Old May 19, 2011, 12:06 PM
aadamson is offline
Find More Posts by aadamson
United States, GA, Atlanta
Joined Dec 2010
Paul,
Any chance of getting an eagle file of the hole placement only (not sure if the design is open hardware or not?).... I'm interesting in doing a plug in shield type board to mate directly to some of the pins?
if your design isn't open hardware, thats ok, if you could do a library or something with the outline and pin placement, that's all I need.
Alan
aadamson is offline Find More Posts by aadamson
Old May 19, 2011, 12:13 PM
EnryCorser is offline
Find More Posts by EnryCorser
EnryCorser's Avatar
Italia, Sicilia, Misterbianco
Joined May 2011
arrived yesterday! Thanks Paul!
Just one question ....
I order a FreeIMU 0.3.1 from Fabio Varesano, but it take some days before arriving.
In the meantime can i use Flyduino +WMP and a Nunchuk instead of BMA020?
EnryCorser is offline Find More Posts by EnryCorser
Old May 19, 2011, 12:34 PM
JussiH is offline
Find More Posts by JussiH
Friend is a 4 letter word...
JussiH's Avatar
3rd stone from the sun
Joined May 2007
Originally Posted by axelnied View Post
Paul,
Any update on if/how to connect Spektrum satellites to the flyduino?
I read something earlier in this thread, but no final conclusion (at least not for me)!
This would require a lot less cables. Are there also any plans to provide a more detailed description on connections/setup for the beginner(s).
Let me up the stakes on that one.....
I will give a FF IMU to the person who comes up with a way to read Spektrum Sats into MultiWii and MegaPirates via serial into a Flyduino or Arduino Mega.
An absolute succes criterium is minimum 9 channels in....(I have a X9303)
Jussi
JussiH is offline Find More Posts by JussiH
Old May 19, 2011, 01:03 PM
kinderkram is offline
Find More Posts by kinderkram
OS Sponsor
kinderkram's Avatar
Germany, NRW, Dusseldorf
Joined Jun 2010
Jussi
Send it to Oleg. He will do.
kinderkram is offline Find More Posts by kinderkram
Old May 19, 2011, 01:28 PM
flye is offline
Find More Posts by flye
Joined Sep 2010
Hi,where can I get usb wire for flyduino?
flye is offline Find More Posts by flye
Old May 19, 2011, 01:35 PM
alteskind is offline
Find More Posts by alteskind
Deutschland, Schleswig-Holstein, Kiel
Joined Jan 2011
f.e. there http://www.dfrobot.com/index.php?rou...product_id=147
link edited
alteskind is offline Find More Posts by alteskind
Old May 19, 2011, 01:42 PM
flye is offline
Joined Sep 2010
Originally Posted by alteskind View Post
Thanks but your link don't work
Old May 19, 2011, 02:24 PM
Goofy23 is offline
Find More Posts by Goofy23
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
EnryCorser, yes of course you can use it in the meantime.
There will be more documentation in future, but my to do list is still full with things and of course regular work involves a lot of time atm.
To burn multiwii soft you need a reglar 5V FTDI.
The PPM in can be achieved by switching motor 2 to 9 and ppm from 19 to 2.
I am working on a more comfortable solution.
Goofy23 is offline Find More Posts by Goofy23
Old May 19, 2011, 02:48 PM
Joined Jan 2011
try this one http://www.dfrobot.com/index.php?rou...product_id=147
same i am using with flyduino - works fine
Old May 19, 2011, 02:57 PM
braindead4554 is offline
Find More Posts by braindead4554
Multicopter Addict
braindead4554's Avatar
Southwest Minnesota
Joined Feb 2010
Originally Posted by aadamson View Post
Paul,
Alan
I'm curious as to why your goin around asking everyone for their eagle files on their projects. What are you doing with them?
braindead4554 is offline Find More Posts by braindead4554
Old May 19, 2011, 06:55 PM
itod is offline
Find More Posts by itod
Joined Sep 2010
I bet he is doing something weird, like learning something from them
itod is offline Find More Posts by itod
Old May 19, 2011, 07:51 PM
aadamson is offline
Joined Dec 2010
yeah, its curious isn't it... I buy the products and would like board level documentation... what a novel concept
Actually, what I'd like to do is design and 328P board to mate to this, one that might be a dedicated AHRS/sensor fusion/GPS board. In order to do that I'd like to make sure I have header spacing correct.
But Paul came to my rescue he and I are discussing directly in email... so who knows... maybe something will come of it.
He's explained that he's keeping his design non-open source for now, which I totally respect.
As my other request to Jussi which you may have seen as well...
We have an ARM board that we are toying with and I'd like to make sure that we do the sensor part of it right. There are a million different BOB sources that are open, but I really like Jussi's approach and it was open hardware so I figured I'd compare his to ours... Who knows if this project will materialize, but not bad to keep some stuff in the pipeline
No ill intentions, the last thing I need is to do hardware... I'm a software guy and the AQ guys have me pretty consumed at the moment with all the changes we've made to flight control and the AHRS.
Good things on the horizon there soon as well.
But thanks for asking
Alan
Old May 19, 2011, 09:27 PM
Multicopter Addict
Southwest Minnesota
Joined Feb 2010
Alan
Again I was totally curious I just thought it was strange that I saw this in two different threads, so I had to ask to cure my curiousity. That is, after all, how I am able to learn alot. I hope and eagerly look forward to what you will be offering and bring to this wonderful hobby. I too look at board designs just to see how evewrything works together.
Old May 20, 2011, 03:12 AM
OS Sponsor
kinderkram's Avatar
Joined Jun 2010
Alan
Good to see the AeroQuad team getting involved in "our" hardware design. This will even provide more opportunities to use it on different platforms.
Which sensors do you plan for the IMU?
Old May 20, 2011, 11:09 AM
ala42 is offline
Find More Posts by ala42
ala42's Avatar
Germany
Joined Jan 2011
See http://aeroquad.com/showthread.php?3023-New-AQ-PCB for the details and http://aeroquad.com/showthread.php?3...ll=1#post28834 for a better rendered board image.
ala42 is offline Find More Posts by ala42
New Product Please let me introduce myself jimaquo Dock Talk 7 Oct 27, 2010 02:27 AM
Let me introduce the DEMON!!!! (Transparent covering and eliptical wing!!!) modest-master Sport Planes 7 Aug 25, 2002 11:46 PM
Let me introduce Angelis 280/400, Benjamin, Zombi (ARFs) modest-master Parkflyers 17 Mar 14, 2002 01:20 PM
Let me introduce the "NIKE" modest-master Electric Sailplanes 3 Mar 07, 2002 05:20 AM
