Old Nov 24, 2011, 10:13 AM
olaf.j is offline
Find More Posts by olaf.j
Joined Aug 2011
Flydumini - turnigy plush 10A
Hi,
has anybody tried the flydumini with the turnigy plush 10A-ESC? I'm waiting for the plush 6A at Hobbyking now quite long but they're still not available. But the 10A are available...
But the reviews at HK are not too good
olaf.j is offline Find More Posts by olaf.j
Old Nov 24, 2011, 10:24 AM
nasgul is offline
Find More Posts by nasgul
nasgul's Avatar
United Kingdom, Wales, Gwaun-Cae-Gurwen
Joined Mar 2011
Originally Posted by flow23 View Post
Wouldn't it be better to start a new thread for the flydumini discussion?!
http://www.rcgroups.com/forums/showthread.php?t=1543138
started one so that it would not over contaminate here.......
as i have plenty to ask regards to help with this little bird, perhaps some of the more experienced can help with questions and tips/hints?
nasgul is offline Find More Posts by nasgul
Old Nov 24, 2011, 11:47 AM
hubibubi is offline
Find More Posts by hubibubi
hubibubi's Avatar
Deutschland, SA
Joined May 2011
FlyduMini the Second
After the FlyduMini with the proto frame flies quite reasonable, I have a second 2.4 mm with the stronger frame construction.
List of materials:
- 1 x 2.4 mm Flydumini Frame
- 4x Hexatronik 10g Brushless Outrunner Motors
- 4x FlyFun 6A ESC from Hobbywing
- 1x ITG 3205
- 1x BMA020
- 1x 7-channel Deltang Rx32 of SUM-PPM - (Spectrum compatible)
- 1x landing skid from the TRex 250
- 1x 2S 7.4 V/800mAh
- 4x 2-blade 5x3 props CW and CCW
- 4x 3 LED stripes (red and yellow / orange)
I screwed the arrow under the frame, as a direction indicator (in the vicinity;-)) and as a lipo-holder.
Electronic coverage as of I've built a plate from a disused packaging.
I tested with MWC v1.8p2, with original values, but did not bring back the stable flight.
Values ​​halved and therefore re-tested, that's better but still not good enough.
ITG and BMA against one of 6DOF Drotek exchanged, and changes recorded test flight, ... anderst not, as might be expected.
Propeller balanced again and see ... will fly the bird.
So back down the 6DOF and my team ITG piggyback mounted on BMA.
No matter what you do, I'm repeating myself here, A and O is the balancing of the propeller, just come to the vibration gyro you've lost. A lot of double sided tape brings no improvement, rather deteriorates the whole.
Even if I give in the arms of the frames fly without reinforcement (carbon rods or other), both the frame nor the Black Proto-Mini.
The landing gear I'll still make a little lower, otherwise return a TOP Copter
Thanks to Paul.
Description:
Description:
Description:
I love Google Translator
Nachdem der FlyduMini mit dem Protoframe ganz vernünftig fliegt, habe ich einen zweiten mit dem stärkeren 2,4mm Frame gebaut.
Materialliste:
- 1x 2,4mm Flydumini Frame
- 4x Hexatronik 10g Brushless Outrunner Motoren
- 4x 6A FlyFun ESC von Hobbywing
- 1x ITG 3205
- 1x BMA020
- 1x Rx32 von Deltang 7-Kanal SUM-PPM (Spektrum kompatible)
- 1x Landegestell vom TRex 250
- 1x 2S 7,4V/800mAh
- 4x 2-blade CW und CCW 5x3 Props
- 4x 3 LED Stripes (rot und gelb/orange)
Den Pfeil habe ich unter das Frame geschraubt, als Richtungsanzeige (im Nahbereich ;-) ) und als Lipo-Halter.
Als Abdeckung der Electronic habe ich eine Plate gebaut aus einer ausgedienten Verpackung.
Getestet habe ich mit MWC v1.8p2, mit Originalwerten, das brachte aber wieder nicht den stabilen Flug.
Werte deshalb halbiert und nochmals getestet, schon besser aber noch nicht gut genug.
ITG und BMA gegen ein 6DOF von Drotek getauscht, Änderungen eingespielt und Testflug, ... auch nicht anderst, wie zu erwarten war.
Propeller noch einmal gewuchtet und siehe ... schon fliegt der Vogel.
Also wieder den 6DOF runter und mein Huckepack Gespann ITG auf BMA montiert.
Egal was ihr macht, ich wiederhole mich hier, A und O ist das auswuchten der Propeller, kommen erst Vibrationen zum Gyro habt ihr verspielt. Viel doppelseitiges Klebeband bringt auch keine Besserung, eher Verschlechtert sich das Ganze.
Auch wenn die Arme des Frames nachgeben ich fliege ohne Verstärkung (Carbonstäbe oder sonstiges) sowohl das Protoframe noch den Black-Mini.
Das Landegestell werde ich noch etwas flacher machen, ansonsten wieder ein TOP Copter
Dank an Paul.
hubibubi is offline Find More Posts by hubibubi
Old Nov 24, 2011, 01:47 PM
aBUGSnightmare is offline
Find More Posts by aBUGSnightmare
Joined Jul 2011
Originally Posted by olaf.j View Post
Hi,
Hi olaf.j
Black Mantis ESC were fine too (http://www.giantcod.co.uk/black-mant...-402902.html); you can program the motor rotation (comes handy!) - but, be shure the buy the programming card too!
Rgds
aBUGSworstnightmare
aBUGSnightmare is offline Find More Posts by aBUGSnightmare
Old Nov 24, 2011, 02:08 PM
Farmer_Joe is offline
Find More Posts by Farmer_Joe
RC Farmer
Farmer_Joe's Avatar
Joined Aug 2011
Hi,
is it possible that i burned mag and baro on my drotek 10dof, because i connected 5V FTDI to my mega board?
Farmer_Joe is offline Find More Posts by Farmer_Joe
2.4g shaun is offline
Find More Posts by 2.4g shaun
2.4g shaun's Avatar
United Kingdom, England, West York
Joined Aug 2008
Hi Olaf,
I have only ever used Turnigy Plush 10A esc's on all my copters
(Tri/Quad/hex) over the last 2 years.
I have never had a problem in use, never had a D.O.A.
The only mod I do is to remove one of the piggy backed BEC's from the PCB to lower the profile. The Hobby wing equivalent is identical except it only comes with 1 BEC on the board.... Same manufacturer.
I would be dubious of the few bad reviews, if you scan further down, you will see they are well received. I must have bought about 40 of them now, never had a bad one... still I have never tried to draw too much current from them and also taken the time to set them up. The one review saying it smoked when plugging the programming card in the wrong way is suspect. I have done this loads of times... no problem . Same as plugging a servo the wrong way into a RX.. unless the centre pin was changed from positive, it can't cause an issue.
The new 12A versions are the same size as the 10A.. (they used to be bigger).
I have used the 10A on my mini.. I'll add a picture soon Actually, there are 2 x Turnigy plush 10A and 2 x Hobbywing 10A.
Shaun
2.4g shaun is offline Find More Posts by 2.4g shaun
Old Nov 24, 2011, 03:37 PM
olaf.j is offline
Joined Aug 2011
Thank you for this information - looking forward to your picture
Old Nov 25, 2011, 03:56 AM
rinatka7 is offline
Find More Posts by rinatka7
rinatka7's Avatar
Russia, МО, Podolsk
Joined Dec 2010
Hello. Please help me with choice of t-motor.
I have quad, with all equipment weight is 1300gr, 10inch prop and 18A ESC.
Old motor was rc-timer 2830-14 750kv.
Which of tiger motor best suitable for me?
Thank you very much for help.
rinatka7 is offline Find More Posts by rinatka7
Old Nov 25, 2011, 04:26 AM
Joined Jul 2011
Originally Posted by Farmer_Joe View Post
Hi,
Did you connect 5V supply voltage or did you connect the I2C bus to 5V?
aBUGSworstnightmare
Old Nov 25, 2011, 04:31 AM
RC Farmer
Farmer_Joe's Avatar
Joined Aug 2011
aBUGSworstnightmare
I conected 5V usb-FTDI board to flyduino mega and since i assume that my mag and baro are not working properly. I will try to re-upload the software and calibrate everything again.
Old Nov 25, 2011, 05:00 AM
Goofy23 is offline
Find More Posts by Goofy23
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
MT2216 i guess, Rosewood made some tests, exellent results with 10".
Goofy23 is offline Find More Posts by Goofy23
Old Nov 25, 2011, 05:52 AM
Joined Jul 2011
Hi Farmer_Joe,
you must supply your Drotek IMU with 3.3V! Be shure to disable the internal pull-ups if you don't use a LLC.
Rgds
aBUGSworstnightmare
Old Nov 25, 2011, 06:21 AM
bovi is online now
Find More Posts by bovi
Joined Oct 2010
So that means that we cant use 5V FTDI with flyduino mega to configure the board.
bovi is online now Find More Posts by bovi
Old Nov 25, 2011, 09:27 AM
Goofy23 is offline
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
sure you can, in any way the drotek needs 3.3V, you can mount a 3.3V regulator set on the mini, then you are fine.
Old Nov 25, 2011, 12:17 PM
2.4g shaun's Avatar
Joined Aug 2008
My Flydumini is finished.
Esc's are 2 x Hobbywing and 2 x Turnigy 10A ( same manufacturer except Turnigy has 2 becs per esc, double current capacity)
Rx is a Spektrum 6300 Nanolite ( 2g) Finished weight is 148g.
WMP only, may put a BMA020 depending on how it flies.
Could loose a little more weight with lighter prop adaptors and will probably use 2 plade props, the 3 blade GWS are very poor.. I've balanced them and there is still excessive viabration, but I haven't put the frame stiffners on yet..
Thanks Paul a brilliant project.... Flyduminihex next please !!!
Shaun
New Product Please let me introduce myself jimaquo Dock Talk 7 Oct 27, 2010 02:27 AM
Let me introduce the DEMON!!!! (Transparent covering and eliptical wing!!!) modest-master Sport Planes 7 Aug 25, 2002 11:46 PM
Let me introduce Angelis 280/400, Benjamin, Zombi (ARFs) modest-master Parkflyers 17 Mar 14, 2002 01:20 PM
Let me introduce the "NIKE" modest-master Electric Sailplanes 3 Mar 07, 2002 05:20 AM
