Old Oct 09, 2011, 12:55 PM
wilco1967 is offline
Find More Posts by wilco1967
Winterswijk, Netherlands
Joined Jun 2007
Hi Nils,
Electrically, I have exactly the same
However, the orientation of your 5883 sensor is completely different, and you probably need to play with the orientation settings in the code to get it correct.
The 5883 is upside down to start with (your photo shows the bottom of the board, the WMP and BMA-020 MUST be on the top). It is also turned 90 deg
I have it on the other (top) side, next to the WMP / BMA-020, with the solder connections facing aft.
I had to use the following code, but you will need something else....
#define MAG_ORIENTATION(X, Y, Z) {magADC[ROLL] = -Y; magADC[PITCH] = X; magADC[YAW] = Z;}
For the BMP-085, orientation clearly does not matter
The pull-ups in the code can be disabled as you have 5V pull-ups already installed on the Flydusense.
Wilco.
Originally Posted by jevermeister View Post
I use the same sensors from the same seller, can you make a photo of your setup?
I installed the like this:
Software pullups are still enabled but it is working fine...
Is this still correct?
Nils
wilco1967 is offline Find More Posts by wilco1967
Old Oct 09, 2011, 01:26 PM
jevermeister is offline
Find More Posts by jevermeister
jevermeister's Avatar
Deutschland, SH, Kiel
Joined Jul 2011
Originally Posted by wilco1967 View Post
Hi Nils,
Wilco.
Thanks for the hints, I intended to put those sensors on the back of the flydusense, I had quite a hard time to configure the mag, I started by turning the coordinate system they way I learned in math, but I ended up trial and error and a lot of help from Alex. Now it is working fine (but I got some weird behavior when the copter tilts very much in flight hmmm)
Nils
jevermeister is offline Find More Posts by jevermeister
Old Oct 09, 2011, 01:59 PM
Joined Jun 2007
If it is moving correcty in the GUI, the problem in flight is probably from the 5883 getting disturbed by the magnetic field from the motor current....
You can try holding in in your hand, while connected to the GUI, and powering up the motors..... If you raise the throttle, observe the compass readings... (and don't let go.... )
I had the compass heading completely turn around at some point with my old Quad while using these sensors (still on a Flydusense V1 board)....
After I relocated the ESC's away from the sensors, it became better.
My current quad has a Warthox board + FreeIMU 0.3.5 MS, which still has some interference from the ESC's, but not a real problem (it drifts a little in yaw, but holds heading quite reasonable).
I haven't tried it yet on the flydusense V2 I'm have put together now (building a Tri at the moment).
Nils
Old Oct 10, 2011, 12:55 AM
Goofy23 is offline
Find More Posts by Goofy23
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
Nils
Hi Nils, a friend told me today the BMP (sparkfun) have some Pullups on it, but you know allready, so its completely right how you both did it, electrically, orinetation is another story, but i am sure you can deal with that.
You dont need the 3.3V pullups on the V2 cause your BMP provides this, a second pair pullups may not harm, but depending on the value the signal quality can suffer.
Its simple 2 10K in parallel gives you 5K resitance in the end (values only as example).
This is the case when you enable the internal pullups and connect the ones on your BMA020 may your WMP clone got some too, so the end value of "the " 5V pullups depends on this 3 factors.
The Values i choosed are well working if took alone (4.7K-6.8K for 5V/ about 3.3K for 3.3V) for our I2C signal.
Ok we are in a digital world here, so working or not working (if murphy isnt there), so there is some room, but a too low value isnt good as a too high isnt.
Easy german expalnation for you and other germans who wants to know.
http://www.strippenstrolch.de/1-3-9-...-parallel.html
Resistor calc in english:
http://www.1728.org/resistrs.htm
Wiki Pullups
http://en.wikipedia.org/wiki/Pull-up_resistor
You can easily meassure this value, take a multimeter and meassure the resistance between 3.3V or 5V (depending on what side you want to meassure) and your I2C Datalines, this tells you very fast the value.
Goofy23 is offline Find More Posts by Goofy23
Old Oct 10, 2011, 05:58 AM
r0sewhite is offline
Find More Posts by r0sewhite
It wasn't me
r0sewhite's Avatar
Augsburg, Germany
Joined Mar 2010
Had maiden flight yesterday with Pauls Tiger motors, CF props and warthox board on my esther frame. It was a lot of fun since I never thought that a quad with 10" props could be that agile. Before the flight I set the RC rate to 1.2 as I usually do this with every quad to have good rates. I was very surprised because I didnt' expect this "big" quad to react so stick-sensitive.
Also the cf props are very nice. Okay, they came with massive imbalance and had to be balanced first but then it's pure fun to fly them. No rattel at all when flying circles with high speed. Also I enjoy the prompt reaction on stick inputs like stopping the quad after flips.
Unfortunately the flight ended with a broken prop. I flew until it was dark outside and after the 4th battery I missed a little stick that was hidden in the grass. One prop hitted the stick and cracked. Usually such a small stick wouldn't harm a prop at all but obviously these cf props are very brittle.
For those who can read German, here is the build log: http://www.microcopters.de/artikel/d...r0sewhite-quad
r0sewhite is offline Find More Posts by r0sewhite
Old Oct 10, 2011, 08:44 AM
aBUGSnightmare is offline
Find More Posts by aBUGSnightmare
Joined Jul 2011
DIVIDE et IMPERA! meets Flyduspider
Hi there,
just to add some more details on the DIVIDE et IMPERA! you can find some pictures enclosed! DIVIDE meets Flyduspider !
The PPM signal comes from a 1hoch4 SpektrumtoPPM converter, visible on top of the stack.
aBUGSworstnightmare
Edit: Maidened the spider with default PID settings! Now I have a very stable platform for my GPS tests!!
aBUGSnightmare is offline Find More Posts by aBUGSnightmare
Old Oct 11, 2011, 07:19 AM
aidensere07 is offline
Find More Posts by aidensere07
United Kingdom, England, Sheffield
Joined Nov 2009
i just want to say how satisfied i am with shopping with paul @ flyduino.com, iv placed two orders in 2 weeks and had them both through quicker than some uk vendors. A very impressed customer, im definatly going to be ordering the flydusense v2 as i bought the v.1 by mistake. Dont hesitate to shop there. The props look great too, i got some 10" and 8" glass reinforced ones and they seem good. Not finished my hex yet so not had chance to try them out but ill post when iv tried them.
Aiden
aidensere07 is offline Find More Posts by aidensere07
Old Oct 11, 2011, 07:30 AM
volver is offline
Find More Posts by volver
Russia, Moscow
Joined Jan 2011
Hi Paul, congrats with new motors MT3506!!!
I received some last week, they are very good quality! Will you test them (thrust, amp draw, etc)?
I am also finalizing my Y6 based on x468 frame (i wanted hexa but was impressed by Warthox's Y6).
volver is offline Find More Posts by volver
Old Oct 11, 2011, 04:27 PM
helicoblast is offline
Find More Posts by helicoblast
Geneva, Switzerland
Joined Jan 2009
Originally Posted by kinderkram View Post
Well done, Mike!
Thanks for your work so far. Arguing from the pix you posted I'm afraid the front isn't flat enough. Is it really only 2cm? Anyway .... I'll test it and will send you some more info then.
The other problem remains: people have different heigths of the bob stacks. I don't think we will get away with only 1 universal dome but have to offer min. 2 variations.
I'll see how it fits...
Norbert, some news about the cover?
helicoblast is offline Find More Posts by helicoblast
Old Oct 12, 2011, 01:47 AM
kinderkram is offline
Find More Posts by kinderkram
OS Sponsor
kinderkram's Avatar
Germany, NRW, Dusseldorf
Joined Jun 2010
No, sorry. I hope it's on the way...
kinderkram is offline Find More Posts by kinderkram
Old Oct 12, 2011, 02:17 AM
Geneva, Switzerland
Joined Jan 2009
Ok thanks Norbert, as usual I'm a bit impatient!
@Paul,
Could you tell me how to use the battery monitor PIN with megapirates code?
Old Oct 12, 2011, 02:47 AM
Goofy23 is offline
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
same as with the Multiwii
I think Markus will make further tests
Old Oct 12, 2011, 05:43 AM
fr3d-nexus is offline
Find More Posts by fr3d-nexus
fr3d-nexus's Avatar
France (near the ch'ti village)
Joined Apr 2007
can someone tell me the name of little white serial connector in flyduinomega board ?
fr3d-nexus is offline Find More Posts by fr3d-nexus
Old Oct 12, 2011, 06:54 AM
alteskind is offline
Find More Posts by alteskind
Deutschland, Schleswig-Holstein, Kiel
Joined Jan 2011
its JST-SHL or JST-SH
older flyduinos (V1) have other version of this connector (but with the same name....)
for the actual flyduino paul offers a matching cable http://flyduino.net/GPS-Kabel-20cm
alteskind is offline Find More Posts by alteskind
Old Oct 12, 2011, 02:48 PM
mgros is offline
Find More Posts by mgros
mgros's Avatar
España, Aragón, Zaragoza
Joined Dec 2006
Flyduino with lights
I present you a new evolution of my Mini Quad
I have changed the engines, I have finally solved the problem that stopped in flight. (don't use bad engines).
The control board is first flyduino version (MEGA 1280), gyro MP+ and accelerometer BMA180.
I'm flying MultiWii 1.8P2 version but I've added control for the arms LEDs.
LED sequence is programmable, I'm thinking to program different sequence according to the type of flight. (stable, acro) or battery alarms.
The code that controls the lights is copied from an idea I saw in Megapirates and does not affect the control of the flight. Furthermore, it is quite elegant.
Enjoy it!
Flyduino Multiwii with lights (5 min 31 sec)
mgros is offline Find More Posts by mgros
New Product Please let me introduce myself jimaquo Dock Talk 7 Oct 27, 2010 02:27 AM
Let me introduce the DEMON!!!! (Transparent covering and eliptical wing!!!) modest-master Sport Planes 7 Aug 25, 2002 11:46 PM
Let me introduce Angelis 280/400, Benjamin, Zombi (ARFs) modest-master Parkflyers 17 Mar 14, 2002 01:20 PM
Let me introduce the "NIKE" modest-master Electric Sailplanes 3 Mar 07, 2002 05:20 AM
