Old Oct 06, 2011, 12:06 AM
jonnypaletta is offline
Find More Posts by jonnypaletta
Switzerland
Joined Jun 2011
@ Paul,
why not propose a frame for HEXA and TRI traditional?
jonnypaletta is offline Find More Posts by jonnypaletta
Old Oct 06, 2011, 05:09 AM
warthox is offline
Find More Posts by warthox
Joined Aug 2009
Originally Posted by Morphin View Post
And Warthox your feedback about the MT3506 and the big prop? I'm planning to use 4S and 13x4 or the 12x4.5 from Paul that you testet also.
So which one should i try first?
Andy
with the apc sfp 14x4.7 i have of course more thrust. i lifted 2kg of payload. i use 3s. after normal flying the motors are cold.
for 4s the 12x4.5 could be enough. but u have to test it on your copter.
Originally Posted by Goofy23 View Post
Warthox as always, heavy stuff, full throttle all the time
Btw.
New Flyduinos arrived!
on www.flyduino.com
Originally Posted by kinderkram View Post
Woaaahhh!
I bow down for some moves never seen before. The CF props #2 is outstanding. I mean moves like at 0.42 - 0.44 - looks like dancing.
Also: those full stops at high speed into a hover or a flip. Great!
Found a new favorite toy, eh?
yep, allready came back to just watch the videos from markus, he is unbelievable and the sound is unique, he have a own style, markus dont you want to try to compose some music in flight?, some simple melody will be enough
thanks guys
flighttime was arround 3:30min till battery was completely empty. full throttle for 90% of the flying time calls for his victims
warthox is offline Find More Posts by warthox
Old Oct 06, 2011, 05:15 AM
kinderkram is offline
Find More Posts by kinderkram
OS Sponsor
kinderkram's Avatar
Germany, NRW, Dusseldorf
Joined Jun 2010
At least it was 3.30min of pure fun - and not 5min of boredom if I had flown that beast.
kinderkram is offline Find More Posts by kinderkram
Old Oct 06, 2011, 05:17 AM
warthox is offline
Joined Aug 2009
crashs can be very entertaining, too
Old Oct 06, 2011, 06:58 AM
OS Sponsor
kinderkram's Avatar
Joined Jun 2010
Bllll!
Trying to make fun of me ole geezer, eh?
I'm still learning. Let's say in 20 years I'll be there where you were when you were young.
Old Oct 06, 2011, 11:40 AM
Goofy23 is offline
Find More Posts by Goofy23
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
Originally Posted by jonnypaletta View Post
@ Paul,
also planned
Goofy23 is offline Find More Posts by Goofy23
Old Oct 06, 2011, 11:44 AM
jevermeister is offline
Find More Posts by jevermeister
jevermeister's Avatar
Deutschland, SH, Kiel
Joined Jul 2011
thanks guys
What does "Empty" mean here? How low are you going with the voltage?
I try not to harm my Lipos by setting the LIP alarm to a very High value but sometimes my charger puts 2200mAh into the Lipo, so it was totally depleted.
I should test the powermeter.
Nils
jevermeister is offline Find More Posts by jevermeister
Old Oct 06, 2011, 11:49 AM
Switzerland
Joined Jun 2011
also planned
And OCTO
Old Oct 06, 2011, 03:01 PM
Goofy23 is offline
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
Nils
?? he simply flew till it fall from the sky??
Old Oct 06, 2011, 03:06 PM
Switzerland
Joined Jun 2011
@Paul,
you can add the dimension of the arm for the flyduspider with 10" Propellers in your shop?
I have added 5cm for mount 10" propellers in my FLYDUSPIDER, but i don't know if the geometry it's compromised...
Old Oct 06, 2011, 03:43 PM
r0sewhite is offline
Find More Posts by r0sewhite
It wasn't me
r0sewhite's Avatar
Augsburg, Germany
Joined Mar 2010
Black FreeIMU and black Promini on a black board:
The Promini is from DFRobot and works well. There are just 2 things to consider:
1. FTDI pin header is inverted so don't simply solder 90 angled pins or your FTDI breakout won't fit
2: A4 and A5 are not exactly in line with the board. Normal pins would lead to tension so better use copper wire.
r0sewhite is offline Find More Posts by r0sewhite
Goofy23 is offline
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
it is compromised...but it may work good, i heard of it, Hubibubi did it too.
Well but 8" is a good size for the spider, nice sportscar then.
Old Oct 06, 2011, 04:20 PM
Switzerland
Joined Jun 2011
Paul,
in your spider the front propellers are 2.5cm/3cm up on the frame, this induce turbolence and vibration, my friend have tried to add 2cm on the front arms and the vibration it's decreased.
Do you know this problem on your frame?
How it's possible resolve this turbolence problem?
How i can calculate the correct lenght for the arms? (10" propellers?)
I like this frame, but the front arms are too small (this it's my opinion)
Old Oct 06, 2011, 04:29 PM
It wasn't me
r0sewhite's Avatar
Augsburg, Germany
Joined Mar 2010
Turbolences are only one fact. Another one is the length of the arms. The longer they are, the more vibrations you will have. On the flyduspider you will notice that the front arms will not vibrate while the long rear arms will badly vibrate.
Old Oct 06, 2011, 05:14 PM
bob4432 is offline
Find More Posts by bob4432
bob4432's Avatar
United States, AZ, Phoenix
Joined May 2010
Looking good. What escs and what size hs tubing did you use on them?
bob4432 is offline Find More Posts by bob4432
New Product Please let me introduce myself jimaquo Dock Talk 7 Oct 27, 2010 02:27 AM
Let me introduce the DEMON!!!! (Transparent covering and eliptical wing!!!) modest-master Sport Planes 7 Aug 25, 2002 11:46 PM
Let me introduce Angelis 280/400, Benjamin, Zombi (ARFs) modest-master Parkflyers 17 Mar 14, 2002 01:20 PM
Let me introduce the "NIKE" modest-master Electric Sailplanes 3 Mar 07, 2002 05:20 AM
