Old Nov 27, 2011, 07:24 AM
Russia, Moscow
Joined Jan 2011
what is the difference between leistung and schubleistung?
volver is offline Find More Posts by volver
Old Nov 27, 2011, 07:28 AM
Joined Aug 2011
With "El. Leistung" is meant the electrical power, that is consumed by the motors. "Schubleistung" is the effective power, the trust. The difference is neaded to heat the motors
olaf.j is offline Find More Posts by olaf.j
Old Nov 27, 2011, 08:11 AM
Russia, Moscow
Joined Jan 2011
Old Nov 27, 2011, 10:07 AM
QuaDreko pilot :)
Drekavac's Avatar
Slovenia, Kamnik
Joined Oct 2010
Me again.
On the Flydumini, do I need to connect power + signal cables from ESC on D3 or it is not needed?
Is it enough to connect just the signal wires from all ESCs?
I think the board is allready powered, so no need to, but asking anyway.
Drekavac is offline Find More Posts by Drekavac
Old Nov 27, 2011, 10:21 AM
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
one esc is enough, 3 are possible to connect, wont hurt to connect all 3, i take only one.
Goofy23 is offline Find More Posts by Goofy23
Old Nov 27, 2011, 11:19 AM
QuaDreko pilot :)
Drekavac's Avatar
Slovenia, Kamnik
Joined Oct 2010
Great, thanks Goofy!
Old Nov 27, 2011, 11:27 AM
Gaza07's Avatar
United Kingdom, England, Nottingham
Joined Nov 2002
It would appear that sharing your buddy discount codes in the threads you read and use is against the rules so I have had to remove them
Gaza07 is offline Find More Posts by Gaza07
Old Nov 28, 2011, 02:07 PM
let's brm together!
Czech Republic, Prague
Joined Nov 2011
IMO it is wrong to connect all ground and power pins from ESCs in usual "rc" setup, but on flyduino, those pins are not even routed anywhere - right? Unless one bridges the ESC power pin and then it is supposed to power the FC.
Btw when I did this, and connected FC via FTDI/USB, it actually powered the ESCs as well (and my USB is powerful enough to even make a startup melody, ouch - this could burn my USB port I guess)- shouldn't there be a diode instead of a bridge?
zviratko is offline Find More Posts by zviratko
Old Nov 29, 2011, 05:08 AM
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
Yes its only one ESC who powers the Flyduino, if you went that way.
A diode, will lower the Voltage about 0.2V, but yes its a good option there, sure.
With some types of ESC its safer, but i had this problem only one time, when connected the ESC brdige.
I wont burn your USB, the FTDI will burn before.
Old Nov 29, 2011, 05:46 AM
let's brm together!
Joined Nov 2011
Good to know so it is actually expected that bridging ESC to power Flyduino will cause ESCs to be powered by FTDI? I think this should be corrected if you decide to make a new revision of the board...
Old Nov 29, 2011, 03:46 PM
No, it's the same plane ...
jjk77's Avatar
Deutschland, Nordrhein-Westfalen, Bochum
Joined Jul 2010
Originally Posted by zviratko View Post
With MultiWii or some other software? Multiwii reset my PIDs everytime I flashed a new (or different) version, I guess it will not happen when it matures a bit and the eeprom structures are not changed anymore... or when they fix this
It happens often, without flashing MulitWii software to the flyduino.
@Paul: What could be the cause for this? My buddy could only fly one or two batteries, after that he has to reconfigure all PID settings.
jjk77 is offline Find More Posts by jjk77
Old Nov 30, 2011, 04:05 AM
Joined Aug 2011
STUCK need help
Hi all,
I connected all the parts , escs calibrated , uploaded the 1,9 firmware., but it won't work ,the motors don't starts.
I double checked the connection and the software and everything seems ok,
In the gui I have all ( throttle yaw ecc) from 900 to 2100.
when i connect the battery the esc start beeping at fast frequency and one of the motor start to "vibrate".
I made a video of it here http://dl.dropbox.com/u/16215769/vid...0-10-56-28.mp4
esc turnigy plush 30A
motors dt740
sensors bma020 + wm+
radio turnigy er9x
Can someone point me on the right path?
claustro is offline Find More Posts by claustro
Old Nov 30, 2011, 04:39 AM
Deutschland
Joined Nov 2011
[...]Can you someone point me on the right path?
After I synchronized my ESC with a servo-tester instead of the TX/ RX I experienced a similiar problem. I solved it through lowering the following parameter within config.h:
Code:
/* this is the value for the ESCs when they are not armed
   in some cases, this value must be lowered down to 900 for some specific ESCs */
#define MINCOMMAND 900
good luck :-)
zerosight is offline Find More Posts by zerosight
Old Nov 30, 2011, 07:50 AM
Joined Aug 2011
Originally Posted by zerosight View Post
#define MINCOMMAND 900[/CODE]
good luck :-)
Ok i did what you told me and now the motor as still and the esc beep only at start but I still can't arm the motors.
The board has 2 green led on, one of this ( the one near the esc ) blink when I pull all 2 sticks of the rc up.
throttle run between 977 and 2100
yaw from 993 to 2100
pitch 985 to 2100
roll 966 to 2092
any idea where is my mistake?
Old Nov 30, 2011, 10:03 AM
hubibubi's Avatar
Deutschland, SA
Joined May 2011
pitch 985 to 2100
roll 966 to 2092
I think you have to teach-even the gas. How? read a little bit here in the Post's.
hubibubi is offline Find More Posts by hubibubi
New Product Please let me introduce myself jimaquo Dock Talk 7 Oct 27, 2010 02:27 AM
Let me introduce the DEMON!!!! (Transparent covering and eliptical wing!!!) modest-master Sport Planes 7 Aug 25, 2002 11:46 PM
Let me introduce Angelis 280/400, Benjamin, Zombi (ARFs) modest-master Parkflyers 17 Mar 14, 2002 01:20 PM
Let me introduce the "NIKE" modest-master Electric Sailplanes 3 Mar 07, 2002 05:20 AM
