Old Oct 30, 2011, 02:54 PM
Thunderbirddimka is offline
Find More Posts by Thunderbirddimka
Joined Nov 2010
Hallo Norbert !
ich habe V 2 Board !
ich probiere den Schutter auszukommentieren ,dann melde mich !
Hello Norbert!
I have V 2 board!
I try commenting out the muck, then sign me!
Thunderbirddimka is offline Find More Posts by Thunderbirddimka
Old Oct 30, 2011, 03:04 PM
treeda is offline
Find More Posts by treeda
Joined Dec 2008
Originally Posted by treeda View Post
thanks kinderkram, i think i will go with the 10g HXT and 6a turnigy esc, i have a couple of them already here but still need to order a few.
is there a useful tested all in one unit to replace WMP and BMA00? Not the FreeIMU, i use that for my bigger quad, maybe just a breakout board with both?
i found a promising one, i think it was already mentioned here or in another forum. This should work together with all Arduinos, right? So also a replacement and weighr saving for the mini?
http://www.drotek.fr/shop/en/32-imu-...er-sensor.html
treeda is offline Find More Posts by treeda
Old Oct 30, 2011, 03:05 PM
Joined Nov 2010
...........Schutter auskomentiert :-( kein Erfolg gebracht !
wo sitzt der Wurm ????!
.......... Schutter disabled :-( brought no success!
where the worm sits ????!
Old Oct 30, 2011, 03:17 PM
kinderkram is offline
Find More Posts by kinderkram
OS Sponsor
kinderkram's Avatar
Germany, NRW, Dusseldorf
Joined Jun 2010
Lol! Dunno where the worm sits! (sorry...)
What does it look like in the GUI?
Wie siehts denn im Configurator aus?
kinderkram is offline Find More Posts by kinderkram
Old Oct 30, 2011, 03:25 PM
hubibubi is offline
Find More Posts by hubibubi
hubibubi's Avatar
Deutschland, SA
Joined May 2011
or do you do that, by Jürgen copied, thx Jürgen von fpv-com...
ITG3205 on a BMA020
Description: ITG3205 ad hook on an BMA020
hubibubi is offline Find More Posts by hubibubi
Old Oct 30, 2011, 03:27 PM
Joined Nov 2010
da sieht es ganz normal aus ! die Gyros funktionieren !! ich bin ja mit der einstellung so eben geflogen ! die Camstab und Camtrigg sind schaltbar !
oder kann man noch im GUI Kamerastabilisirung sehen ?
muß spannung messen an den Servopins ,ob es überhaupt vorhanden ist ?
mit dem externen BEC probiert ,geht auch nicht !
because it looks quite normal! the gyros work! I'm just now flown with the setting! and the Camstab Camtrigg are switched!
or you can still see the GUI Kamerastabilisirung?
must measure the voltage at the Servopins whether it exists at all?
tried with the external BEC does not even work!
Old Oct 30, 2011, 03:28 PM
treeda is offline
Joined Dec 2008
looks scary.. well due to the fact i neither hav a BMA nor a ITG to play Bremer Stadtmusikanten *g i think i go with the 6dof. Except for some reason someone knows it doesn't work...
Old Oct 30, 2011, 03:47 PM
Joined Nov 2010
Spannung liegt an an den PINS 44, 45, 46 !!!!!!
oder ist bei Hexa das Giball nicht möglich ?! es ist ein Hexenwerk bei mir ,es funktioniert nicht auf Anhieb !
wer hatt alles Hexas hier mit Gimball ? was funktioniert :-)
Gruß
Voltage applied to the pins 44, 45, 46 !!!!!!
or is in the hexa Giball not possible? it is a rocket with me, it does not work right away!
Who was here with all Hexas Gimball? what works :-)
greeting
Old Oct 30, 2011, 03:52 PM
OS Sponsor
kinderkram's Avatar
Joined Jun 2010
Yep, I have a Drotek 6dof waiting to be soldered onto the Mini.
So I'm not alone...
btw: didn't something bad happen to the Bremen Boys at the end of the fairy tale?
Old Oct 30, 2011, 03:54 PM
treeda is offline
Joined Dec 2008
yikes! stop scaring me! :-) i'm already nervous like hell.... crawling the ceiling watching the monitor for the flydumini showing up....
Old Oct 30, 2011, 04:02 PM
Goofy23 is offline
Find More Posts by Goofy23
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
have to take a evening meal and allready have to reply some mails, but be sure it will show up today (damm only 2h left...)
Goofy23 is offline Find More Posts by Goofy23
Old Oct 30, 2011, 04:04 PM
OS Sponsor
kinderkram's Avatar
Joined Jun 2010
Calm down!
You sound like a pregnant father awaiting his first baby.
Old Oct 30, 2011, 04:05 PM
Saneless is offline
Find More Posts by Saneless
Joined Jun 2011
Calm down!
Saneless is offline Find More Posts by Saneless
Old Oct 30, 2011, 04:08 PM
treeda is offline
Joined Dec 2008
Calm down!
imagine it's a gang of 4 .-)
Old Oct 30, 2011, 04:48 PM
treeda is offline
Joined Dec 2008
just ordered it now i need start to think how to connect the 6dof to it. i'm currently reading it needs 3.3v but the pro mini from paul is a 5v version.
New Product Please let me introduce myself jimaquo Dock Talk 7 Oct 27, 2010 02:27 AM
Let me introduce the DEMON!!!! (Transparent covering and eliptical wing!!!) modest-master Sport Planes 7 Aug 25, 2002 11:46 PM
Let me introduce Angelis 280/400, Benjamin, Zombi (ARFs) modest-master Parkflyers 17 Mar 14, 2002 01:20 PM
Let me introduce the "NIKE" modest-master Electric Sailplanes 3 Mar 07, 2002 05:20 AM
