Romania, Dolj, Craiova
Joined Sep 2007
Not sure what you mean...
Latest blog entry: JRSky - birth of a dream radio
Joined Aug 2011
Hi guys hel needed
Bought this bluetooth adapter http://www.rctimer.com/index.php?gOo...4&productname= Connected to serial 1 and 3 , I able to connect it to my phone but no data is downloaded. Tried to swap rx- tx with no luck.baud port is 115200 Have I to change something in multiwii code . I make it work in previous multiwii version but i don't remember if changing code is needed UPDATE I am able to retrive data only from serial 0. How can I use serial 1 or 3 ( on 2 I have GPS) |
The Netherlands, NH, Amsterdam
Joined Mar 2008
Doesn't sound like calibration nor MAG issue ![]() Have you increase YAW P already for more yaw authority? You can have it quite high up from my experience. Drift correction would need higher P, slow 'jitters' should need I adjustment if I recall correctly. But no expert on PID-tuning, way to time consuming for my liking ![]() How did you calibrate the MAG? Did you rotate it around all axis during the calibration (flashing status LED)? Was there no magnetic interference from laptop/pc/PSU/cellphone etc? But I don't believe MWC uses MAG for yaw anyway, it utilizes the gyro's. MAG can be enabled (via software or TX switch) to keep pointing front, or to fly 'headless'. Maybe Megapirates combines the gyro and mag readings, but I'm not sure. |
Joined Mar 2008
When starting calibration of MAG the status LED on Flyduino boards start flashing. During this period, rotate the sensor/board/copter full 360 degrees around all 3-axis (X,Y,Z).
Do this as far away from interference (like computers, phones, speakers, display/tv, and other ferro-metal objects) as possible. |
Thank you shufflz
![]() I've a separate switching BEC from hk. This should solve the heat issue but i hope it doesn't introduce much interference with the rc tx and video tx. My flyduino mega or at least one component near the cam servo supply is getting really hot after just a few seconds, even when powered from 5v (or 3.3v?) via USB...is that normal? Thanks in advance |
| Thread Tools | |
| New Product Please let me introduce myself | jimaquo | Dock Talk | 7 | Oct 27, 2010 02:27 AM |
| Let me introduce the DEMON!!!! (Transparent covering and eliptical wing!!!) | modest-master | Sport Planes | 7 | Aug 25, 2002 11:46 PM |
| Let me introduce Angelis 280/400, Benjamin, Zombi (ARFs) | modest-master | Parkflyers | 17 | Mar 14, 2002 01:20 PM |
| Let me introduce the "NIKE" | modest-master | Electric Sailplanes | 3 | Mar 07, 2002 05:20 AM |
