Old Jul 27, 2011, 08:01 PM
Goofy23 is offline
Find More Posts by Goofy23
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
have both, but used for the LLC (only for that, FD´s are auto pick n place) the regular iron.
Most of them work good, but 2 people told they had problems with the soldering joints.
I will switch to a through hole design now, as i dont want to let them to be made and populated, only 4 easy parts to be soldered, or?
To let them produce wil take longer, so i decided for the quick route.
Goofy23 is offline Find More Posts by Goofy23
Old Jul 27, 2011, 08:27 PM
r0sewhite is offline
Find More Posts by r0sewhite
It wasn't me
r0sewhite's Avatar
Augsburg, Germany
Joined Mar 2010
Okay, I feared you might only have a soldering iron. I've got a cheap Gordak hotair station since many years and it's probably my most used tool. Don't ask me, how many uBGA I reballed with it. It must be hundrets of hours and it still works fine.
r0sewhite is offline Find More Posts by r0sewhite
Old Jul 27, 2011, 11:17 PM
aBUGSnightmare is offline
Find More Posts by aBUGSnightmare
Joined Jul 2011
Originally Posted by Goofy23 View Post
Thanks.
The batt plate will be here soon, arms are ordered but will take a bit.
Oh no not another not working llc, yes you are right the llcs i solder by hand.
But guess on what i worked today, a nice bob for the imu you showed
I normally like smd a lot more then trough hole, but i will switch to through hole and will sell them as kits, just the 2 mosfets and 2 resistors to solder, it maybe better the people care for theirself, to solder some parts and some connectors is easy, but to do a whole batch is anoying and leads to failures, sorry for that, i am glad that so able people are here who figgure out most of their problems themself or even better help others with their knowledge, cool.
Some build docimentation is still planned but not made, sry.
BTW, Fabio and Jussi will release new IMU boards soon (2 weeks) but i decided to also support the atmel imu.
Hi Paul,
when will your new BOB for the Atmel IMU be available? I'm just thinking about which IMU I will use for the Flyduspider and would like to have another SBIN1 as an option.
Do you have an idea on the selling price for the bat-holder and the arms yet?
By the way, I think your footprint for the SMD resistors is quite small (for hand soldering); maybe you would like to make a small improvement on it and keep SMD resistors for the pull-ups on the new BOB design (use 1206; I've learned that most people - even those with little or less soldering skills - can handle it).
Rgds
Joerg
aBUGSnightmare is offline Find More Posts by aBUGSnightmare
Old Jul 27, 2011, 11:23 PM
It wasn't me
r0sewhite's Avatar
Augsburg, Germany
Joined Mar 2010
Why should there be a special BOB for an IMU? The already existing BOB should be good for any IMU or single sensor.
Old Jul 28, 2011, 06:17 AM
M4d_D is offline
Find More Posts by M4d_D
M4d_D's Avatar
Joined Dec 2006
http://www.hobbyking.com/hobbyking/s...Warehouse.html
hobbyking ss regler im deutschen lager
M4d_D is offline Find More Posts by M4d_D
Old Jul 28, 2011, 07:09 AM
kinderkram is offline
Find More Posts by kinderkram
OS Sponsor
kinderkram's Avatar
Germany, NRW, Dusseldorf
Joined Jun 2010
And if you wait long enough (keep the page open for some time) they will offer you the item for 7,06$ in a popup.
Including shipping that makes ~5€ if you take 10pcs.
Ordered some. Thx for the info!
kinderkram is offline Find More Posts by kinderkram
Old Jul 28, 2011, 07:24 AM
Joined Jul 2011
Thanks.
Hi Paul,
sorry, aber der LLC funzt nur sporadisch! Ich vermute dass das PCB einen Haarriss im Bereich des LLC hat. Das Board funktiniert eine gewisse Zeit, dann steigt die GUI aus und es werden nur noch Schrottdaten bzw - in den meisten Fällen - keine Daten mehr ausgegeben.
Wenn man dann die Leiterplatte im Bereich des LLC 'drückt' ist er wieder bereit mitzuarbeiten.
Also, was tun?
Joerg
Short englich translation:
The LLC of the BOB I've received is only working sporadically. I suspect there is a hairline crack in one of the PCB traces in the area of the LLC. If one 'presses' the board in this area the LLC will work for some time again and then stop working (or only outputting junk data).
So, what's the solution for the problem?
Old Jul 28, 2011, 07:25 AM
jevermeister is offline
Find More Posts by jevermeister
jevermeister's Avatar
Deutschland, SH, Kiel
Joined Jul 2011
ah Kinderkram, you should order more stuff at HK I only paid 7,02$ .
Nils
ps.: next time we should do a "collectet order" (sammelbestellung) this saves money.
jevermeister is offline Find More Posts by jevermeister
Old Jul 28, 2011, 07:27 AM
alteskind is offline
Find More Posts by alteskind
Deutschland, Schleswig-Holstein, Kiel
Joined Jan 2011
as platinum buyer you will get them for 7,02 immediately without waiting
btw, i can recommend the frame center plates from flyduino.com
they look nice and are well done. cutting and screwing the arms was easy and just took about 1 hour.
the flyduspider frame looks soooo aweful.
with the same package i got the nice quadro centerplate , which is made very fine too.
that props from flyduino are almost the same (seem little stiffer) as gaui 330x props, at a 3 times lower price
the order was sent fast, and was packed fine.
i like pauls shop very much.
alteskind is offline Find More Posts by alteskind
Old Jul 28, 2011, 07:29 AM
Gaza07 is offline
Find More Posts by Gaza07
Gaza07's Avatar
United Kingdom, England, Nottingham
Joined Nov 2002
If you have used HK before and login you will get the best price with out sitting and waiting, I just logged in and got $7.02
Gaza07 is offline Find More Posts by Gaza07
Last edited by Gaza07; Jul 28, 2011 at 07:30 AM. Reason: Looks like I was beaten to it :D
Old Jul 28, 2011, 07:51 AM
OS Sponsor
kinderkram's Avatar
Joined Jun 2010
Funny guys!
Guess what: I am a Platinum Member and 7,06 was just a typo.
I paid 7,02$ - ok?
Old Jul 28, 2011, 08:58 AM
JUERGEN_ is offline
Find More Posts by JUERGEN_
xxxxxxxxxxxxx
JUERGEN_'s Avatar
Deutschland
Joined Nov 2009
Funny guys!
I paid 7,02$ - ok?
no swarm code ?
JUERGEN_ is offline Find More Posts by JUERGEN_
Old Jul 28, 2011, 09:27 AM
birdofplay is offline
Find More Posts by birdofplay
Retired CAD guy
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
since almost all esc's in this class are BK,
you better start BUYING and stop POSTING !
birdofplay is offline Find More Posts by birdofplay
Old Jul 28, 2011, 10:06 AM
warthox is offline
Find More Posts by warthox
Joined Aug 2009
good luck with these escs. i dont like the ss escs and would never use them again for a multiroto...
warthox is offline Find More Posts by warthox
Old Jul 28, 2011, 11:18 AM
st99 is offline
Find More Posts by st99
st99's Avatar
United States, PA, Uniontown
Joined Jan 2005
Hi Warthox,
What ESC would recomend.? I am going to make an order in a couple more days for the flyduspider frame and flyduino board.
at99
st99 is offline Find More Posts by st99
New Product Please let me introduce myself jimaquo Dock Talk 7 Oct 27, 2010 02:27 AM
Let me introduce the DEMON!!!! (Transparent covering and eliptical wing!!!) modest-master Sport Planes 7 Aug 25, 2002 11:46 PM
Let me introduce Angelis 280/400, Benjamin, Zombi (ARFs) modest-master Parkflyers 17 Mar 14, 2002 01:20 PM
Let me introduce the "NIKE" modest-master Electric Sailplanes 3 Mar 07, 2002 05:20 AM
