Old Jan 15, 2012, 05:26 PM
Jessestr is offline
Find More Posts by Jessestr
BelgiŽ, Vlaams Gewest, Evergem
Joined Nov 2011
Originally Posted by whiteturbo View Post
Did you see the Guy picking up the bits after the first crash? He didnt look as happy as the rest. I recon it was his heli
Heli's are brilliant, or at least i think mine are, until they crash and it costs a weeks money to repair. So i prefer flying my Quads, it looks like i know what i am doing and even big crashes only cost a prop or two and a bit of epoxy.
Ray
Indeed. Quad's are awesome!
Jessestr is offline Find More Posts by Jessestr
Old Jan 16, 2012, 06:45 AM
Goofy23 is offline
Find More Posts by Goofy23
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
been some days of, try to arrange quite a lot new stuff
got some new nice Megas, allready in the shop.
Jesse you can also scartch some paintbeside the pad and use that as a pad.
I would suggest use a Multimeter and check for a Short before using them!
Thats the most important you can also follow the + and - with this tool easily.
Thanks for helping me out.
Goofy23 is offline Find More Posts by Goofy23
Old Jan 16, 2012, 11:37 AM
Jessestr is offline
Joined Nov 2011
I'll try to do that, but I'll just get a new one too Cause It's not that safe to use that. But I'll try.
I'm very happy that I can support you with buying the stuff so I don't mind to get a new one.
Thanks Paul!
Old Jan 16, 2012, 05:46 PM
Formix is offline
Find More Posts by Formix
Joined Jan 2012
Hello guys, Iīm new and I have couple questions. My equipment is Flyduino Mega board, Drotek's 10DOF LLC and FMP04 GPS Modul on Flyduino FMP04 GPS Bob
1) Is the Drotek's 10DOF LLC board supported by the megapirates code?
2) Multiwii code supported GPS?
My Drotek's 10DOF LLC with Multiwii code working very well bud doesnť work GPS, so, I donīt know where is the problem. I try change tx-tx, rx-rx to tx-rx, rx-tx bud nothing change. Code is
#define GPS
#define GPS_SERIAL Serial2 // should be Serial2 for flyduino v2
//#define GPS_BAUD 4800
#define GPS_BAUD 38400
Formix is offline Find More Posts by Formix
Old Jan 16, 2012, 07:47 PM
Jessestr is offline
Joined Nov 2011
Ordered MT2208's and 10A HobbyWing Flyfun's. Can't wait
Old Jan 17, 2012, 03:01 AM
kinderkram is offline
Find More Posts by kinderkram
OS Sponsor
kinderkram's Avatar
Germany, NRW, Dusseldorf
Joined Jun 2010
Sorry to say but the MP code doesn't support the Drotek yet. Maybe someone can get it working with some tinkering in the code.
And the MW code doesn't have GPS funcionality atm.
I'm afraid you need to wait a bit longer...
kinderkram is offline Find More Posts by kinderkram
Old Jan 17, 2012, 03:46 AM
zviratko is offline
Find More Posts by zviratko
let's brm together!
Czech Republic, Prague
Joined Nov 2011
kinderkram: 10DOF has the same sensors as allinone board, so it shouldn't be a problem. Orientation also looks the same. Only I2C addresses are different which should be very easy to make into a #define
Is there some problem with it I'm not aware about?
zviratko is offline Find More Posts by zviratko
Old Jan 17, 2012, 04:04 AM
OS Sponsor
kinderkram's Avatar
Joined Jun 2010
That's what I meant by "tinkering".
In general the sensors are supported by the MP - someone needs to find the proper orientation and I2C addresses...
Old Jan 17, 2012, 04:12 AM
zviratko is offline
let's brm together!
Joined Nov 2011
the only differences are
IDG3200 address 0xD0 on allinone - 0xD2 on drotek IMU
BMA180 0x82 on allinone - 0x80 on drotek
I don't have the board to test if it is sufficient though...
Old Jan 17, 2012, 10:43 AM
OS Sponsor
kinderkram's Avatar
Joined Jun 2010
Thx!
btw: there's an ongoing discussion about the Drotek 10DOF in the MP thread:
http://www.rcgroups.com/forums/showt...82503&page=183
Old Jan 18, 2012, 01:37 PM
M4d_D is offline
Find More Posts by M4d_D
M4d_D's Avatar
Joined Dec 2006
hi guys ,
after weeks of testing and failing , the flydumini works great now .
- use pauls props ... they are awesome , no more vibrations ( they were one of the many problems i had before
- build as light as possible , mine weighs more than 210g with a 3s lipo , i think its too heavy
i removed the bma completely and instead i put a beeper in which shows me how high my voltage still is ... 1Ah 3s is okay but flies kind of like a truck , 500mAh work okay , voltage drops quite fast but its great for 5 minutes of aerobatics
on 11.1V blue light
11.1V-10.1V blue flash light
the light is flashing after a minute or so
hope this helps someone , if not , im still happy :-)
cheers
how long will it take to get new quad frames in the shop paul ? any ideas ?
M4d_D is offline Find More Posts by M4d_D
Old Jan 18, 2012, 02:14 PM
Goofy23 is offline
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
great result.
Will get some Tiger mini Motors, specially developed for us, should give us a little formula one racer.
i have some problems getting the parts for a new frame, still waiting, but its a nice design, very universal, you will see.
New Quad Centerplates will take till February, sorry to say, new alu arms even longer, but its all on its way.
Old Jan 18, 2012, 02:22 PM
zviratko is offline
let's brm together!
Joined Nov 2011
FIY I got Drotek IMU 10DOF to work with megapirate (more details in megapirate thread), only I2C addresses are different - as expected.
FMP04 GPS has 9600 baud setting by default, this is different source to source so you need to find the right one (I think my datasheet says 19200 default, came with 38400 default, other unit came with 9600 default...)
Old Jan 18, 2012, 02:24 PM
zviratko is offline
let's brm together!
Joined Nov 2011
great result.
Cool. I'll probably need some new flyduspider arms soon so should I rather wait for a new frame? (hope it's octo orr hexa for 10" props! )
Old Jan 18, 2012, 02:42 PM
M4d_D is offline
M4d_D's Avatar
Joined Dec 2006
great result.
NOOOOO , im too lazy to cut the arms myself
the tiger motors sound great though
by the way , im looking for a new transmitter , around 400€ but i would like telemetry and ball bearings on the sticks , which ones do you guys use ?
New Product Please let me introduce myself jimaquo Dock Talk 7 Oct 27, 2010 02:27 AM
Let me introduce the DEMON!!!! (Transparent covering and eliptical wing!!!) modest-master Sport Planes 7 Aug 25, 2002 11:46 PM
Let me introduce Angelis 280/400, Benjamin, Zombi (ARFs) modest-master Parkflyers 17 Mar 14, 2002 01:20 PM
Let me introduce the "NIKE" modest-master Electric Sailplanes 3 Mar 07, 2002 05:20 AM
