Old Jul 28, 2011, 11:30 AM
r0sewhite is offline
Find More Posts by r0sewhite
It wasn't me
r0sewhite's Avatar
Augsburg, Germany
Joined Mar 2010
1) Turnigy Plus = Hobbywing Pentium
2) Black Mantis = HK Blue Series = Maytech = Xetronic
I prefer 2 since you can change the rotation direction by programming. It's sometimes better than having to swap motor cables.
r0sewhite is offline Find More Posts by r0sewhite
Old Jul 28, 2011, 11:31 AM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
also #2 has the worst throttle response of any other esc.
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old Jul 28, 2011, 12:38 PM
Goofy23 is offline
Find More Posts by Goofy23
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
Originally Posted by aBUGSnightmare View Post
Hi Paul,
when will your new BOB for the Atmel IMU be available? I'm just thinking about which IMU I will use for the Flyduspider and would like to have another SBIN1 as an option.
Do you have an idea on the selling price for the bat-holder and the arms yet?
By the way, I think your footprint for the SMD resistors is quite small (for hand soldering); maybe you would like to make a small improvement on it and keep SMD resistors for the pull-ups on the new BOB design (use 1206; I've learned that most people - even those with little or less soldering skills - can handle it).
Rgds
Joerg
The resistors are 1206, of course i choosed 1206 for handpicking.
Also like 1206 more then trough hole.
But everyone with little soldering skills will be able to do it.
The endprices are not calculated, but it wont be that expensive.
The bob now is usable for every sensor config, of course.
Just made the atmel bob, as its it pretty easy to mount then, plug n play.
The hole board will get a vibration dampening, as the sensors are mounted directly then.
It will also be round to support + mode flying.
To the few failures some llc bobs have, i am sure its my handsoldering sorry for that, but of course i will send you anew one if you didnt get it working.
If you have problems, please try to resolder the pins first.
Goofy23 is offline Find More Posts by Goofy23
Old Jul 28, 2011, 01:20 PM
st99 is offline
Find More Posts by st99
st99's Avatar
United States, PA, Uniontown
Joined Jan 2005
OK, thanks for the info.
st99
st99 is offline Find More Posts by st99
Old Jul 28, 2011, 01:31 PM
aBUGSnightmare is offline
Find More Posts by aBUGSnightmare
Joined Jul 2011
Hi Paul,
I spend nearly the hole day trying to get it working. The problem is, that it works for some time and then suddenly stops working (I've probed the I2C bus - before and after the LLC - with an Logic16 logic analyzer I have at hands (http://www.saleae.com/logic16/)) and I don't get any data out of the LLC after some time. That's why I suspect there's a problem with the PCB (and because I've re-soldered every connection twice).
Having a BOB in exchange would be o.k..
Since you're designing a new BOB version why don't you use a 'true' I2C level converter (i.e. TXS0102 or PCA9306A (preferred))? Well, you would have to mount them (or have them mounted) since they come in SSOP packages, but this would be an ideal and reliable solution (no problem with bus lenght (I2C has a 400pf capacitance limit) and 400kHz bus frequency).
Rgds
Joerg
aBUGSworstnightmare
aBUGSnightmare is offline Find More Posts by aBUGSnightmare
Old Jul 28, 2011, 01:42 PM
It wasn't me
r0sewhite's Avatar
Augsburg, Germany
Joined Mar 2010
Only if you forgot to change startup speed from soft (default) to fast.
Old Jul 28, 2011, 02:15 PM
Goofy23 is offline
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
Hi Paul,
Rgds
Joerg
aBUGSworstnightmare
Those Mosfets are very good, normally, but yours have to be replaced.
There is much written about it, i read some ELV articles about it.
I switch to regular trough hole, think it will be ok thenm normally those mosfet llc gives us very good i2c signals.
Old Jul 28, 2011, 04:04 PM
warthox is offline
Find More Posts by warthox
Joined Aug 2009
Originally Posted by st99 View Post
Hi Warthox,
What ESC would recomend.? I am going to make an order in a couple more days for the flyduspider frame and flyduino board.
at99
i use turnigy plush and hobbywing pentium.
i installed arround 100 yet and all work perfectly. not one was damaged or doesnt work.
warthox is offline Find More Posts by warthox
Old Jul 28, 2011, 07:29 PM
st99 is offline
st99's Avatar
Joined Jan 2005
Sounds good.
Thanks.
Old Jul 28, 2011, 07:35 PM
fr3d-nexus is offline
Find More Posts by fr3d-nexus
fr3d-nexus's Avatar
France (near the ch'ti village)
Joined Apr 2007
monitoring lipo with mega mission planner
hi goofy,
I am trying to understand megapirates code's using mega planner mission for an megaheXa. I have some difficulties to connect to the card with or without the cli (I will try on a different computer, or with a differents usb chip I'm using an usb plug with the cp2102 chip )
but this not the problem.
so here is the question :
I'would like to monitor the lipo battery under mission planner, must I build, as in a multiwiirotor, an external resistor divider with 33k & 51k ? and connect the middle to A0 ?
or there is already a built-in divisor and I had only to plug the main lipo(3s) red wire on the "IN" flyduino pin ? (I'm using a external bec, nor esc bec) .
greetings.
fr3d-nexus is offline Find More Posts by fr3d-nexus
Old Jul 28, 2011, 07:42 PM
timecop is offline
Joined Dec 2010
Maybe you misunderstand what "throttle response" is.
This is startup response.
Old Jul 28, 2011, 11:01 PM
birdofplay is online now
Find More Posts by birdofplay
Retired CAD guy
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
fr3d-nexus: with the power distribution board it would be easy to add resistors
and then run the center wire to your port.
birdofplay is online now Find More Posts by birdofplay
Old Jul 29, 2011, 01:32 AM
It wasn't me
r0sewhite's Avatar
Augsburg, Germany
Joined Mar 2010
It does not only affect the first spin up but smoothes any change of the throttle channel. A simple way to find out: Keep this parameter on SOFT and the copter will wobble even with very low PID values. Set it OFF and the ESC reacts like it should.
Old Jul 29, 2011, 06:00 AM
Joined Jul 2011
Universal Mounting plate
Hi,
this is a little bit off-topic, but 'who dares wins'!
I'm looking for a universal mounting plate (like the one shown in the picture, 50x50mm, made of plastic or ..., 45mm mounting holes) for mounting i.e. my receiver on the Flyduspider.
Does anybody know were I can buy one off the shelf?
I can't make them myself since I don't own a milling machine (and I don't want to do it with a jigsaw).
I would also like to know if somebody would mill them for me. I have a drawing made with Eagle at the moment (the one shown in the attachment).
Thanks for answering
Joerg
Old Jul 29, 2011, 08:05 AM
M4d_D is offline
Find More Posts by M4d_D
M4d_D's Avatar
Joined Dec 2006
hi ,
i have a big problem with my octo at the moment...
if i fly with gyros only it works great , if i switch the accelerometer on it flies okay but sometimes it suddenly tips forwards or backwards ( never to the side ) and i have to counteract really hard to keep it under control . i wanted to try fpv today ( first time ) and it did that and landed in a tree ... nothing except one prop broke but i need to know why it does that .
im using flyduino and ff imu
i might be forced to switch to wm+ with bma020 but i therefore i would need another board i.e. the flydusense bob . when will thete be new ones paul ? dont you have any left ? what about bma020 ?
if someone has a clue what might cause the behaviour i described please post it or send me a pm ...
i just hope the ff imu isnt damaged
M4d_D is offline Find More Posts by M4d_D
New Product Please let me introduce myself jimaquo Dock Talk 7 Oct 27, 2010 02:27 AM
Let me introduce the DEMON!!!! (Transparent covering and eliptical wing!!!) modest-master Sport Planes 7 Aug 25, 2002 11:46 PM
Let me introduce Angelis 280/400, Benjamin, Zombi (ARFs) modest-master Parkflyers 17 Mar 14, 2002 01:20 PM
Let me introduce the "NIKE" modest-master Electric Sailplanes 3 Mar 07, 2002 05:20 AM
