Old Oct 30, 2011, 11:12 AM
joebarteam is offline
Find More Posts by joebarteam
J'ai remis la purée
Netherlands, ZH, Zoetermeer
Joined Mar 2011
Originally Posted by warthox View Post
@~1.02 , Anfänger !!!
Menno
joebarteam is offline Find More Posts by joebarteam
Old Oct 30, 2011, 11:18 AM
alteskind is offline
Find More Posts by alteskind
Deutschland, Schleswig-Holstein, Kiel
Joined Jan 2011
Originally Posted by kinderkram View Post
Don't worry, guys. I'm sure Paul will put it online soon.
In the meantime you should order some ESCs, props and motors so you don't end up as me: having the Mini but missing essential parts.
I only need my props and them I'm ready to go...
i got my turnigy 1811 already - was lucky to get them from german HK warehouse...and have some props + ESCs lying around here
just waiting for frame....
ordered enough of the small motors for 2 octos .
will build a custom mini frame , as i am very impatient to test them
when flydumini is available, i can compare the minis, and maybe switch the hardware to the new frame.
btw, the turnigy 1811 2000kv were delivered with 2 prop savers, one with o-ring, and one with alloy spinner (5mm) - perfect for our copters .
they are packed in the same box as some hextronic 24g i ordered in the past.
alteskind is offline Find More Posts by alteskind
Old Oct 30, 2011, 12:37 PM
Goofy23 is offline
Find More Posts by Goofy23
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
heavy stuff, been flying the mini outdoors too yesterday, but my flight looked a bit different.
Flew only autostable with the 1.8 patch2, fun, real fun and quite stable.
Ok i iwll put in the shop, just waiting for a saw to prepare some carbon sticks.
If you wont mind the missing carbon reinforcements, i am ready to go.
Goofy23 is offline Find More Posts by Goofy23
Old Oct 30, 2011, 12:52 PM
kinderkram is offline
Find More Posts by kinderkram
OS Sponsor
kinderkram's Avatar
Germany, NRW, Dusseldorf
Joined Jun 2010
I don't think you'll really need the reinforcers.
The black one is damn stiff on its own.
I showed it off to some experts today and everyone said: "nearly unbreakable".
I think the weakest point in case of a crash will be near the motor mounts...
kinderkram is offline Find More Posts by kinderkram
Old Oct 30, 2011, 12:56 PM
Norf is offline
Find More Posts by Norf
Fly low!
Norf's Avatar
VS , Germany
Joined Jul 2007
I agree to kinderkram!!
On the black one you don´t need something to make it more stable.
Norbert
Norf is offline Find More Posts by Norf
Old Oct 30, 2011, 01:50 PM
hubibubi is offline
Find More Posts by hubibubi
hubibubi's Avatar
Deutschland, SA
Joined May 2011
FlyduMini Outdoor
Congratulations, Nobert and Markus as always TOP.
Have been for Paul said, you may be given a broom handle (Nimbus 2000), the main thing is a motor to it, then you can also fly to.
FlyduMini First Flight (1 min 43 sec)
But I doubt to the motto, always reasonable to have no meaning I've brought my FlyduMini in the garden in the air.
Cruise around a bit and had my props, until I have more of it.
Thanks to Paul one, good job, your great idea FlyduMini.
Glückwunsch, Nobert und Markus, wie immer TOP.
Hab schon zu Paul gesagt, euch kann man einen Besenstil (Nimbus 2000) geben, Hauptsache ein Motor ist dran, dann könnt ihr den auch fliegen.
Ich aber ganz nach dem Motto, immer sinnig, nicht unsinnig habe ich meinen FlyduMini im Garten in die Luft gebracht.
Cruise ein wenig rum und schon meine Props, bis ich mehr davon habe.
An Paul ein Dank, guter Job, großartige Idee dein FlyduMini.
hubibubi
hubibubi is offline Find More Posts by hubibubi
Old Oct 30, 2011, 02:10 PM
OS Sponsor
kinderkram's Avatar
Joined Jun 2010
Crongratz, hubi!
Mini video number 3 - looks really smooth and stable.
Please post your setup & settings, guys. So we have some corner stones for the following generations of Minis...
Maybe someone could open a new thread for the Mini?
Otherwise this thread here will become confusing.
Old Oct 30, 2011, 02:13 PM
treeda is offline
Find More Posts by treeda
Joined Dec 2008
did we already identify a useful motor setup and esc for pauls mini?
i need to prepare :-)
treeda is offline Find More Posts by treeda
Old Oct 30, 2011, 02:33 PM
Thunderbirddimka is offline
Find More Posts by Thunderbirddimka
Joined Nov 2010
Hallo Jungs ,brauche Hilfe ,komme einfach nicht weiter !
so habe einen Hexa mit Flyduinoboard mit 1.8 Wii Software ,hat lange gedauert jetzt fliegt der Copter wie auf Schienen ,heute bin ich weiter gegangen habe dann die Kamerastabilisierung aktiviert ,im Sketh das #define SERVO_TILT und #define CAMTRIG auskommentiert und upload ,dann Servos an die Pins 44 und 45 angeschlossen und 5 Volt an das Powerpin für Gimball ,wozu ist der pin 46 ? naja auf jeden Fall habe ich keine Funktion beim einschalten zucken die Servos ganz kurz ,der Copter wird bewegt ,die Kamerastabilisierung hat aber keine Funktion ,was habe ich übersehen oder falsch gemacht ? bitte um einen kleinen Tipp ist es zwingen einen extra BEC an das Powerpin für kamerastabilisierung !?
Gruß
Dimi
Hi guys, need help, not get past easy!
Sun has a hexa with Flyduinoboard with 1.8 Wii software, has taken a long time now fly the copter as if on rails, now I'm gone I then turned the camera stabilization, commented out in Sketh the # define SERVO_TILT and # define CAMTRIG and upload, then servos connected to pins 44 and 45 and 5 volts to the Powerpin for Gimball, which is pin 46? Well anyway, I have no function in turn the servos twitch very briefly, the copter is moving, the camera has no stabilization function, what am I missing or doing wrong? ask for a small tip is an extra force to the BEC Powerpin for camera stabilization?
greeting
Dimi
Thunderbirddimka is offline Find More Posts by Thunderbirddimka
Old Oct 30, 2011, 02:37 PM
OS Sponsor
kinderkram's Avatar
Joined Jun 2010
This is what I collected so far:
Code:
Paul:
Flydumini Frame
org WMP
BMA020
4 Hextronik 10g
6A Hobbywing
500mA 2S
Frsky D4FR PPM
hubibubi:
Mystery A1504 2700KV
T-Power, Black Mantis ESC 8-10A (10A Hobbywing good are the GC, very narrow and small)
Props 5x3 and 4x2, 5 (both can fly well)
WMP original
2S 7.4V 800mAh LIPO
DelTang RX31 4-channel, 7-channel PPM converted (super small 9x10mm)
Norf:
The green one is WMP only
Hobbywing ESC
A1510 Motors with GWS 5x3 3Blade.
The black one is WMP only
10A T-Motor ESC ( same as Mystery )
HK 10 gr Motors with 5x3 3Blades.
warthox:
Turnigy 1811 2000kV
T-Motor ESC 10A
GWS 5x3x3 props
3S1000 20C lipo
treeda is offline
Joined Dec 2008
The servos for the gimbal need an extra powerinput... they are not feeded by the internal power system.
Old Oct 30, 2011, 02:40 PM
treeda is offline
Joined Dec 2008
thanks kinderkram, i think i will go with the 10g HXT and 6a turnigy esc, i have a couple of them already here but still need to order a few.
is there a useful tested all in one unit to replace WMP and BMA00? Not the FreeIMU, i use that for my bigger quad, maybe just a breakout board with both?
Old Oct 30, 2011, 02:43 PM
Joined Nov 2010
also and das Powepin einen externen BEC ? ist das Richtig ?!
and thus the Powepin an external BEC? is that correct?
rinatka7 is offline
Find More Posts by rinatka7
rinatka7's Avatar
Russia, МО, Podolsk
Joined Dec 2010
May be one of this motor will good choice:
http://www.himodel.com/sort.php?brand=239
rinatka7 is offline Find More Posts by rinatka7
Old Oct 30, 2011, 02:47 PM
OS Sponsor
kinderkram's Avatar
Joined Jun 2010
Which version of the Flyduino do you have?
I'd disable the trigger first (pin#46) and only use the pitch&roll stabilization.
Nimm mal erst den Shutter raus und probier, ob du die Servos mit den Gyros steuerst.
New Product Please let me introduce myself jimaquo Dock Talk 7 Oct 27, 2010 02:27 AM
Let me introduce the DEMON!!!! (Transparent covering and eliptical wing!!!) modest-master Sport Planes 7 Aug 25, 2002 11:46 PM
Let me introduce Angelis 280/400, Benjamin, Zombi (ARFs) modest-master Parkflyers 17 Mar 14, 2002 01:20 PM
Let me introduce the "NIKE" modest-master Electric Sailplanes 3 Mar 07, 2002 05:20 AM
