Old Dec 07, 2011, 05:30 AM
2.4g shaun is offline
Find More Posts by 2.4g shaun
2.4g shaun's Avatar
United Kingdom, England, West York
Joined Aug 2008
Hi to all fellow Flydumini builders..
I thought it would be interesting to see what are the optimum props for these brilliant quads...
So far I have only used 5x3x3 but as we all know, they can be challenging to balance accurately.. Has anybody any experience of 2 blade replacements that give the similar performance / current draw.
I'm using the Turnigy 1811-2000 motors ( same as the Hextronic 10g) and 2s.
It would also be good to know what the best props for a 3s set up would be..
Cheers,
Shaun (now officially multicopter obsessive )
2.4g shaun is offline Find More Posts by 2.4g shaun
Old Dec 07, 2011, 12:38 PM
kinderkram is offline
Find More Posts by kinderkram
OS Sponsor
kinderkram's Avatar
Germany, NRW, Dusseldorf
Joined Jun 2010
Welcome to multiple addictions!
but you'd better ask your questions in the dedicated FlyduMini thread:
http://www.rcgroups.com/forums/showthread.php?t=1543138
Cheers,
kinderkram is offline Find More Posts by kinderkram
Old Dec 07, 2011, 01:08 PM
2.4g shaun's Avatar
Joined Aug 2008
Will do.. Thanks for the pointer....but as there has been lots of mini-ness in this thread I thought it was a good place to start.
Don't forget we need to encourage Paul to design a Flyduminihex... lets give him and indication of how many people would want one..... Me please...
Shaun
Old Dec 07, 2011, 03:35 PM
treeda is offline
Find More Posts by treeda
Joined Dec 2008
Flyduminispider.... yes gimme gimme
treeda is offline Find More Posts by treeda
Old Dec 07, 2011, 10:14 PM
claustro is offline
Find More Posts by claustro
Joined Aug 2011
Camera?
Hi guys , finally I managed to fly my first quad.
Now I would like to start with the second step , adding a camera.
I am totally nob here , can you confirm me the step required?
1) build or buy something like this with 2 servo ( 3 if I want start and stop filming function)
2) connect the servo on flyduino pitch e roll entry (44 and 45)
and 46 if I want a switch on / off button on camera
3) abilitate on gui camstab and camtrig.
that's all , is that right?
Thank you
Andrea
claustro is offline Find More Posts by claustro
Old Dec 08, 2011, 12:25 PM
OS Sponsor
kinderkram's Avatar
Joined Jun 2010
Yep, that should do.
But on the gimbal you linked you can only attach a small FPV or keychain cam.
Thank you
Andrea
Old Dec 08, 2011, 01:18 PM
Galumbo is offline
Find More Posts by Galumbo
Able to learn fly
Germany, BW, Crailsheim
Joined Aug 2011
Have to sell two new FMP04 GPS modules, such modules you need for Pauls GPS BOB.
Price: 25 + shipping (only in europe)
Please send PM with name + adress + e-mail.
You have to pay via Paypal.
Regrads, Heiko
Galumbo is offline Find More Posts by Galumbo
Old Dec 08, 2011, 01:19 PM
aBUGSnightmare is offline
Find More Posts by aBUGSnightmare
Joined Jul 2011
Thank you
Andrea
Hi Andrea,
have a look at this one http://quadframe.com/collections/fro.../products/g01k
Looks expensive but believe me, it's with it's price!
aBUGSworstnightmare
aBUGSnightmare is offline Find More Posts by aBUGSnightmare
Old Dec 08, 2011, 04:27 PM
claustro is offline
Joined Aug 2011
Originally Posted by aBUGSnightmare View Post
Hi Andrea,
aBUGSworstnightmare
Thank you for you suggestion , it seems sturdy and well build but I am worried for the weight, I have only a quad with dt750 and it weight with battery ( 4A ) 1,250 Kg.
I'll think about it.
Andrea
Old Dec 09, 2011, 07:54 PM
Goofy23 is offline
Find More Posts by Goofy23
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
nice video a friend did from the Flydumini, seems he is on the right track.
FlyduMini Quadrocopter (1 min 44 sec)
Goofy23 is offline Find More Posts by Goofy23
Old Dec 10, 2011, 04:09 PM
olaf.j is offline
Find More Posts by olaf.j
Joined Aug 2011
[QUOTE=flow23;20060161]I'm also building a flydumini and I try to use the ppm with my HK T6A V2 receiver on channel 7[QUOTE]
Not sure, if somebody has answered? Just try it this way:
#define SERIAL_SUM_PPM PITCH,YAW,THROTTLE,ROLL,AUX1,AUX2
But it depends on the channels you used at your er9x-configuration. I used:
channel 1: throttle
channel 2: roll
channel 3: pitch
channel 4: yaw
channel 5: aux 1
channel 6: aux 2
olaf.j is offline Find More Posts by olaf.j
Old Dec 10, 2011, 05:53 PM
olaf.j is offline
Joined Aug 2011
Originally Posted by Drekavac View Post
Yes, two pull-up resistors are needed.
From 5V to SCL and again from 5V to SDA.
Really strange - have the same issue with MultiWii 1.9 - no gyro reaction. If I use 1.8 patch 2, everything is fine. Have no resistors here at the moment to test it. Cannot really understand, why pullup resistors are needed for the one firmware and not for the other...
Old Dec 10, 2011, 06:55 PM
claustro is offline
Joined Aug 2011
Is there a way to add a status led?
I can't see it underneath the sensor board and I'd like to port a small status led outside the electronics cover.
Thank you
Andrea
Old Dec 11, 2011, 10:29 AM
flow23 is offline
Find More Posts by flow23
Deutschland
Joined Jul 2011
[QUOTE=olaf.j;20104854][QUOTE=flow23;20060161]I'm also building a flydumini and I try to use the ppm with my HK T6A V2 receiver on channel 7
channel 1: throttle
channel 2: roll
channel 3: pitch
channel 4: yaw
channel 5: aux 1
channel 6: aux 2
Hi olaf,
I meant to use the sum signal on pin 7 of my receiver. I don't get any output when I try to use it (uncommented line in the code). Using no sum signal works and therefore 1-5pin use works. Can anybody help? Do I need to set up the Eurgle transmitter with er9x differently for using sum signal on pin 7?
flow23 is offline Find More Posts by flow23
Old Dec 11, 2011, 10:45 AM
olaf.j is offline
Joined Aug 2011
Yes, I understood - I also use the battery pin for sum signal with the HK-TR6A V2. Have you connected the battery-pin with the throttle input from the flydumini? What happens in the GUI, when moving the sticks around - nothing, or will the throttle go up sometimes for a few milliseconds?
The description of the channels was because you can change the channel-order - so if you use another channel-order on your transmitter than I use, you have to change line of code. I'm not sure, if it is important, but because it's only a 6 CH-Receiver, I only used the following line:
no CAMPITCH or CAMROLL...
New Product Please let me introduce myself jimaquo Dock Talk 7 Oct 27, 2010 02:27 AM
Let me introduce the DEMON!!!! (Transparent covering and eliptical wing!!!) modest-master Sport Planes 7 Aug 25, 2002 11:46 PM
Let me introduce Angelis 280/400, Benjamin, Zombi (ARFs) modest-master Parkflyers 17 Mar 14, 2002 01:20 PM
Let me introduce the "NIKE" modest-master Electric Sailplanes 3 Mar 07, 2002 05:20 AM
