Old Oct 02, 2011, 09:17 PM
Goofy23 is offline
Find More Posts by Goofy23
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
this is what i suggest
Goofy23 is offline Find More Posts by Goofy23
Old Oct 03, 2011, 02:23 AM
Frank.T is offline
Find More Posts by Frank.T
Frank.T's Avatar
Netherlands, NH, Amsterdam
Joined Jul 2010
After my trip to Cuba I will order this board and try it.
Both Atmel sensors and Fabio 35MS board work great.
They use almost the same sensors but the Atmel is a tiny bit more stable on the Gyro and ACC (noise?), where the FreeIMU 0.3.5MS baro is some better.
//Frank
Frank.T is offline Find More Posts by Frank.T
Old Oct 03, 2011, 04:55 AM
JUERGEN_ is offline
Find More Posts by JUERGEN_
xxxxxxxxxxxxx
JUERGEN_'s Avatar
Deutschland
Joined Nov 2009
Originally Posted by aBUGSnightmare View Post
heute will ich euch einen neuen Flightcontroller – das DIVIDE et IMPERA! V2 – vorstellen. Die Leiterplatte wird Paul in Kürze in seinem Shop (www.flyduino.com) haben!
schön hier auch mal etwas in deutsch zu lesen.
verschwindet allerdings sehr schnell in den tiefen des Datenmülls.
noch besser wäre es in einem PAUL-WIKI zu übertragen ?
als PDF-Dokumentation wäre es natürlich auch geil,
und in Pauls Shop, mit Link auf die Dokumentationen.
JUERGEN_ is offline Find More Posts by JUERGEN_
Old Oct 03, 2011, 05:55 AM
CaLviNx is online now
Find More Posts by CaLviNx
not surprised.........
CaLviNx's Avatar
Cyprus, Ammochostos, Liopetri
Joined Jan 2005
lets stay together
And in English to allow everyone to participate in the thread
There is some very good information to read in German.
But it disappears very quickly into the depths of the other garbage posted.
It would be even better if the relevant information was transferred and available in a Wiki, what about it Paul ?
Also PDF documentation would be cool,
and if it was located in Paul's shop, with links to the documentation, for all to find, would make it even better
I can only agree with most of this.
But it would have been nice and more community spirited if you have posted the same as "aBUGSnightmare" did with English too, (as from some of your other posts your appear capable of posting in English) and nicer to not initially close your post to only a few, as most use the international language of English....
And yes I can speak English, Gaelic a little German, Thai & Greek so im not just picking on the one language.
lets keep the community together and not try to introduce a divide. Hence my attempt/reason for translating it for everyone.
kindest regards
CaLviNx is online now Find More Posts by CaLviNx
Old Oct 03, 2011, 07:21 AM
jevermeister is offline
Find More Posts by jevermeister
jevermeister's Avatar
Deutschland, SH, Kiel
Joined Jul 2011
There is alreay w multiwii wiki with a hardware section.maybe we could add this there
jevermeister is offline Find More Posts by jevermeister
Old Oct 03, 2011, 07:25 AM
aBUGSnightmare is offline
Find More Posts by aBUGSnightmare
Joined Jul 2011
Originally Posted by Goofy23 View Post
ok, i have also almost some stickers finished, we may should merge the result.
Allready optimizing it a bit, till now i got stickers for quad + x, tri, Y6, thinking of doing 2 extra ones for x and + hex, as i printed CW and CCW on it.
Paul,
perfekt! I think you should keep em! I only had Y4 and BI in addition.
Joerg
aBUGSnightmare is offline Find More Posts by aBUGSnightmare
Old Oct 03, 2011, 07:28 AM
Joined Jul 2011
Hi Juergen,
It's no problem to have a PDF document on it once the docu is finished. Paul can link to this on the product page.
Joerg
Old Oct 03, 2011, 08:29 AM
fax8 is offline
Find More Posts by fax8
Fabio Varesano
fax8's Avatar
Torino, Italy
Joined Jan 2011
Are you sure about this? FreeIMU uses the BMA180 which should be better than the BMA150 used in ATMEL boards. FreeIMU also uses the ITG3200 gyroscope, also used on the ATMEL boards. The HMC5883L used in FreeIMU, should be quite better than the AK8975 of ATMEL... So, on paper, FreeIMU v0.3.5 should be superior than ATMEL boards.
Have you actually compared these two boards? Results of such tests would be pretty interesting to me.
fax8 is offline Find More Posts by fax8
Old Oct 03, 2011, 09:59 AM
funfox is offline
Find More Posts by funfox
Joined Sep 2011
Still having problems with the ACC. Mostly when I like to start the copter in ACC mode, the copter goes directly in a 30° possition, so I have to brakeup the starting or risk the copter will go overhaed while starting. If I switsh off the ACC mode the copter will rise normal with a bit sidewards flying.
Why will the copter lift only one side by starting under ACC??? If I controll the GUI the ACC will shows 0/0/254. Do the BMA020 need a way sidewards to find the horizontal?!?
funfox is offline Find More Posts by funfox
Old Oct 03, 2011, 10:06 AM
Goofy23 is offline
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
yes technically the freeimu is better.
The 3200 is the same on both, the bma150 shouldnt behave that different compared to bma180.
The HMC mag on the freeimu is technically better.
Only thing which can be dfferent is the power supply.
Frank went over 2 linear regulators when using his Atmel board.
3.3V is supplied by a reg. from the sensor bob, the Atmel ATAVRSBIN1 have a own 2.5V reg aditionally (LP2985A).
The more linear regulator the better, the more clean/decoupled the power will be.
May this one reg more is doing a difference frank sees ?
You imu connected the same way should give similar results, means using a 2.5V low drop on the imu supplied by a 3.3V in front?
Old Oct 03, 2011, 10:25 AM
Goofy23 is offline
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
@ Jürgen, this is not the place here for german, but as you saw Joerg is doing it biligual.
There will be also at least a PDF to download.
We also may start a Flyduino Wiki page soon where we can add things like this.
For the stickers, i run a bit out of space, i thing a BI the user may can fuggure out himself, for the Y4 i am sorry but its exactly like the X Quad, so.....
Old Oct 03, 2011, 10:26 AM
Goofy23 is offline
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
May the PID settings have to be tweaked when the ACC overreact.
Old Oct 03, 2011, 10:28 AM
fax8 is offline
Fabio Varesano
fax8's Avatar
Torino, Italy
Joined Jan 2011
I'm not really sure about this.... all depends on the implementation (components, circuits, etc..)
Old Oct 03, 2011, 10:29 AM
fax8 is offline
Fabio Varesano
fax8's Avatar
Torino, Italy
Joined Jan 2011
@funfox You have to calibrate your level mode http://www.multiwii.com/faq#How_to_t...n_1.7_and_more
Old Oct 03, 2011, 11:19 AM
Katch is offline
Find More Posts by Katch
FC flux'd
Katch's Avatar
Joined Jan 2007
@Paul
Same old questions I know but...
When are the Flyduino Mega back in stock? and... how long till GPS?
Katch is offline Find More Posts by Katch
New Product Please let me introduce myself jimaquo Dock Talk 7 Oct 27, 2010 03:27 AM
Let me introduce the DEMON!!!! (Transparent covering and eliptical wing!!!) modest-master Sport Planes 7 Aug 26, 2002 12:46 AM
Let me introduce Angelis 280/400, Benjamin, Zombi (ARFs) modest-master Parkflyers 17 Mar 14, 2002 02:20 PM
Let me introduce the "NIKE" modest-master Electric Sailplanes 3 Mar 07, 2002 06:20 AM
