Old Oct 27, 2011, 04:35 PM
treeda is offline
Find More Posts by treeda
Joined Dec 2008
amazing!!! definitly a must have, when can we order that board / frame?
treeda is offline Find More Posts by treeda
Old Oct 27, 2011, 05:14 PM
Goofy23 is offline
Find More Posts by Goofy23
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
yes for sure, soon, thanks.
ave everything here, just wnated to find a setting which pleases me.
I may have some good tiger motrs too soon.
I will have props also in a few weeks.
the Frame Set itself will be avaiable soon, just have to pepare some sets, i think of offering it with some 2.5x2.5mm carbon square tubes, 2 pieces at 25cm enough for 8 5.5cm pieces, still unsure if its needed also.
Goofy23 is offline Find More Posts by Goofy23
Old Oct 28, 2011, 12:34 AM
aBUGSnightmare is offline
Find More Posts by aBUGSnightmare
Joined Jul 2011
Originally Posted by Goofy23 View Post
185g complete incl. all 500mA 2s and reinforcement plus landig gears (4 20mm plyamid standoffs).
Board itself is arround 50g.
Hi Paul,
a real beauty
Will you offer the 6A Hobbywing ESCs too? They're out of stock at giantcod.co.uk
Rgds
aBUGSworstnightmare
P.S. what about posting a pic from the bottom ??
aBUGSnightmare is offline Find More Posts by aBUGSnightmare
Old Oct 28, 2011, 05:36 AM
kinderkram is offline
Find More Posts by kinderkram
OS Sponsor
kinderkram's Avatar
Germany, NRW, Dusseldorf
Joined Jun 2010
Originally Posted by aBUGSnightmare View Post
Hi Paul,
a real beauty
Rgds
aBUGSworstnightmare
Here you go:
kinderkram is offline Find More Posts by kinderkram
Old Oct 28, 2011, 06:06 AM
svensonite is offline
Find More Posts by svensonite
svensonite's Avatar
Deutschland, Berlin
Joined Oct 2011
who's the real problem of contact for my post 2390?
svensonite is offline Find More Posts by svensonite
Old Oct 28, 2011, 06:31 AM
OS Sponsor
kinderkram's Avatar
Joined Jun 2010
Sorry for the late answer: I can't view you silverlight videos.
It asks me to install the latest silverlight but when I try it says: latest version already installed. Typical MS...
Can't you upload to Youtube or Vimeo instead?
Old Oct 28, 2011, 06:46 AM
Joined Jul 2011
Originally Posted by kinderkram View Post
Here you go:
Hi kinderkram,
yes! now I can see the UBEC I was missing since no BEC is connected from the ESC.
Is this little beauty the one from Paul http://flyduino.net/3A-mini-UBEC ?
You don't have any reinforcements at the moment, right?
Rgds
aBUGSnightmare
P.S. By the way, 500mA Zippy 2S1P were available from the German HK warehouse (http://www.hobbyking.com/hobbyking/s...arehouse_.html), 3,48EUR (4.93USD) each. Should be perfect to go with the flydumini.
Old Oct 28, 2011, 07:53 AM
svensonite's Avatar
Deutschland, Berlin
Joined Oct 2011
hey Kinderkram,
no Problem. i hope it is so better for you?
Multiwii Camstab (1 min 7 sec)
Old Oct 28, 2011, 08:22 AM
OS Sponsor
kinderkram's Avatar
Joined Jun 2010
Yep, the UBEC is the one Paul sells.
Thx for the link to the Zippy - will order 2 of them to try.
Hi kinderkram,
Rgds
aBUGSnightmare
Old Oct 28, 2011, 08:27 AM
OS Sponsor
kinderkram's Avatar
Joined Jun 2010
hey Kinderkram,
http://vimeo.com/31250197
Ok, now I see...
You mean the moment when the servos get triggered. I don't think there's a solution to smoothen this - at least none I know of. It always snaps in that way.
But I think this is no problem since it only occurs right after the start.
One thing you could try is to bring the servo into the desired position before you plug in the lipo. That's the way it works for me. Only if I hang some heavy cam on my gimbal the weight will tear on the servo and let's it point downwards.
Old Oct 28, 2011, 11:43 AM
r0sewhite is offline
Find More Posts by r0sewhite
It wasn't me
r0sewhite's Avatar
Augsburg, Germany
Joined Mar 2010
hey Kinderkram,
I think the flip of the cam when camstab is activated, should be no problem since you usually activate it before a flight.
The bigger problem is the resolution. I was also disappointed of how rough the servos run. Since I know that the tail servo of a multiwii tri works much smoother, I guess that the resolution is a matter of code.
I think the best way is to compare the code of the yaw servo and the cam servos to find out differences.
r0sewhite is offline Find More Posts by r0sewhite
Old Oct 28, 2011, 12:20 PM
svensonite's Avatar
Deutschland, Berlin
Joined Oct 2011
Hey Tilman,
i'm glad I've found the code and adapt it for Camstab could so that the servos operate synchronously.
Sven
Old Oct 28, 2011, 02:11 PM
Goofy23 is offline
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
Hi kinderkram,
Rgds
aBUGSnightmare
Yes i tried the UBEC, but switched back to the ESC BEC, no difference and 6g less, thought its may safer when using 2s.
Atm i have reinforcements underneath. 2.5mmx2.5mm square CFK tube, glued with hotglue.
Flies well, with the Hex 10g mots it seem to fit good with a small 500mA lipo, which are really cheap and not bad.
I am sure we find other configs too.
Old Oct 28, 2011, 03:10 PM
OS Sponsor
kinderkram's Avatar
Joined Jun 2010
While I'm still waiting on parts for my Mini why not entertain us with some flight vidz of yours, Päule?
I'm sure you'll meet a very interested audience - or is it vidience in this case?
Old Oct 28, 2011, 05:30 PM
hubibubi is offline
Find More Posts by hubibubi
hubibubi's Avatar
Deutschland, SA
Joined May 2011
Flydumini only
Today I was again busy with my FlyduMini, it must be possible but that the little flies and I can already tell he is flying.
First, I swapped the motors and the A1504 2700KV mounted with the mounting holes had to be adjusted a bit but it may not even be available for all engines the appropriate holes.
The propellers are absolutely important, because I've taken me more time and balanced the leaves, you are bad , I hope the 3-blade are better. I had about 6-8cm on a piece of tape stuck to the run around.
Then I added a new hole with the center ring, which I had a random way or by any batch of props.
Description:
Now a test flight and what should I say the top is like a small one, and without the BMA only with WMP.
Then something else will correct the values ​​and then I'll solder the next time one BMA020.
The PID values ​​are seeing in the picture.
Description:
A and O are to eliminate the vibrations, not too much power to the engines and propeller de balancing and happy you are with the neighbors.
You see Paul you must be just stubborn, Frame TOP
My setup:
Mystery A1504 2700KV
T-Power, Black Mantis ESC 8-10A (10A Hobbywing good are the GC, very narrow and small)
Props 5x3 and 4x2, 5 (both can fly well)
WMP original
2S 7.4V 800mAh LIPO
DelTang RX31 4-channel, 7-channel PPM converted (super small 9x10mm)
hubibubi is offline Find More Posts by hubibubi
New Product Please let me introduce myself jimaquo Dock Talk 7 Oct 27, 2010 02:27 AM
Let me introduce the DEMON!!!! (Transparent covering and eliptical wing!!!) modest-master Sport Planes 7 Aug 25, 2002 11:46 PM
Let me introduce Angelis 280/400, Benjamin, Zombi (ARFs) modest-master Parkflyers 17 Mar 14, 2002 01:20 PM
Let me introduce the "NIKE" modest-master Electric Sailplanes 3 Mar 07, 2002 05:20 AM
