Old Mar 26, 2012, 06:48 AM
warthox is offline
Find More Posts by warthox
Joined Aug 2009
Originally Posted by Karsten J. View Post
Hi Warthox,
you mean the "How should be the sensor axis directions"
I´ve checked this... and everything seemed to be ok BUT my MAG doesn´t work.
Only if I turned the MAG 45° and changed the MAG orientation in the config , it worked...
Therefore I asked if the lines has to run in one direction...
Karsten
the lines have to run in the directions as it is described under 'How should be the sensor axis directions', otherwise the orientation/s of your sensor/s respectively the orientation define/s is/are wrong and the copter will not fly properly.
warthox is offline Find More Posts by warthox
Old Mar 26, 2012, 02:39 PM
NaterPin is offline
Find More Posts by NaterPin
Joined Dec 2009
I got the FCP frame from Paul today. Here are a couple pics to start.
It came well pack and all the parts are clean and neatly cut.
The DVD is in there for scale.
NaterPin is offline Find More Posts by NaterPin
Old Mar 26, 2012, 02:57 PM
Karsten J. is offline
Find More Posts by Karsten J.
Germany
Joined Mar 2010
Hey Paul,
where can I connect a Buzzer to the Mega-Board ?
Karsten
Karsten J. is offline Find More Posts by Karsten J.
Old Mar 26, 2012, 03:40 PM
Douwe74 is offline
Find More Posts by Douwe74
Netherlands
Joined Apr 2010
Originally Posted by Goofy23 View Post
Thanks, it took me a while to figure out how it works but here is how I did it:
- Connect the FC to the computer via the USB FTDI adapter
- Connect a LiPo so the Rx and the ESCs also receive power
- Set the throttle on the Tx to max
- Upload the firmware above and wait until the Atmega resets
- You will hear the familiar calibration beeps of the ESCs, wait until they all beeped and then lower the throttle
- Then you will hear the confirmation beeps of the ESCs and tada, finished
Douwe74 is offline Find More Posts by Douwe74
Old Mar 27, 2012, 12:28 AM
aBUGSnightmare is offline
Find More Posts by aBUGSnightmare
Joined Jul 2011
Hi Douwe74,
which Arduino version did you use? I've tested with 0022/0023 and V1.0.
I was able to compile successfully on 0022 and 0023 but unable to download the sketch.
Using V1.0 gives me compiler errors.
Rgds
aBUGSworstnightmare
aBUGSnightmare is offline Find More Posts by aBUGSnightmare
Old Mar 27, 2012, 03:29 PM
Douwe74 is offline
Netherlands
Joined Apr 2010
Originally Posted by aBUGSnightmare View Post
Hi Douwe74,
Rgds
aBUGSworstnightmare
I used the 0023 version of Arduino.
Concerning your problem, you probably already checked multiple times that you selected the correct board type? What kind of error do you get?
Old Mar 27, 2012, 05:06 PM
olaf.j is offline
Find More Posts by olaf.j
Joined Aug 2011
MultiWii 2.0 and AUX3/AUX4
Hi,
if I want to use the AUX3 and AUX4 with the new MultiWii 2.0 - which pins of the flyudino mega board have I to connect with my receiver? I cannot find it here:
http://api.viglink.com/api/click?for...13328860540633
I think, that the pins 14 and 15 are used for AUX3 and AUX4 (old CAM pitch and CAM roll), but I'm not totally sure . Can someone confirm this (or correct me)?
Olaf.
olaf.j is offline Find More Posts by olaf.j
Old Mar 28, 2012, 12:32 AM
tevion4670 is offline
Find More Posts by tevion4670
Deutschland, BW, Muggensturm
Joined May 2011
hi olaf, maybe aux3 and aux4 only over ppm-sum?
alex
edit
found it !
New AUX3/AUX4 checkboxes.
We can now have many more possibilities to activate/deactivate
a specific function (4 switch with 3 states assuming you have a 8 channels RC system)
The previous CAM1/CAM2 rc channels (that are now AUX3/AUX4) are still usable
for an assisted PITCH/ROLL gimbal system if the AUX3/AUX4 checkboxes are not used.
tevion4670 is offline Find More Posts by tevion4670
Old Mar 28, 2012, 05:34 AM
olaf.j is offline
Joined Aug 2011
Originally Posted by tevion4670 View Post
The previous CAM1/CAM2 rc channels (that are now AUX3/AUX4)[/COLOR] are still usable for an assisted PITCH/ROLL gimbal system if the AUX3/AUX4 checkboxes are not used.
Thank you, that's what I hoped
Old Mar 31, 2012, 09:40 AM
Goofy23 is offline
Find More Posts by Goofy23
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
Hey Paul,
Karsten
Lipo Alarm, please have a look in the shematic on the first page.
Goofy23 is offline Find More Posts by Goofy23
Old Apr 01, 2012, 12:51 AM
Flyrobot is offline
Find More Posts by Flyrobot
youtube.com/#/user/flyrobots
Indonesia
Joined Apr 2011
GPS FMP04 with GPS bob to Flyduino 2.1 connection
Hi,
I m trying to make the GPS working on MWC sw ver 2.0 but no luck until now. I have tried to connect Tx-Tx Rx-Rx and viceversa Tx-Rx (i also follow this http://radio-commande.com/wp-content...a/img_1979.jpg) and i change the baud rate 115200 and 38400 also didn't work.
maybe i missing something ? i appreciate anyone can give suggestion.
john
Flyrobot is offline Find More Posts by Flyrobot
Old Apr 01, 2012, 06:10 AM
Joined May 2011
hi john,
had the same problem. used my ftdi directly connectet to the gps-shield to update the gps-firmware. after that the gps workt whith the 38400 baud setting. i used the mediatec flashtool
alex
Old Apr 01, 2012, 08:30 AM
Flyrobot is offline
Indonesia
Joined Apr 2011
hi john,
alex
Hi Alex,
Thank you for the info. This step i never try it. I will try now.
John
Old Apr 01, 2012, 09:22 AM
Flyrobot is offline
Indonesia
Joined Apr 2011
Hi Alex,
I am trying to search the GPS lates firmware on this (http://www.f-tech.com.tw/modules/mydownloads/) but none of firmware download, could you appoint me the firmware download?
Thanks.
john
Old Apr 01, 2012, 10:25 AM
Flyrobot is offline
Indonesia
Joined Apr 2011
Hi Alex,
Thanks I update it and now its working.
John
New Product Please let me introduce myself jimaquo Dock Talk 7 Oct 27, 2010 02:27 AM
Let me introduce the DEMON!!!! (Transparent covering and eliptical wing!!!) modest-master Sport Planes 7 Aug 25, 2002 11:46 PM
Let me introduce Angelis 280/400, Benjamin, Zombi (ARFs) modest-master Parkflyers 17 Mar 14, 2002 01:20 PM
Let me introduce the "NIKE" modest-master Electric Sailplanes 3 Mar 07, 2002 05:20 AM
