Old Apr 22, 2012, 02:25 PM
kinderkram is offline
Find More Posts by kinderkram
OS Sponsor
kinderkram's Avatar
Germany, NRW, Dusseldorf
Joined Jun 2010
Originally Posted by zviratko View Post
Sweet! Now I know how you can fit ESCs in there - my 25A are twice the size
What are you flying, multiwii?
Yah, sweet!
On my quad I will mount my ESCs in the left and right chambers between front and rear arms. 1 will be mounted on the lower canter plate, the other one below the top plate. There's plenty of room...
kinderkram is offline Find More Posts by kinderkram
Old Apr 22, 2012, 04:29 PM
x4FF3 is offline
Find More Posts by x4FF3
Germany
Joined Mar 2011
so
my Y6 flies! super smooth and stable with standard multiwii 2.0 PIDs i'm using mpu6050 from flyduino.
x4FF3 is offline Find More Posts by x4FF3
Old Apr 22, 2012, 05:01 PM
zviratko is offline
Find More Posts by zviratko
let's brm together!
Czech Republic, Prague
Joined Nov 2011
x4FF3: am I correct that you have all props and rotations reversed?
zviratko is offline Find More Posts by zviratko
Old Apr 22, 2012, 05:09 PM
x4FF3 is offline
Germany
Joined Mar 2011
nope, they rotate in the correct directions --> http://www.multiwii.com/wp-content/u...28-290x300.jpg
Old Apr 23, 2012, 03:18 AM
sdaudet is offline
Find More Posts by sdaudet
sdaudet's Avatar
France, IdF, Paris
Joined Jan 2011
Originally Posted by x4FF3 View Post
so
Very nice job, i like it
i think i build one with my MT2216
Can you say me What is the size of your arm
i would like use 14" propeller..
thanks
sdaudet is offline Find More Posts by sdaudet
Old Apr 23, 2012, 03:29 AM
zviratko is offline
let's brm together!
Joined Nov 2011
This is mine:
Flyduino Cheese Plate, 34cm arms
Flyduino Mega
Allinone sensors (gyro, acc, baro, mag)
FMP04 5Hz GPS
ESC Turnigy Plush 25A
Turnigy SK3 2826 motors
APC220 telemetry
DYP ME-007 sonar
FrSky D4FR receiver + Turnigy T9x
still didn't fly, I'm fighting with motor pinout on Megapirate for Y6, and had to reverse rotations of motors multiple times....
Tip to all - make the motor wires LONGER with FCP, you do not want to disassemble it completely to reverse motor rotation or change a motor, it's a huge PITA
Old Apr 23, 2012, 03:30 AM
zviratko is offline
let's brm together!
Joined Nov 2011
so
Out of curiosity, what is your AUW?
Old Apr 23, 2012, 02:07 PM
marc von DEE is offline
Find More Posts by marc von DEE
Stuttgart, BW, Germany
marc von DEE's Avatar
Germany, BW, Durlangen
Joined Apr 2012
FCP octo
Hello l'm new here,
Let me introduce myself:
My name is Marc, I work as an engineer for an automotive supplier in Germany, near Stuttgart. I am car enthousiast, and addicted to RC flying for about two decades.
at Christmas, I started to plan a quadcopter, maidenflight was in early february
Setup:
Warthox centerplates 10x10 aluminium booms 4x Suppo 25a esc 4x Suppo A2212/13 1000KV with 1045 props Divide e impera! board with Atmel ATAVRSBIN1 and ATAVRSBPR1 3s 2200 25C zippy, 450mm wingspan (axis centerline) RC: DX8 with AR800 receiver, multiwii 1.8.2
Flight timer at 840g weight: 12 min (Power cut at about 14 and a half minute) maximum flight time 17min. 40sec with a zippy 3s 4000mah (donīt ask about payload...)
Flying nice, and i want more
The plan for a new one was an HEXA with T-Motor MT2216 900KV, but they weren't available. at the end, it becames an OCTOFLATX with 850 wingspan...
FCP Set, 16mm diameter Alumium booms (for the beginning) 8x T-Motor MT3506 650KV with 1245 props 8x Suppo 30A ESC Divide et Impera!V.2 (RGB led are in the pipe...), Bosch BMA020, I2C 3205 Gyro.
i finished the build yesterday by late afternoon (2 AM this morning...), but iīve still got issues with the board: 4 of the motors arenīt running (directly at the ESC: no problem)
i suppose, the script (1.8.2) has to be adapted, or something with the connection schema doesnt match. (multiwii OCTOFLATX)
http://www.multiwii.com/wp-content/u...OFLATX_328.jpg
Dead outputs are on A0, A1, A2 and D12
iīve tried with a Spektrum Satellit at the dedicated port on divide e impera! board, but in this case, no conection at all.
May be you guys could help me fixing that stuff
Cu, marc
marc von DEE is offline Find More Posts by marc von DEE
Old Apr 23, 2012, 03:20 PM
zviratko is offline
let's brm together!
Joined Nov 2011
Sweet machine!!! Huge! (I like huge ))
the frame is DIY? I was looking for something like that, looks unbreakable
Originally Posted by marc von DEE View Post
Hello l'm new here,
Setup:
Cu, marc
Old Apr 23, 2012, 04:08 PM
Joined Apr 2012
Thanks!
Yes, the frame is self-build.
I ordered the other stuff at flyduino, https://flyduino.net/jtl.php
Nice shop by the way
Actually, weight is at 2020g, could be reduced to 1700g with carbon tubes, and without perimeter frame for stiffeness
Old Apr 23, 2012, 04:38 PM
x4FF3 is offline
Germany
Joined Mar 2011
@marc, why aren't you trying multiwii 2.0?
Old Apr 23, 2012, 05:02 PM
Joined Apr 2012
The last time i was lookingfor the 2.0, i only found the 1.9 witch didn't work on my quad.
Will try the 2.0
Old Apr 23, 2012, 06:46 PM
Goofy23 is offline
Find More Posts by Goofy23
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
very cool build Marc!
Have to say so many things changes atm, ahrd to keep up.
Atm we experiment with a gimbal.
Throw a quickly edited video on the web
Its the frist outdoorflight, only thing we did was ballacing the propellers, no magic vib dampenig or something.
May a bit insane config, but we wanted to know.
The hex is very well, very stable, thank you Alex.
Untitled (1 min 40 sec)
Goofy23 is offline Find More Posts by Goofy23
Old Apr 24, 2012, 07:33 AM
zviratko is offline
let's brm together!
Joined Nov 2011
http://vimeo.com/40900015
Cool. Gimbal from you should be a nice addition :-)
Old Apr 24, 2012, 12:09 PM
aBUGSnightmare is offline
Find More Posts by aBUGSnightmare
Joined Jul 2011
Hello l'm new here,
Setup:
Cu, marc
Hi Marc,
nice build!
You should go for the latest V2.0 release which you can find here http://code.google.com/p/multiwii/downloads/list.
The connection scheme is as follows:
Do you have a PPM receiver at hands? The big drawback with the promini is the lack of a second serial port. You will no longer be able to use the GUI or download new firmware one the Spektrum satellite is connected.
So, for the setup procedure you should use a PPM receiver and once everything is working switch to the Spektrum sat.
As far as I remember, there's no Spektrum support in 1.8.2! The first dev that had it was Danal's branch http://code.google.com/p/multiwii/so...1_8%2BSpektrum
aBUGSworstnightmare
aBUGSnightmare is offline Find More Posts by aBUGSnightmare
New Product Please let me introduce myself jimaquo Dock Talk 7 Oct 27, 2010 03:27 AM
Let me introduce the DEMON!!!! (Transparent covering and eliptical wing!!!) modest-master Sport Planes 7 Aug 26, 2002 12:46 AM
Let me introduce Angelis 280/400, Benjamin, Zombi (ARFs) modest-master Parkflyers 17 Mar 14, 2002 02:20 PM
Let me introduce the "NIKE" modest-master Electric Sailplanes 3 Mar 07, 2002 06:20 AM
