Old May 24, 2011, 06:30 PM
M4d_D is offline
Find More Posts by M4d_D
M4d_D's Avatar
Joined Dec 2006
Originally Posted by helicoblast View Post
Hi M4d_D,
Thanks for your work, I'm really interested by your octo code!
Just a question:
The motors definition at the end of the code lines don't really help to figure out where is which motor...
Could you change them to more "n00b-friendly" definitions, or draw a wiring diagram?
Thanks a lot!
Bastien
here is a picture ,
i think it should be easy to understand what i mean...
now can anyone tell me how to piece the developer code together to programm the flyduino ?`
by the way , did you receive my pm paul ?
without the board it might be difficult to fly
cheers
M4d_D is offline Find More Posts by M4d_D
Old May 24, 2011, 06:32 PM
M4d_D is offline
M4d_D's Avatar
Joined Dec 2006
Originally Posted by kinderkram View Post
Wrong thread guys!
You should ask the coder. Looks like this Octo is set up in X mode.
So looking from the top clockwise front left is the one after left front and right back sits before back right, capiche?
A plus (+) setup with 1 arm pointing to the front would be much clearer...
easy is boring , so we build our stuff ourselves
hope the picture makes it clearer for everyone
Old May 24, 2011, 06:37 PM
MOdesigner is offline
Find More Posts by MOdesigner
MOdesigner's Avatar
USA, MO, Smithville
Joined Oct 2008
Bridge for PPM off D2
Once I figure out if the MultiWii1_7 code will support PPM on my dragonlink reciever I want to make sure I've got the bridging that warthox did to get PPM out of D2. I saw his pictures and it looks like the bridge goes from +vcc-->middle pin of D5---->middle pin of D2. Can someone tell me if this is right?
Respectfully posted,
Scott
MOdesigner is offline Find More Posts by MOdesigner
Old May 24, 2011, 07:45 PM
Goofy23 is offline
Find More Posts by Goofy23
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
You dont need the bridge anymore
simply set the jumper for 5V, this will supply your receiver on pin 2, make the changes in the pde according your needs.
If you also want to use the ESC BEC 5V make a bridge from pin 3 to pin2 5V pin, cause your reciever is now on pin2.
Warthox changed pin 2 to 9 and ppm from 19 to 2.
Goofy23 is offline Find More Posts by Goofy23
Old May 24, 2011, 10:37 PM
MOdesigner's Avatar
USA, MO, Smithville
Joined Oct 2008
Thank you sir. After I do this it'll be back off to the Multiwii thread to figure out how to change pde.
R/P
Scott
Old May 25, 2011, 06:36 AM
SeismicCWave is offline
Find More Posts by SeismicCWave
Hawaii
Joined Feb 2003
What is the best way to power the Flyduino board?
Thank you very much.
SeismicCWave is offline Find More Posts by SeismicCWave
Old May 25, 2011, 07:22 AM
Hogster is offline
Find More Posts by Hogster
HeliAP'er!
Hogster's Avatar
Surrey, UK
Joined Aug 2003
I believe you can either power it using a 3 or 4-cell LiPo (this could be your flight pack), or you can feed 5V directly into the pad at the bottom, as shown in this diagram:
As to which is the 'best' ... I don't know ... running from an external 5V source will mean the onboard linear 5V regulator won't be running, so won't get warm / hot ... (correct?)
Cheers
David
Hogster is offline Find More Posts by Hogster
Old May 25, 2011, 08:41 AM
Goofy23 is offline
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
Absolutely correct, but to suplly the cpu and some sensors shouldnt be a problem for the onboard reg.
I still think for a low power device like the flyduino is a lienar regulator is the way to go.
Switching supplys can be troublesome, can, dont have to.
There are quite a lot powering options, easiest is to take a BEC 5V or the onboard regulator, but a external switching supply should work too.
Old May 25, 2011, 12:20 PM
chrisez is offline
Find More Posts by chrisez
Romania, Bucuresti, Bucuresti
Joined May 2011
We received the Flyduino last week and have since connected WMP+ and Nunchuk. MultiWii uploaded to the board OK but we're still waiting on delivery for ESCs and motors so we can't build the full quad yet.
I'd like to know what we should expect to see on screen with Flyduino connected to the computer via FTDI.
I mean if I move one of the sensors should the change be visible in MultiWii Conf?
Thanks!
Chris
chrisez is offline Find More Posts by chrisez
Old May 25, 2011, 12:42 PM
alteskind is offline
Find More Posts by alteskind
Deutschland, Schleswig-Holstein, Kiel
Joined Jan 2011
Thanks!
Chris
yes.
dont forget to click "start" in gui
alteskind is offline Find More Posts by alteskind
Old May 25, 2011, 01:29 PM
Hawaii
Joined Feb 2003
Cheers
David
Thank you David. I found the the image very helpful.
Old May 25, 2011, 01:54 PM
Hogster is offline
HeliAP'er!
Hogster's Avatar
Surrey, UK
Joined Aug 2003
Fair point Paul I was struggling to find a reason why there might be an advantage to using an external regulator
The current draw will be so low that very little power will have to be dropped across the regulator = very little heat would be produced ...
Cheers
David
Old May 25, 2011, 02:00 PM
Goofy23 is offline
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
New Toys in the shop
www.flyduino.com
Old May 25, 2011, 03:32 PM
Hawaii
Joined Feb 2003
I got the Flyduino working on the quad finally. It was with the GUI all this time. I just never hooked it up to a real quad because of the sensor mounting issue.
So I just took a WMP board and stuck it to the bottom of the Flyduino board instead of using another sensor BOB.
Test flights shows that it flies like any other controller using the WMP sensor.
What other 3 axis are there that is good for the Flyduino board? Any recommendations? I have tried the ITG3200 on a couple other Wii controller board and I don't like it.
Thanks in advance for any suggestions.
Old May 25, 2011, 05:36 PM
Hogster is offline
HeliAP'er!
Hogster's Avatar
Surrey, UK
Joined Aug 2003
www.flyduino.com
Ohhh I want mine in black now
Looking really great Paul! Well done for all your hard work!
David
New Product Please let me introduce myself jimaquo Dock Talk 7 Oct 27, 2010 03:27 AM
Let me introduce the DEMON!!!! (Transparent covering and eliptical wing!!!) modest-master Sport Planes 7 Aug 26, 2002 12:46 AM
Let me introduce Angelis 280/400, Benjamin, Zombi (ARFs) modest-master Parkflyers 17 Mar 14, 2002 02:20 PM
Let me introduce the "NIKE" modest-master Electric Sailplanes 3 Mar 07, 2002 06:20 AM
