Old Jun 11, 2011, 08:19 AM
xxxxxxxxxxxxx
JUERGEN_'s Avatar
Deutschland
Joined Nov 2009
Englisch versteht nur mein PC.
jetzt wo die hardware fest steht.
und sich viele mit dem ARDUINO schwer tuen,
ist es doch einfach eine fertige "Flyduino9DOF.hex"
via AVRDUDE auf dem Flyduino speichern ?
English only understands my PC.
now that the hardware is fixed.
tuen and many difficulties with the Arduino
yet it is simply a ready-made "Flyduino9DOF.hex"
store via the AVRDUDE Flyduino?
JUERGEN_ is offline Find More Posts by JUERGEN_
Old Jun 11, 2011, 08:20 AM
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
Thanks Guys, it seems here is good hlep comunity established.
You dont need the LLC Jussi designed his board to work as it is with a Arduino, only important thing then.....disable the pullups in the multiwii code!
Kinderkram is absolutely right, it seems the "blob" is missing, 2 leds have to light up on the FFIMU to show propper function.
Define the Mega, this should give you RX signals in the GUI.
Goofy23 is offline Find More Posts by Goofy23
Old Jun 11, 2011, 08:21 AM
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
yes jürgen good idea, but there is allready a preconfigured multiwii on it.
But there are so many different configs, i think everybody have to do his settings on its own.
Old Jun 11, 2011, 08:46 AM
Deutschland, HE, Lampertheim
Joined Aug 2007
Thanks for your Help.
Whats is "blob". I make a Connection on the FFImu from Pwr to enable on the Backsite from the FFImu.
The Software from the MultiWii_dev is 1.8.
I Have Change the Sketch in Mega and the RX signals are one the GUI :-)) Here the better Pics.
Marc
Blade1975 is offline Find More Posts by Blade1975
Old Jun 11, 2011, 10:27 AM
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
Great, i think you made the right connection, it doesnt matter if its on the underside or on top.
Does now everything work fine?
Old Jun 11, 2011, 10:44 AM
Joined Aug 2007
The Rx on the GUI works, but the Copter Display on the GUI doesn't not Work korekt.
Old Jun 11, 2011, 10:55 AM
AutoQuad Team
kinderkram's Avatar
Germany, NRW, Dusseldorf
Joined Jun 2010
Originally Posted by Blade1975 View Post
The Rx on the GUI works, but the Copter Display on the Gaui is the same.
The 3rd of your pics above shows that you still don't have the sensors activated. Instead you ARM the motors when AUX1 is low AND high and AUX2 is low!
Remove these and set the sensor like this:
- Accels activated when AUX1 is low, mid and high (so it's in stable mode no matter how AUX1 is switched)
- Baro when AUX1 is mid and high
- Mag activated when when AUX2 is mid and high
That way you can see the sensor in the GUI when no Tx/Rx is connected (values always mid), baro is on when AUX1 is switched on and mag on when AUX2 is switched on.
kinderkram is offline Find More Posts by kinderkram
Old Jun 11, 2011, 01:58 PM
Svizzera, TI, Lugano
Joined Jun 2011
Hi,
when i use Turnigy plush 25A ESC's the minthrottle it's the same of the PLUSH 10A ESC's?
I have buy the 25A, because the 10A are backorder...
jonnypaletta is offline Find More Posts by jonnypaletta
Old Jun 11, 2011, 03:15 PM
Deutschland, Schleswig-Holstein, Kiel
Joined Jan 2011
Originally Posted by jonnypaletta View Post
Hi,
if motors keep running when armed, minthrottle is high enough
think this minthrottle parameter is for preventing inflight-motorstops
using 10A plush parameter should work, i use 12A turnigy plush and some pentium 25A with 1190 minthrottle - both work fine.
alteskind is offline Find More Posts by alteskind
Old Jun 11, 2011, 04:53 PM
Joined Aug 2007
Hy,
thanks for all your posts. Everything works. Does anyone have any idea why the flight direction is wrong in the GUI? Or is this no Problem?
Old Jun 11, 2011, 06:41 PM
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
orientate yourself on the pitch and roll grafic, turn your copter to the left, does it roll to the left, arrow goes down on left side?
Pitch it forward does the pitch arrow move down?
If yes your imu is mounted right if not its not right.
As there are all chips on the pcb and jussi made the design having in mind the multiwii settings you should be right then.
Old Jun 12, 2011, 04:01 AM
Joined Aug 2007
Hy,
the first flight was Very good My first impresion, the Barometer works + - 2 Meter is this normal? The stable Mode is a little bit better than the BMA020. The Magnetometer doesn't work, but the Display work in the GUI, i don't no why
Many thanks on all for Help
Marc
Old Jun 12, 2011, 04:12 AM
fr3d-nexus's Avatar
France (near the ch'ti village)
Joined Apr 2007
hye all,
I would like to jump to a better fpv and aerialphotographic system. I need some advises for the electronic. If I've well understand, to have a full stable multirotor with gps and waypoint
I need :
-a flyduino board
-an ArduPilot Mega IMU Shield/OilPan Rev-H V1.0http://www.buildyourowndrone.co.uk/A...th-p/op-wp.htm
-a gps http://www.buildyourowndrone.co.uk/M...gps-mt3329.htm
- some motors esc,propeller, of course home made frame.
-and the ardupirates software or arducopter ?
is it correct ?
thanks for your answers fr3d.
fr3d-nexus is offline Find More Posts by fr3d-nexus
Old Jun 12, 2011, 04:58 AM
AutoQuad Team
kinderkram's Avatar
Joined Jun 2010
Originally Posted by fr3d-nexus View Post
hye all,
I need :
-a flyduino board
is it correct ?
Nope - if you want to use the original ArduCopter2 code (or the PiratesNG) you need the original DIYDrones hardware: the APM & IMU (oilpan)
If you want to use the MultiWii or the MegaPirates' code you need a Flyduino and Jussi's FFIMU or a similar sensor board like the Allinone.
GPS doesn't work on the MW code atm.
Old Jun 12, 2011, 06:52 AM
Joined Aug 2007
Is the up and downs from the Magnetometer normaly?
New Product Please let me introduce myself jimaquo Dock Talk 7 Oct 27, 2010 02:27 AM
Let me introduce the DEMON!!!! (Transparent covering and eliptical wing!!!) modest-master Sport Planes 7 Aug 25, 2002 11:46 PM
Let me introduce Angelis 280/400, Benjamin, Zombi (ARFs) modest-master Parkflyers 17 Mar 14, 2002 01:20 PM
Let me introduce the "NIKE" modest-master Electric Sailplanes 3 Mar 07, 2002 05:20 AM
