Old Jun 01, 2011, 01:12 PM
3rdeyepro is offline
Find More Posts by 3rdeyepro
Hovership
3rdeyepro's Avatar
United States, CA, Cupertino
Joined Aug 2010
I will test the pins tonight. Can we get an updated diagram? Paul made another that shows where to plug in the servos.
I would like to see a diagram that shows how to connect everything (GPS, FF, Sonar, Servos). Also, the above diagram doesn't point out where to put the jumper if using the BEC. This one from paul also shows the 5v from an ESC going into one of the ISP pins.
3rdeyepro is offline Find More Posts by 3rdeyepro
Old Jun 01, 2011, 01:18 PM
Gaza07 is offline
Find More Posts by Gaza07
Gaza07's Avatar
United Kingdom, England, Nottingham
Joined Nov 2002
My Flyduino has 2 more pins where it says NC in the top right corner of that picture im sure I saw some one elses board with the 2 pins I have on mine shorted out with a jumper and another with just a peice of wire soldered across the holes
Just tested with a multimeter I see now it connects the 1st esc,s bec (2) to the rest of the 5v rail ive put a jumper on mine
Gaza07 is offline Find More Posts by Gaza07
Old Jun 01, 2011, 04:20 PM
Goofy23 is offline
Find More Posts by Goofy23
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
A update is needed, Hogsters on the first page is more up to date, it only miss the 5V Jumper Gaza07 mentinoed above, lets see when i get a nice shematic done, hopefully soon.
Goofy23 is offline Find More Posts by Goofy23
Old Jun 01, 2011, 05:41 PM
Hogster is offline
Find More Posts by Hogster
HeliAP'er!
Hogster's Avatar
Surrey, UK
Joined Aug 2003
If someone wants to scribble on my diagram I will update it when I have a moment
Cheers!
David
Hogster is offline Find More Posts by Hogster
Old Jun 01, 2011, 06:24 PM
Goofy23 is offline
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
Thanks!
A little update.
Old Jun 01, 2011, 06:35 PM
Hovership
3rdeyepro's Avatar
Joined Aug 2010
Awesome, thanks
Old Jun 01, 2011, 10:56 PM
Hovership
3rdeyepro's Avatar
Joined Aug 2010
Just tested the 3,3v and 5v pins in the corner. Nothing
All other 5v pins are reading good except these.
Old Jun 02, 2011, 04:34 AM
hubibubi is offline
Find More Posts by hubibubi
hubibubi's Avatar
Deutschland, SA
Joined May 2011
Wiring Diagram
Hello All,
I have in my post before Paul asked the question after a wiring diagram if he makes this accessible. This would render superfluous the ultimate questions.
@ Paul
A circuit diagram is available to you yet? Is but the first thing you have before designing a layout.
There you will find all connections, each contact is so designated.
It is the symbiosis of Berkley's diagram and in the middle of the Flyduinoboard, wherein said would like a second diagram of the circuit.
If all the connections continue to be drawn about the schema of the layout, it is sometime confusing.
Please show us Paul but the schematic to Flyduino or is it a secret?
thx hubibubi
a german tranlate:
Hallo an Alle,
ich habe in meiner Post Paul schon einmal die Frage nach einem Schaltplan gestellt ob er diesen zugänglich macht. Damit würden sich die letzten Fragen erübrigen.
@Paul
Ein Schaltplan liegt dir doch vor? Ist doch das erste was man hat bevor man ein Layout entwickelt.
Dort findet man alle Verbindungen, jeder Kontakt ist ja bezeichnet.
Es ist die Symbiose aus Berkleys Diagram und in der Mitte dem Flyduinoboard, wobei man wie gesagt ein zweites Diagram der Schaltung hätte.
Sollten alle Anschlüsse weiterhin über das Schema des Layouts gezeichnet werden, wird es irgendwann unübersichtlich.
Bitte Paul zeig uns doch den Schaltplan zum Flyduino oder ist das ein Geheimnis?
thx hubibubi
hubibubi is offline Find More Posts by hubibubi
Old Jun 02, 2011, 05:29 AM
hubibubi is offline
hubibubi's Avatar
Deutschland, SA
Joined May 2011
Originally Posted by Goofy23 View Post
Thanks!
A little update.
Hier sollte der Hinweis stehen, das der ESC vom Regler des Motoranschluß 1 gemeint ist.
Das hattest du Paul schon in einem vorherigen Beitrag geschrieben.
Here, the reference stand, which the ESC is the controller of the motor terminal 1 meant.
Paul you had already written in a previous post.
hubibubi
Old Jun 02, 2011, 05:41 AM
Gaza07 is offline
Gaza07's Avatar
Joined Nov 2002
Putting the jumper on those 2 pins will make the bec from motor 1 active for the 5v rail and power the board without the jumper it will not
German
Inbetriebnahme der Jumper auf den 2 Pins wird das BEC von Motor 1 aktiv für die 5V Schiene und Leistung der Platine machen, ohne die Brücke wird es nicht
Old Jun 02, 2011, 05:49 AM
hubibubi is offline
hubibubi's Avatar
Deutschland, SA
Joined May 2011
German
Genau das hab ich auch geschrieben.
Aber das sollte dann auch als Hinweis im Schema stehen.
Schönen Himmelfahrtstag hubibubi
That's what I've written.
But that should then also be an indication in the schema.
Fine Fahter's Day hubibubi
Old Jun 02, 2011, 05:53 AM
Gaza07 is offline
Gaza07's Avatar
Joined Nov 2002
Oh I see I thought you wanted to confirm it oops sorry
And a fine fathers day to you too
Oh, ich sehe ich dachte, du wolltest es zu bestätigen oops sorry
Und ein feines Väter Tag auf Sie zu
Old Jun 02, 2011, 05:58 AM
hubibubi is offline
hubibubi's Avatar
Deutschland, SA
Joined May 2011
- Pin 13 sollte die LED für die Statuskontrolle sein gegen Masse.
- Pin 12 sollte gemäß Software ein schaltbarer Pin sein, beim anderen Diagrammen zum Aktivieren/Deaktivieren des WMP.
- Bei Pin 0 steht On/Off LCD, aber wie? da muß ich mich noch in die Software einlesen. Oder kennt jemand die Lösung?
- Pin 30, Leiste hinter den Eingängen der TX, ist der Anschluß für den Buzzer
- Pin 31 über Widerstand an LED für LiPo Alarm und
- Pin 33 ein zweites Servo
- Pin 13, the LED for status monitoring be to ground.
- Pin 12 should be in accordance with a switchable software Pin at the other diagrams to enable / disable the WMP.
- When is pin 0 on / off LCD, but how? because I must have read in the Software. Or someone knows the solution?
- Pin 30, block behind the inputs of the TX, is the connection for the buzzer
- Pin 31 via resistor to LED for alarm LiPo
- Pin 33, a second servo
hubibubi
Old Jun 02, 2011, 06:10 AM
JUERGEN_ is offline
Find More Posts by JUERGEN_
xxxxxxxxxxxxx
JUERGEN_'s Avatar
Deutschland
Joined Nov 2009
das ist genau wie das HobbyKing Quadcopter control,
alles top secret
wo bleibt dann sonst der spass am knobeln ?
JUERGEN_ is offline Find More Posts by JUERGEN_
Old Jun 02, 2011, 06:54 AM
hubibubi is offline
hubibubi's Avatar
Deutschland, SA
Joined May 2011
alles top secret
Versteh ich nicht ganz denn soviel ist nicht dran, ist nur lästig für Jeden entweder unter der Lupe das Layout nachzuverfolgen oder mit dem Multimeter mir selbst die Schaltung nah zu bringen.
Ist nix mit Open Hardware?
Für jene die im 'Stoff' stehen vielleicht egal, aber Anfänger wie ich wollen nicht unbedingt das Board schießen, bloß weil die Dokumentation zu den Pins nicht offen gelegt werden soll, mmhhh.
Knobeln schön und gut, ist ja 'günstig' das Board, kostet ja sozusagen nix???
Und die Angeschlossenen Teile bekomme ich ja auch gratis!
Ein LiPo 3S2000 macht ja auch nur ein 'paar Amperchen', buff und wech.
Ok, die vielen Pin's sind einfach nicht schlüssig erklärt, es kommen immer wieder Fragen auf.
Würde mich über konstruktivere Erklärungen freuen.
Nicht böse gemeint @Jürgen_
I do not quite understand: confused: because so much is not, but is just annoying for everyone either under the microscope to track the layout or to the multi-meter to bring myself to close the circuit.
If nothing with Open Hardware?
For those in the 'fabric' are perhaps not care, but beginners as I do not necessarily want the board to shoot, just because the documentation to the pins should not be disclosed, mmhhh.
Toss well and good, is so 'cheap' the board, it costs nothing, so to speak?
And the connected parts can I get free, too!
A 3S2000 LiPo does indeed only a 'few Amperchen', buff and then turned.
Ok, the many pin's just not conclusively explained, there are always questions.
Would appreciate any constructive statements.
Not bad meant @ Jürgen_
thx hubibubi
New Product Please let me introduce myself jimaquo Dock Talk 7 Oct 27, 2010 02:27 AM
Let me introduce the DEMON!!!! (Transparent covering and eliptical wing!!!) modest-master Sport Planes 7 Aug 25, 2002 11:46 PM
Let me introduce Angelis 280/400, Benjamin, Zombi (ARFs) modest-master Parkflyers 17 Mar 14, 2002 01:20 PM
Let me introduce the "NIKE" modest-master Electric Sailplanes 3 Mar 07, 2002 05:20 AM
