Old May 30, 2011, 02:28 PM
hubibubi is offline
Find More Posts by hubibubi
hubibubi's Avatar
Deutschland, SA
Joined May 2011
Beginner Question
thx Paul for your Answer.
Code:
Otherwise i would pullout a 5V pin from one ESC and connect it to this BEC Pin, this would be a quite sensefull config.
Thats is.
It would be easier if there were a circuit diagram and not only the layout of the board.
Looks like it would you publish it?
It can be difficult to trace the circuit lines on the black material.
I would therefore like the pin that's looked into the void (BEC pin) lead.
Serial interface on the display I have 5V, GND and RX. RX tentatively associated with TX and RX on the Flyduino, its same effect.
hubibubi is offline Find More Posts by hubibubi
Old May 30, 2011, 03:05 PM
alteskind is offline
Find More Posts by alteskind
Deutschland, Schleswig-Holstein, Kiel
Joined Jan 2011
Originally Posted by hubibubi View Post
Danke für die schnelle Antwort.
@alteskind
Pitchwerte sind 1015 min und 1928 max, Throttle bei 999.
In der TX sind alle Kanäle auf 125% gestellt.
Tranlate
Thanks for the quick reply.
@alteskind
Pitch values ​​are 1015 and 1928 min, max throttle at 999
In the TX all the channels to 125%.
THX hubibubi
ups, hab wohl zuvel sonne abbekommen heute...meine obige antwwort war mangelhaft
hast nen quad oder nen tri?
quad wird mit yaw links, throttle unten ausgeschaltet.
tri mit throttle unten + pitch unten + roll links aussgeschaltet.
someone did a nice sheme
alteskind is offline Find More Posts by alteskind
Old May 30, 2011, 03:39 PM
Goofy23 is offline
Find More Posts by Goofy23
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
Originally Posted by Desaster View Post
HI ,
is this OK ?
http://shop.trenz-electronic.de/cata...?cPath=105_139
based on MediaTek single chip architecture (MediaTek MT3329)
super low power consumption with SMPS (switching mode power supply) and power saving management
acquisition: 30 mA typical
tracking: 24 mA typical
small dimension: 16 x 16 x 6 mm
integrated ceramic GPS antenna
external antenna I/O support; SPDT (single pole, double throw) auto-switching; short-circuit protection
horizontal position accuracy: < 3m CEP (circular error probable 50%) without SA (selective availability)
ultra-high sensitivity: -165 d Bm (reference to GPS chip specification)
L1 frequency, C/A code, 66-channels satellite searching
fix update rate: up to 10Hz
DGPS (WAAS/EGNOS/MSAS/GAGAN)
RTCM support (option)
AGPS support for fast TTFF
multi-path detection and compensation; E-GSM-900 band rejection
magnetic variation support (configurable by customized firmware)
1-PPS support for timing applications
UART (TTL); integrated USB (Windows and Linux drivers)
protocols: NMEA 0183, PMTK, binary, PGTOP (1-sentence)
RoHS, REACH, E911 compliant
As an official GlobalTop distributor, we will be happy to quote a price for your volume order.
Bye
impressive !, we should investigate in this.
I would be glad to integrate this module in the Flyduino system.
Goofy23 is offline Find More Posts by Goofy23
Old May 30, 2011, 04:13 PM
Gaza07 is offline
Find More Posts by Gaza07
Gaza07's Avatar
United Kingdom, England, Nottingham
Joined Nov 2002
In the multiwii code when you arm then the motors spin at what ever you set minimum throttle to, if you want the motors to stop then look for these lines and un-comment as shown I have mine this way because I dont like the motors spinning all the time
/* motors will not spin when the throttle command is in low position
this is an alternative method to stop immediately the motors */
#define MOTOR_STOP
Gaza07 is offline Find More Posts by Gaza07
Old May 30, 2011, 04:57 PM
rvbcrs is online now
Find More Posts by rvbcrs
Joined Dec 2010
Thanks Paul, I got the GPS Bob, I hope to test it out tomorrow!
rvbcrs is online now Find More Posts by rvbcrs
Old May 31, 2011, 02:54 AM
kinderkram is offline
Find More Posts by kinderkram
OS Sponsor
kinderkram's Avatar
Germany, NRW, Dusseldorf
Joined Jun 2010
Looking good!
Hope you'll have success with the GPS...
Everything else working so far?
kinderkram is offline Find More Posts by kinderkram
Old May 31, 2011, 03:29 AM
hubibubi is offline
hubibubi's Avatar
Deutschland, SA
Joined May 2011
@Gaza07,
thx, I've also tested and it is a possibility.
But I will try to take this opportunity once more thing.
/ * this is the value for the ESCs when thay are not armed
in some cases, this value must be lowered down to 900 for some specific ESCs * /
# define MINCOMMAND 1000
/ * this is the maximum value for the ESCs at full power
this value can be Increased up to 2000 * /
# define MAXTHROTTLE 1850
Greeting hubibubi
Old May 31, 2011, 04:45 AM
Gaza07 is offline
Gaza07's Avatar
Joined Nov 2002
If you scroll further down the sketch you will find the motor stop just un comment it and the motors will stop at zero throttle
@Gaza07,
Greeting hubibubi
Old May 31, 2011, 05:44 AM
Joined Dec 2010
Originally Posted by kinderkram View Post
Looking good!
I was not able to test anything GPS related, because I don't know how to set the pos_hold, I'm going to try to go outside today to test the B8+ firmware, but the weather is very bad! damn rain!
On thing I also want is the Camera outputs working for my Gimbal, but I hope Oleg is working on that as we speak
Old May 31, 2011, 07:23 AM
Goofy23 is offline
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
Looking very good, nice stack Ramon.
Hope its all working as expected, cause the GPS thing is very new.
Old May 31, 2011, 10:28 AM
Goofy23 is offline
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
One thing.
I ordered another batch of the Flyduino, this time the 2.0 version.
It will have a slight change in the serials, thats it.
I want to hear your opinion of allready presoldered Pinheaders on it.
I will choose the straight versions for most of them, 3 row angled ones are very expensive.
But what you guys think.
Its good to have presoldered straight pins, or will you more like the freedom of chossing it by yourself?
Old May 31, 2011, 11:12 AM
Gaza07 is offline
Gaza07's Avatar
Joined Nov 2002
I think they would be fine supplied with no pins soldered in, also im not a big fan of the angled ones
Old May 31, 2011, 11:31 AM
Goofy23 is offline
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
oh btw, i got 2 new ftdi´s, the new SF version.
Fits perfect even better then the old one!!
Old May 31, 2011, 11:39 AM
whiteturbo is offline
Find More Posts by whiteturbo
Registered MisUser
whiteturbo's Avatar
Bristol UK
Joined Oct 2009
Originally Posted by Goofy23 View Post
One thing.
Although my eyesight isnt as good as it used to be i still prefere to solder my own pinheaders, but i can see some people would like the presoldered option so how about giving the choice of either way. As far as angled headers are concerned, i have tryed them and they do reduce hight but at the cost of spreading sideways a bit, i certainly dont think they are worth the extra cost though.
Just my 2P's worth
Ray
whiteturbo is offline Find More Posts by whiteturbo
Old May 31, 2011, 11:44 AM
Goofy23 is offline
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
Your 2P´s are worth a lot Ray.
Yes i also like the option of offering both, but will have sort out a bit how much i will oder with pinheaders and how much without.
New Product Please let me introduce myself jimaquo Dock Talk 7 Oct 27, 2010 02:27 AM
Let me introduce the DEMON!!!! (Transparent covering and eliptical wing!!!) modest-master Sport Planes 7 Aug 25, 2002 11:46 PM
Let me introduce Angelis 280/400, Benjamin, Zombi (ARFs) modest-master Parkflyers 17 Mar 14, 2002 01:20 PM
Let me introduce the "NIKE" modest-master Electric Sailplanes 3 Mar 07, 2002 05:20 AM
