Old Oct 19, 2011, 07:27 PM
Goofy23 is offline
Find More Posts by Goofy23
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
and also have a Flyduino pro mini now in stock for MWC, Divide and Flydumini.
In matt black and 1.6mm
http://flyduino.net/index.php?a=73
Goofy23 is offline Find More Posts by Goofy23
Old Oct 20, 2011, 02:46 AM
kinderkram is offline
Find More Posts by kinderkram
OS Sponsor
kinderkram's Avatar
Germany, NRW, Dusseldorf
Joined Jun 2010
Nice! Will make a nice companion for the MiniQuad.
kinderkram is offline Find More Posts by kinderkram
Old Oct 20, 2011, 04:25 AM
jrlederer is offline
Find More Posts by jrlederer
Joined Apr 2009
Big steps in proper direction
Originally Posted by jrlederer View Post
In fact, I have just received an ardupilot mega oilpan + shield kit in the mail today, so I will be able to check these things as soon as i am finished assembling the headers onto the boards. I will check where the fault is then I will post back my results. Thank you for responding so quickly.
--Jonathan
Well, as a status update: I soldered up the only alternate arduino-based electeonics that I received from DIYDrones and when, as u recommended, I tried with an alternate FTDI adaptor I was suddenly able to complete the verify and upload to board the MultiWii 1.8rev2 package. Lo and Behold! For the first time in quite a lot of tries, finally I was able to view the data while in the config GUI!
Thanks for the assistance, it is very much appreciated.
jrlederer is offline Find More Posts by jrlederer
Old Oct 20, 2011, 04:26 AM
Joined Apr 2009
Spektrum adapter instead of receiver + patch cables?
Now I've another inquiry: is it possible to substitute the physical receiver when on ver 1.8+ in place of simply a Spektrum satellite that has been pre-bound (binded) to my transmitter via AR7000 or similar? I am a little confused after what I've read, as nothing explicitly states this, yet in the interest of saving weight and wiring complexity it would seem desirable to do this.
It looks like all I need to do solder pin 19 to the grey cable, Ground to black, and 3.3V to orange and then uncomment the //#define Spektrum in the config.h or is there some intermediate bit of hardware that needs to go between the two elements?
Thanks again!
Old Oct 20, 2011, 05:33 AM
fr3d-nexus is offline
Find More Posts by fr3d-nexus
fr3d-nexus's Avatar
France (near the ch'ti village)
Joined Apr 2007
ser 2 connector
hye all,
I want ot connect a remzibi poor gps(gnd-black,5v-red,tx-white,rx-blue) trough the "ser" little white connector on a flyduino board.
I've bought the specific wire @ flyduino.com.
And now I would like to know the connecting diagram of this connector.
I've found the following with a multimeter
from TX1/Rx1/5v/gnd connector (up) to rc receiver pins(down)
"ascii" schematic:
TX1/RX1/5v/gnd
pin6: Ground
pin5: 5v
pin4: TX
pin3: RX
pin2: gnd
pin1: unknow xck?
rc pin reciver
is it correct ?
fr3d-nexus is offline Find More Posts by fr3d-nexus
Old Oct 20, 2011, 12:08 PM
Goofy23 is offline
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
in berkeleys shematic is the pinout included.
http://multiwii.googlecode.com/svn/t...20Flyduino.png
Old Oct 20, 2011, 12:59 PM
r0sewhite is offline
Find More Posts by r0sewhite
It wasn't me
r0sewhite's Avatar
Augsburg, Germany
Joined Mar 2010
Oops, it breeded! I'm sure it was only one yesterday.
r0sewhite is offline Find More Posts by r0sewhite
Old Oct 20, 2011, 01:37 PM
OS Sponsor
kinderkram's Avatar
Joined Jun 2010
The black one's name must be Adam!
And the girl at his side (must be a girl - with silvery arms) was made from one of his ribs. Hmmm ... did you control if he still got all of his?
Again: very professional setup! You can start mass production now...
Old Oct 20, 2011, 01:39 PM
flow23 is offline
Find More Posts by flow23
Deutschland
Joined Jul 2011
Originally Posted by aBUGSnightmare View Post
Hi bovi,
glad you like it
Find a baisc 'how-to' here http://www.rcgroups.com/forums/showt...81577&page=140 and here
http://www.rcgroups.com/forums/showt...81577&page=142.
In case of any questions do not hesitate to ask!
I think a detailed setup instruction will be online soon now that Paul's Wiki is up 'n running.
aBUGSworstnightmare
I like the board too, and also the idea of a wiki with Paul's stuff and MWC settings for his frames and motors. Most import I think is a good article about the LLC and which sensor works with which board (with or without LLC).
flow23 is offline Find More Posts by flow23
Old Oct 20, 2011, 02:02 PM
aBUGSnightmare is offline
Find More Posts by aBUGSnightmare
Joined Jul 2011
Hi flow23,
I will include the info when re-writing the setup instructions (How-to guide).
By the way: you can mount any sensor to the board since it gives you plenty of possibilities ...
aBUGSworstnightmare
aBUGSnightmare is offline Find More Posts by aBUGSnightmare
Old Oct 20, 2011, 02:04 PM
It wasn't me
r0sewhite's Avatar
Augsburg, Germany
Joined Mar 2010
You think so? I just called him spider.
I guess, this must get boring pretty soon.
Old Oct 20, 2011, 02:14 PM
Joined Jul 2011
Well Tilmann, why don't you build a third one with 'minimalistic' flight controller and RX?
Paul has a nice new board which perfectly suits the spider (lol) and Alex/Danal have the Spektrum code (http://www.rcgroups.com/forums/showt...1504116&page=5) running.
--> everything is there for an all-in-one flight controller + satellite receiver (making it even simpler than http://www.rcgroups.com/forums/attac...mentid=4338468).
Chers
Joerg
Old Oct 20, 2011, 02:45 PM
It wasn't me
r0sewhite's Avatar
Augsburg, Germany
Joined Mar 2010
Joerg, I know. I have already seen the prototype some time ago. Will try your board on my next quad. Paul just sent me a set of 12" props, so I need to build a quad that's big enough to test them.
I already downloaded the Spektrum version but didn't try it yet. Instead of soldering a VC to the power line of the Spektrum satellite, I thought about using the 3V3 from the board.
However, the possibility of using Spektrum satellites is great. No more standard receivers with all their wiring.
Old Oct 20, 2011, 02:57 PM
OS Sponsor
kinderkram's Avatar
Joined Jun 2010
But she is more perfect than him.
You even drilled the holes for the motors differently to let all wires swing to the back. Perfect!
Old Oct 20, 2011, 03:03 PM
It wasn't me
r0sewhite's Avatar
Augsburg, Germany
Joined Mar 2010
No, hole distances are all 19mm. I just had 12 motors and picked out 3 with wires to the left and 3 with wires to the right.
But you're right: It's a SHE because HE's got more power.
New Product Please let me introduce myself jimaquo Dock Talk 7 Oct 27, 2010 02:27 AM
Let me introduce the DEMON!!!! (Transparent covering and eliptical wing!!!) modest-master Sport Planes 7 Aug 25, 2002 11:46 PM
Let me introduce Angelis 280/400, Benjamin, Zombi (ARFs) modest-master Parkflyers 17 Mar 14, 2002 01:20 PM
Let me introduce the "NIKE" modest-master Electric Sailplanes 3 Mar 07, 2002 05:20 AM
