Old Jun 04, 2011, 03:01 PM
Tahoe Ed is online now
Find More Posts by Tahoe Ed
DJI Support
Las Vegas/Lake Tahoe
Joined Feb 2010
Paul thanks to you, Berkely and Oleg for getting these diagrams out to everyone. It is much appreciated.
Tahoe Ed is online now Find More Posts by Tahoe Ed
Site Sponsor
Old Jun 04, 2011, 03:12 PM
M4d_D is offline
Find More Posts by M4d_D
M4d_D's Avatar
Joined Dec 2006
hi, would anyone please post a picture on which i can see every cable ? the schematics dont tell me very much and i really dnt want to fry anything here .
i use the flyduino , the sensor bob and jussis ff imu ....
on this picture the arrow goes the other way than on my flydusense 1.1 , which one is wrong now ? or did someone change it in the code ?
cheers
M4d_D is offline Find More Posts by M4d_D
Old Jun 04, 2011, 03:52 PM
kinderkram is offline
Find More Posts by kinderkram
OS Sponsor
kinderkram's Avatar
Germany, NRW, Dusseldorf
Joined Jun 2010
cheers
It's been said before:
- the big arrow on v1 is pointing to the right. The X-arrow is pointing to the real front (left on this image) and the pins of the FFIMU should point to the back. It's been corrected on v1.1
- the sensor board/shield has to be either powered by 5V or 3,3V, not both
- you can connect the FFIMU 1.22L directly to the 5V pin in the I2C connectors row
Since Paul wanted to create a shield that fits the needs of different MultiWii, AeroQuad and MegaPirate sensors you'll find more connections than usually needed.
kinderkram is offline Find More Posts by kinderkram
Old Jun 04, 2011, 03:56 PM
M4d_D is offline
M4d_D's Avatar
Joined Dec 2006
- the big arrow on v1 is pointing to the right. The X-arrow is pointing to the front and the pins of the FFIMU point to the back. It's been corrected on v1.1
on the picture 3.3 and 5v are connected , why ? does it make any difference ? does it damage anything if both are connected ?
Old Jun 04, 2011, 04:24 PM
M4d_D is offline
M4d_D's Avatar
Joined Dec 2006
i just connected 5v now and connected it to the pc . leds are working
the multiwii software on the other hand isnt. lcd cant be defined in the dev version
Code:
MultiWii_dev20110529.cpp: In function 'void LCDprint(uint8_t)':
LCD:11: error: 'PORTE' was not declared in this scope
MultiWii_dev20110529.cpp: In function 'void configureReceiver()':
RX:25: error: 'DDRK' was not declared in this scope
RX:26: error: 'PORTK' was not declared in this scope
MultiWii_dev20110529.cpp: In function 'void __vector_5()':
RX:51: error: 'PINK' was not declared in this scope
Old Jun 04, 2011, 05:00 PM
Goofy23 is offline
Find More Posts by Goofy23
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
i only connected it to take a regular 3 pin connector, you dont need the 3.3V, sorry, but they dont disturb.
Goofy23 is offline Find More Posts by Goofy23
Old Jun 04, 2011, 05:53 PM
M4d_D is offline
M4d_D's Avatar
Joined Dec 2006
okay , it seems to power up when connected to pc , i was able to upload the multiwii software and the gyros dont seem to work , at least they dont work in the gui , any idea there ?
Old Jun 04, 2011, 06:39 PM
3rdeyepro is offline
Find More Posts by 3rdeyepro
Hovership
3rdeyepro's Avatar
United States, CA, Cupertino
Joined Aug 2010
You need power from an ESC in addition to having the FTDI power. The sensors won't read proper in the gui without power from an ESC.
3rdeyepro is offline Find More Posts by 3rdeyepro
Old Jun 04, 2011, 07:31 PM
Gaza07 is offline
Find More Posts by Gaza07
Gaza07's Avatar
United Kingdom, England, Nottingham
Joined Nov 2002
I read on another thread for a different board that if you power the board with 5v from an external source than you should not connect the 5v rail from the FTDI,
I made a little adapter with the 5v rail removed there are pictures below altho it says 3v3 on the FTDI it is the 5v version,
Is this the case with the Flyduino board is it better to remove the 5v rail from the FTDI when powering from another source, can it damage the FTDI if you do connect both,
I have always used my little adapter to be safe rather than sorry
Gaza07 is offline Find More Posts by Gaza07
Old Jun 04, 2011, 07:59 PM
whiteturbo is offline
Find More Posts by whiteturbo
Registered MisUser
whiteturbo's Avatar
Bristol UK
Joined Oct 2009
My Bad
whiteturbo is offline Find More Posts by whiteturbo
Old Jun 04, 2011, 08:06 PM
Registered MisUser
whiteturbo's Avatar
Bristol UK
Joined Oct 2009
Thats True of Jussi's Shield but the Flyduino Displays as it should in the Gui with just the USB/FTDI and doesnt need any additional power
Old Jun 04, 2011, 09:24 PM
Hovership
3rdeyepro's Avatar
Joined Aug 2010
Oops sorry.
Old Jun 05, 2011, 06:07 AM
hubibubi is offline
Find More Posts by hubibubi
hubibubi's Avatar
Deutschland, SA
Joined May 2011
have you enabled these lines in the sketch?
/* I2C gyroscope */
#define ITG3200
//#define L3G4200D
/* I2C accelerometer */
//#define ADXL345
//#define BMA020
#define BMA180
//#define NUNCHACK // if you want to use the nunckuk as a standalone I2C ACC without WMP
/* I2C barometer */
#define BMP085
/* I2C magnetometer */
//#define HMC5843
#define HMC5883
hubibubi
hubibubi is offline Find More Posts by hubibubi
Old Jun 05, 2011, 09:45 AM
M4d_D is offline
M4d_D's Avatar
Joined Dec 2006
/* I2C gyroscope */
#define ITG3200
//#define L3G4200D
//#define ADXL345
//#define BMA020
#define BMA180
/* I2C barometer */
#define BMP085
//#define HMC5843
#define HMC5883
hubibubi
yes i have enabled these
Old Jun 05, 2011, 10:29 AM
EnryCorser is offline
Find More Posts by EnryCorser
EnryCorser's Avatar
Italia, Sicilia, Misterbianco
Joined May 2011
finally it flew
Thank you all !!!!
(waiting for jussy IMU and then i'll try Megapirate's code)....
EnryCorser is offline Find More Posts by EnryCorser
New Product Please let me introduce myself jimaquo Dock Talk 7 Oct 27, 2010 03:27 AM
Let me introduce the DEMON!!!! (Transparent covering and eliptical wing!!!) modest-master Sport Planes 7 Aug 26, 2002 12:46 AM
Let me introduce Angelis 280/400, Benjamin, Zombi (ARFs) modest-master Parkflyers 17 Mar 14, 2002 02:20 PM
Let me introduce the "NIKE" modest-master Electric Sailplanes 3 Mar 07, 2002 06:20 AM
