Old Oct 06, 2011, 05:32 PM
r0sewhite is offline
Find More Posts by r0sewhite
It wasn't me
r0sewhite's Avatar
Augsburg, Germany
Joined Mar 2010
ESCs are Black Mantis 20A. The original tubing is much too strong and blocks the heat. Usually I completely strip the ESCs but this time I wanted them to be black so I took a thin hs tubing which is normally used for batteries. Flat width was 30mm.
Btw: This is the quad so far. I hope the blue LED strips to arrive tomorrow so I can finish it:
r0sewhite is offline Find More Posts by r0sewhite
Old Oct 06, 2011, 05:38 PM
bob4432 is offline
Find More Posts by bob4432
bob4432's Avatar
United States, AZ, Phoenix
Joined May 2010
appreciate the info, looking very good - nice and clean
bob4432 is offline Find More Posts by bob4432
Old Oct 07, 2011, 02:12 AM
warthox is offline
Find More Posts by warthox
Joined Aug 2009
Originally Posted by r0sewhite View Post
Black FreeIMU and black Promini on a black board:
The Promini is from DFRobot and works well. There are just 2 things to consider:
1. FTDI pin header is inverted so don't simply solder 90° angled pins or your FTDI breakout won't fit
2: A4 and A5 are not exactly in line with the board. Normal pins would lead to tension so better use copper wire.
black is beautiful nice and clean build tilman
warthox is offline Find More Posts by warthox
Old Oct 07, 2011, 02:56 AM
warthox is offline
Joined Aug 2009
Originally Posted by kinderkram View Post
Bllll!
Trying to make fun of me ole geezer, eh?
I'm still learning. Let's say in 20 years I'll be there where you were when you were young.
i just wanted to say that u work to much; u should fly more
Originally Posted by jevermeister View Post
What does "Empty" mean here? How low are you going with the voltage?
I try not to harm my Lipos by setting the LIP alarm to a very High value but sometimes my charger puts 2200mAh into the Lipo, so it was totally depleted.
I should test the powermeter.
Nils
empty means that the quad is not able to fly anymore as paul said. see the end of the video when i picked it up at the end, i gave full throttle; nothing happens, this is empty
mwc quad // flyduino 8" cf prop testflight no2 (2 min 45 sec)
Old Oct 07, 2011, 03:02 AM
Katch is offline
Find More Posts by Katch
FC flux'd
Katch's Avatar
Joined Jan 2007
Any reason for emptying the LiPo? Surely this just damages the pack.
Katch is offline Find More Posts by Katch
Old Oct 07, 2011, 03:07 AM
aBUGSnightmare is offline
Find More Posts by aBUGSnightmare
Joined Jul 2011
Hi Tilmann,
correct me if I'm wrong, but isn't this board running on 8MHz only? What cycle time will this result in (since this will give you only 8 MIPS instead of 16 MIPS when running on 16MHz)?
Rgds
aBUGSworstnightmare
aBUGSnightmare is offline Find More Posts by aBUGSnightmare
Old Oct 07, 2011, 03:09 AM
jevermeister is offline
Find More Posts by jevermeister
jevermeister's Avatar
Deutschland, SH, Kiel
Joined Jul 2011
Yeah,
I am not sure if this is too offtopic, but is it to far if my Charger says Capacity reached?
How do you guys time your flights?
I have two voltage limits but seconds after reaching the first I have to land or I deplete the LiPo totally.
Nils
jevermeister is offline Find More Posts by jevermeister
Old Oct 07, 2011, 03:24 AM
Katch is offline
FC flux'd
Katch's Avatar
Joined Jan 2007
I use a low voltage alarm and land as soon as it goes off. This seems to take my packs down within a safe range and I get good flight times.
warthox is offline
Joined Aug 2009
more flighttime - more fun
i fly till i feel that i loss power. in the case in the video i made it till the bitter end. normally i land when i feel the powerloss otherwise some seconds later the copter starts a autonomous landing
ive set a timer in my tx. depending on flightstyle i know about how long i can fly. in the cf prop test i flew almost always with full throttle to load the props most so i had no clue when the battery would be empty.
Old Oct 07, 2011, 03:25 AM
Joined Jul 2011
I use that to, but as I said - there are seconds between the two levels, I think I have to adjust the levels
Nils
Old Oct 07, 2011, 03:26 AM
Katch is offline
FC flux'd
Katch's Avatar
Joined Jan 2007
heh a good response.
Katch is offline
FC flux'd
Katch's Avatar
Joined Jan 2007
Nils
This could just be because LiPo have a steep voltage drop off at the end of their cycle.
Old Oct 07, 2011, 05:10 AM
It wasn't me
r0sewhite's Avatar
Augsburg, Germany
Joined Mar 2010
I knew you would like it, Markus.
Since it's raining, I hovered it indoor a first time. Man, I could get used to the 10" sound.
Originally Posted by aBUGSnightmare View Post
Hi Tilmann,
Rgds
aBUGSworstnightmare
Hi Jörg,
there is a 16MHz version, too. I found it on eBay last week when Paul gave me a hint. Cycletime is normal, about 3200.
Old Oct 07, 2011, 06:06 AM
monsterplay is offline
Find More Posts by monsterplay
Deutschland, HB, Bremen
Joined Aug 2011
Hallo aBUGSnightmare,
have you got a picture, that i can see the conection from the free imu to the board?
I have the new free imu and there is no pin for the 5V, only 3,3. i don't now if i can use another pin for the regulator?
I use the flyduinoboard with the flydusense 1 or 2
Thank you
Michael
monsterplay is offline Find More Posts by monsterplay
Old Oct 07, 2011, 07:26 AM
Nelapaty is online now
Find More Posts by Nelapaty
KK4NZS
Nelapaty's Avatar
Virginia
Joined Sep 2006
Ok where are you guys getting your free imu's???.. any links or free imus ae appreciated
Nelapaty is online now Find More Posts by Nelapaty
New Product Please let me introduce myself jimaquo Dock Talk 7 Oct 27, 2010 02:27 AM
Let me introduce the DEMON!!!! (Transparent covering and eliptical wing!!!) modest-master Sport Planes 7 Aug 25, 2002 11:46 PM
Let me introduce Angelis 280/400, Benjamin, Zombi (ARFs) modest-master Parkflyers 17 Mar 14, 2002 01:20 PM
Let me introduce the "NIKE" modest-master Electric Sailplanes 3 Mar 07, 2002 05:20 AM
