Old Jun 07, 2011, 01:12 PM
kinderkram is offline
Find More Posts by kinderkram
OS Sponsor
kinderkram's Avatar
Germany, NRW, Dusseldorf
Joined Jun 2010
Originally Posted by Gaza07 View Post
I received my Allinone sensor board today and my GPS module (just need a GPS bob now )
Heres a picture of how I wired mine I have tried it with the mutiwii code and every thing appears to be working, I have performed a test hover and all seemed fine the auto level and the mag but the baro seemed to make it a little unstable
Looking good!
To make the baro work properly you need to cover it with some open cell foam (or similar) and hide it from the sun.
If you put the baro on a switch in your Tx you can test it and tune the PIDs to get the most from it.
kinderkram is offline Find More Posts by kinderkram
Old Jun 07, 2011, 02:17 PM
Gaza07 is offline
Find More Posts by Gaza07
Gaza07's Avatar
United Kingdom, England, Nottingham
Joined Nov 2002
Thanks for the info I just need a link to the latest mega pirate code and what ever info i need to set it up with a flyduino and allinone
thanks
Gary
Originally Posted by kinderkram View Post
Looking good!
Gaza07 is offline Find More Posts by Gaza07
Old Jun 07, 2011, 03:36 PM
OS Sponsor
kinderkram's Avatar
Joined Jun 2010
thanks
Gary
Here you go:
http://www.rcgroups.com/forums/showt...4#post18244388
Would be nice if you could post your experiences in that thread.
Old Jun 08, 2011, 03:02 PM
Goofy23 is offline
Find More Posts by Goofy23
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
thanks for the picture, good to hear its working, this will help others a lot.
Goofy23 is offline Find More Posts by Goofy23
Old Jun 08, 2011, 07:32 PM
Electraflyit is offline
Find More Posts by Electraflyit
Toowoomba,Australia
Joined Jul 2002
Gaza,
Did you need to go through the Flydusense or can you go straight into the Flyduino from the Allinone?
thanks eddie
Electraflyit is offline Find More Posts by Electraflyit
Old Jun 08, 2011, 08:10 PM
Goofy23 is offline
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
you can go straight in to it too, of course.
The version with llc is a no brainer, the version without llc needs disabled pullups in multiwii soft.
Connect GND 5V SCL and SDA, thats it.
Old Jun 08, 2011, 11:41 PM
Gaza07 is offline
Gaza07's Avatar
Joined Nov 2002
You can go straight from the allinone to the flyduino with the four wires as Paul said before because it has the built in LLC, I prefered to have the wires coming from the edge of the flydusense board rather than them coming from the centre,
And the flydusense board just looks the mutts nuts with the flyduino and flydubution
Originally Posted by Electraflyit View Post
Gaza,
thanks eddie
Old Jun 09, 2011, 04:44 PM
apache74 is offline
Find More Posts by apache74
apache74's Avatar
France, RA, Bossey
Joined May 2011
connecting allinone-flydusense-flyduino
Gaza post 900
Heres a picture of how I wired mine I have tried it with the mutiwii code and every thing appears to be working.....
tks for your pic showing how you connected allinone-flydusense-flyduino.
Until I receive the boards I ordered (same as yrs, except my Flydusense which will be with LLC),
I try to gather all infos I will need to make my connections.
I suppose the connection between Flydusense (with or without LLC) and Flyduino
should be exactly the same as shown on yr picture?
But what about connection Allinone5vLLC=>FyldusenseLLC?
Can I connect them also as shown on yr picture?
If not, what would be the difference?
Gaza or Goofy can you pls inform?
Reproducing same picture showing differences of connections, if any, (for instance with green arrows) would be nice.
(as Napoleon said a good picture is better than a long talk)
sorry for Napo, I'am french, nobody is perfect
apache74 is offline Find More Posts by apache74
Old Jun 09, 2011, 06:16 PM
Goofy23 is offline
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
You can connect your Allinone like Gaza showed in the picture, he seems to have one too with a llc onboard.
I would do it too this way.
If you take the outputs with llc out the signal will go through 2 llcīs, its nothing wrong with it, but its not needed.
The difference between the pictures is, i took the llc out he took the direct way, there is no electronics involved just simple wires, if you connect direct, connect scl sda gnd and 5V (i asume the allinoe 5V have a onboard regulator) and you are ready to go.
Old Jun 10, 2011, 07:06 AM
Goofy23 is offline
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
For all who want to try the camera servos on 44-46 with the multiwii soft.
Mariano and Alex helped out, thanks guys!
PIN 44
pinMode(44,OUTPUT);
PORTL |= 1<<5;
PORTL |= 1<<5;
PIN 45
pinMode(45,OUTPUT);
PORTL |= 1<<4;
PORTL |= 1<<4;
PIN 46
pinMode(46,OUTPUT);
PORTL |= 1<<3;
PORTL |= 1<<3;
This is a link with a modified version, its preset for the FFIMU and QuadX
http://www.file-upload.net/download-...dMEGA.zip.html
The upcoming Multiwii soft will have this mod allready in to it, its just for now, for the guys who want to try a gimbal on the 44-46 pins and the flyduino.
Old Jun 10, 2011, 09:53 AM
M4d_D is offline
Find More Posts by M4d_D
M4d_D's Avatar
Joined Dec 2006
hi ,
little update on my octo. after the crash i changed the electronics and i completely rebuilt the frame .
i just maidened it .
its now equipped with paul's flyduino, jussi's ff imu and alex' new multiwii developer octo software .
it flies really great. its so incredibly stable i couldnt believe what i saw .
a big thanks to all three and to every other coder
pics and vid will follow.
cheers
p.s. definitely as good as a mikrokopter now
M4d_D is offline Find More Posts by M4d_D
Old Jun 10, 2011, 11:23 AM
OS Sponsor
kinderkram's Avatar
Joined Jun 2010
Originally Posted by M4d_D View Post
hi ,
cheers
Congratz!
Looking forward to your vids!
Old Jun 10, 2011, 11:36 AM
hubibubi is offline
Find More Posts by hubibubi
hubibubi's Avatar
Deutschland, SA
Joined May 2011
http://www.file-upload.net/download-...inmod.zip.html
oh Paul, thats a Error in your zip.
It's for ProMini changed, not for Mega!
Greetings hubibubi
hubibubi is offline Find More Posts by hubibubi
Old Jun 10, 2011, 11:47 AM
3rdeyepro is offline
Find More Posts by 3rdeyepro
Hovership
3rdeyepro's Avatar
United States, CA, Cupertino
Joined Aug 2010
hi ,
cheers
I have a quad running the freeflight with a pro mini for now. It is REALLY stable as well. I have flown an MK before and I really think this is close. Making some video when I go to the field tomorrow.
3rdeyepro is offline Find More Posts by 3rdeyepro
Old Jun 10, 2011, 12:16 PM
x4FF3 is offline
Find More Posts by x4FF3
Germany
Joined Mar 2011
paul you got my pm?
greetings david
x4FF3 is offline Find More Posts by x4FF3
New Product Please let me introduce myself jimaquo Dock Talk 7 Oct 27, 2010 02:27 AM
Let me introduce the DEMON!!!! (Transparent covering and eliptical wing!!!) modest-master Sport Planes 7 Aug 25, 2002 11:46 PM
Let me introduce Angelis 280/400, Benjamin, Zombi (ARFs) modest-master Parkflyers 17 Mar 14, 2002 01:20 PM
Let me introduce the "NIKE" modest-master Electric Sailplanes 3 Mar 07, 2002 05:20 AM
