 PM
Switzerland
Joined Jun 2011
Hi,
change:
Code:
to:
Code:
#define SERVO_TILT
Rgds
aBUGSworstnightmare
I have ch7 and ch8 empty on my RX, how i must connect ex. ch7 on Flyduino for control CAM TILT with a potentiometer on my TX?
Old Aug 07, 2011, 12:16 PM
flow23 is offline
Deutschland
Joined Jul 2011
I did connect the WMP first and after no readings I added the nunchuk. I double checked the wires and checked the connection of the wires from the WMP to the board.
New Product Please let me introduce myself jimaquo Dock Talk 7 Oct 27, 2010 02:27 AM
Let me introduce the DEMON!!!! (Transparent covering and eliptical wing!!!) modest-master Sport Planes 7 Aug 25, 2002 11:46 PM
Let me introduce Angelis 280/400, Benjamin, Zombi (ARFs) modest-master Parkflyers 17 Mar 14, 2002 01:20 PM
Let me introduce the "NIKE" modest-master Electric Sailplanes 3 Mar 07, 2002 05:20 AM
