Old Jul 14, 2012, 03:34 PM
Latvia
Joined Oct 2006
Short question: Where to connect bluetooth module?
Guntars is offline Find More Posts by Guntars
Old Jul 14, 2012, 03:42 PM
M4d_D's Avatar
Joined Dec 2006
is there a way to flash the GPS with a MAC ? my win cannot do that and i really do not want to spend any more time trying
M4d_D is offline Find More Posts by M4d_D
Old Jul 15, 2012, 04:03 PM
The Netherlands, NH, Amsterdam
Joined Mar 2008
Guntars; connect the bluetooth to the FTDI port et voila
M4d_D; there should be a Mac-tool around, I think once saw it at the MK forums where I referred to for the alternate tool. Please ask your questions regarding flashing the GPS in the appropriate thread BTW
shufflez is offline Find More Posts by shufflez
Old Jul 15, 2012, 07:25 PM
M4d_D's Avatar
Joined Dec 2006
thx shufflez for that information , you dont happen to have a link there, do you ? . i found this to be the correct thread since it is sold by flyduino and i was under the impression that people are asking questions regarding all the parts that are sold there in this thread , but ok
Old Jul 16, 2012, 04:26 AM
Joined Mar 2008
Hi M4d_D, have just done a quick search through my bookmarks, but don't seem to be able to find it anymore
Of course you can ask the questions here as it's (somewhat ) regarding Flyduino hardware, but for reference it's also good to have all info centralized. Wasn't trying to push you away or anything!
Let me have a look again tonight for the tools for Mac. Mediatek's SDK is only available for Win.
Old Jul 16, 2012, 04:45 AM
Latvia
Joined Oct 2006
Auuuuuu, fried my board (+14 volts instead of +5). Ordered a new one!
shufflez, thank you, but, why not to connect the Bluetooth module to the free serial port?
Old Jul 16, 2012, 04:31 PM
Joined May 2012
Originally Posted by Goofy23 View Post
the new batch is of real good quality really, top notch PCB and pro soldering, CPUs from a official Atmel supplier proffesionally preprogrammed here in Germany
So that's why the new one doesnt have the ISP pins presoldered on
I noticed It is nice!
Mind if I send in language corrections when I see some are needed?
Trenjeska is offline Find More Posts by Trenjeska
Old Jul 16, 2012, 05:51 PM
M4d_D's Avatar
Joined Dec 2006
which battery is used in the gps bob ? which voltage do i need there ? does it have any effect on the gps itself if i use the wrong battery ? i managed to flash the gps now after a few hours of trial and error and the multiwiii gui shows that it is connected but if i choose a swich and try to activate the gps the box does not turn green like all other sensors do when i activate them with the radio
Old Jul 17, 2012, 04:00 PM
Joined Mar 2008
Guntars; i believe bluetooth needs the RTS/CTS mechanism for communication with the board. Maybe even DTR is required, but not sure about that. I don't think this isn't implemented in the Multiwii software serial protocol, but a part of 'basic' Arduino communication.
But I might be entirely wrong, please check the Multiwii-gods over at that thread
M4d_D: I just went to the supermarket and got a CR2025 buttoncell 3V Lithium battery. 3V seemed safe because it runs on that, mine's empty already anyway Several pages back in this thread Paul (Goofy23) commented on the necessity of that battery.
Old Jul 18, 2012, 03:34 PM
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
we got the Microwii
http://flyduino.net/MicroWii-ATmega3...OF-MultiWii-FC
more instructions will follow, but its avaiable from now.
Goofy23 is offline Find More Posts by Goofy23
Old Jul 19, 2012, 06:16 AM
Joined Jul 2011
we got the Microwii
Hi there,
took some time but finally it's available here: http://flyduino.net/NanoWii-ATmega32...-MultiWii-FC_2
The MICROWII 10DOF all-in-one flightcontroller
Here's a short list of it's features:
- based on ATmega32U4 with Leonardo Bootloader
- 10DOF sensor array
- MPU-6050 (GYRO/ACC)
- HMC-5883L (MAG)
- MS5611-01BA01 (BARO)
- Power supplied by 2S to 4S LiPo
- LiPo voltage divider for 2S to 4S, selectable via solder jumper
- Spektrum Satellite support with dedicated connector (on bottom), for standard Spektrum cable
- Bluetooth/GPS connector (on bottom; only GPS or Spektrum can be used at a time since the 32U4 only has one UART)
- optional LED driver for flight mode signalization (footprint on bottom; i.e. with RGB-LED, similar to the DIVIDE et IMPERA! Rev2 board)
- Onboard USB interface; so no need for a FTDI-adapter
- I2C interface for expansions
- High-Speed PWM with 11-bit resolution
- supports all configs up to OKTO with cam-stab support
- 6 receiver inputs
- PPM-Sum signal support
Hope you'll like it!
aBUGSworstnightmare
aBUGSnightmare is offline Find More Posts by aBUGSnightmare
Old Jul 20, 2012, 09:05 PM
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
now also 12A simonK preflashed are aviaibale
http://flyduino.net/Flyduino-12A-ESC-SimonK-Firmware
Very good combination with 32U4 cpu, good HPWM good ESC resolution.
P Values are very not that critlcal now as before.
Old Jul 21, 2012, 06:15 AM
Joined May 2012
we got the Microwii
It looks lovely and has nice specs,but why only six Tx inputs?
I use one aux for changing the tilt of the cam, one for the camtrigger and one tristate to switch flightmodes and even that seemed too few for me, as I was thinking of getting an 8 channel Tx.
Old Jul 21, 2012, 08:30 AM
Stuttgart, BW, Germany
marc von DEE's Avatar
Germany, BW, Durlangen
Joined Apr 2012
Originally Posted by aBUGSnightmare View Post
Hi there,
aBUGSworstnightmare
Hi,
just odered one 2 days ago, im sure i will like it.
one question: is the mix Spektrum + Bluetooth possible?
ciao,
Marc
marc von DEE is offline Find More Posts by marc von DEE
Old Jul 21, 2012, 12:15 PM
Joined Jul 2011
Originally Posted by marc von DEE View Post
Hi,
ciao,
Marc
Hi marc,
sorry, but it's not possible! Since the mega32U4 has only one UART you can use either the Spektrum Sat or a Bluetooth module.
aBUGSworstnightmare
New Product Please let me introduce myself jimaquo Dock Talk 7 Oct 27, 2010 03:27 AM
Let me introduce the DEMON!!!! (Transparent covering and eliptical wing!!!) modest-master Sport Planes 7 Aug 26, 2002 12:46 AM
Let me introduce Angelis 280/400, Benjamin, Zombi (ARFs) modest-master Parkflyers 17 Mar 14, 2002 02:20 PM
Let me introduce the "NIKE" modest-master Electric Sailplanes 3 Mar 07, 2002 06:20 AM
