Old Aug 28, 2011, 09:54 PM
Goofy23 is offline
Find More Posts by Goofy23
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
you got a pm
Goofy23 is offline Find More Posts by Goofy23
Old Aug 28, 2011, 09:55 PM
Goofy23 is offline
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
alu arms are in the shop
Old Aug 29, 2011, 02:16 AM
flow23 is offline
Find More Posts by flow23
Deutschland
Joined Jul 2011
Looking good
flow23 is offline Find More Posts by flow23
Old Aug 29, 2011, 07:58 AM
berkely is offline
Find More Posts by berkely
berkely's Avatar
Belgium, Flemish Region, coast
Joined Nov 2009
Great work Berkely, thanks.
Very good to see, only thing may missing is the I2C row, what do you think.
Oh and after you cleared the things so well.
I will give a little confusion, i skiped the D37 on Flyduino 2.1 and put a 3.3V in place of the D37, so we have the 3.3V also on the I2C.
let's get this through pm
berkely is offline Find More Posts by berkely
Old Aug 29, 2011, 12:58 PM
Goofy23 is offline
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
this 450 skid fits well.
This fixed version works well, but a non fixed may better.
But this one works much better then i look like as the clamp clamps nicely, 2 zip ties and you are ready.
Old Aug 29, 2011, 04:14 PM
warthox is offline
Find More Posts by warthox
Joined Aug 2009
mine with trex 500 lg..
warthox is offline Find More Posts by warthox
Old Aug 30, 2011, 12:25 AM
st99 is offline
Find More Posts by st99
st99's Avatar
United States, PA, Uniontown
Joined Jan 2005
500 gear
Looks good.
On the Flyduspider I went with the 500 align gear also. Looks just right. Not too much extra weight.
Sorry for the bad quality pic.------cheap camera.
st99
st99 is offline Find More Posts by st99
Old Aug 30, 2011, 08:18 AM
claustro is offline
Find More Posts by claustro
Joined Aug 2011
Sorry guys for the very noob question but I am becoming made with connection.
I am totally new of elettric rc world so I 'd need some basic explanation on how connect Motor - ESC - Lipo - BEC - Flyduino - Receiver
the only thing I know is what is show in this photo were I have to insert flyduino pcb?
what kind of connector are needed?
Please be patience with me I am trying to learn as fast as i can :-(
claustro is offline Find More Posts by claustro
Old Aug 30, 2011, 08:23 AM
jevermeister is offline
Find More Posts by jevermeister
jevermeister's Avatar
Deutschland, SH, Kiel
Joined Jul 2011
Whoaa good one, last year I asked questions like this too, but only in private... ;-)
Thats no Problem - just kidding. You have to connect the flyduino to the input of the ESC you normally connect to the rx, and the rx to the flyduino. Just look at the beginning of this thread, this explains a lot, if you have further questions, feel free to pm me, I may help u.
Nils
jevermeister is offline Find More Posts by jevermeister
Old Aug 30, 2011, 10:02 AM
whiteturbo is offline
Find More Posts by whiteturbo
Registered MisUser
whiteturbo's Avatar
Bristol UK
Joined Oct 2009
Hiya,
We all had the same questions in the begining and it wasnt easy to answer then, but now we have the flyduino thanks to paul and it makes everything a lot easier.
Basicaly each motor has an ESC(electronic speed controller) connected through the end with three thickish wires, the end with two thickish wires is your power input a + and a -
the servo style connector is connected to the flyduino where it says motor 1, motor 2 etc.
Your receiver is connected where it says throttle pitch roll yaw etc.
That is basically it, but you need to read a fair bit to understand which motor goes where and how to arrange the power supply etc.
It takes a bit of learning especially if you dont have an electronic background(im a carpenter) but that is part of the enjoyment of building and flying multies so just take your time and ask if in doubt.
They are generally a friendly lot on this forum and have all been where you are now so most are willing to help if you ask.
And finally Welcome to the world of Multicopters
Ray
whiteturbo is offline Find More Posts by whiteturbo
Old Aug 30, 2011, 10:45 AM
Goofy23 is offline
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
@ST99 i have exact the same skid here waiting for my spider
Thaks for helping me out guys, very nice.
Old Aug 30, 2011, 11:27 AM
st99 is offline
st99's Avatar
Joined Jan 2005
Modify
Paul,
For my future build, Do you think that your quad frame could be modified to make it a Tricopter frame.?
I would order that quad kit/alum tubes and drill 2 holes for the rear part of the frame and insert aluminum leg to fit the quad frame.? --result is a tricopter frame.
I really like the quality of your frame parts.
st99
Old Aug 30, 2011, 11:39 AM
claustro is offline
Joined Aug 2011
Originally Posted by whiteturbo View Post
Hiya,
ok so
the 3 pin connector from esc go where it say motr 1 2 3 4 5 6 according to the scheme ( tri quad octo ecc) in my case quad x shaped
Front right to 5
Rear right to 3
Rear left to 6
Front left to 2
The motors connection rack is composed by 3 pin for red black and yellow line, if I am using an external bec so I suppouse I can use only the black and red wire and leave without pin the middle line of pin marked as NC, is it ok?
So black on GND red on 13 and nothing on NC Is this correct?
what are used for serial 1 and serial 2?
Where I have to connect the BEC 5volts?
Have I to connect the red wire of battery on the IN pin ( 12 volts) also if I will use a separate bec?
in the lower right part ther are six pin ( CAM Gimbal) what are they used for?
I am still waiting the receiver ( economic turnigy x9) , so I don't know what kind connection it has, where i can take the power for it?
THANK YOU FOR YOUR PATIENCE !!!
Old Aug 30, 2011, 02:10 PM
Joined Jul 2011
Great,
today the mailman was my Santa Clause.
two Parcels from Paul,with new Flyduinos, Flydubutioon, and Flydusenses, props and stuff
A Parcel from HK with my new Lipos
a parcel from eBay with the new motors.
Brought my GFK to the milling man to mill me a new frame.
The arms are ready, the motors and ESCs are wired.
I am on my way to a nDROiiD junior...
Nils
Hurry up HK China: I need my new RX
Old Aug 30, 2011, 02:20 PM
warthox is offline
Joined Aug 2009
testing different things with the mwc fw 1.8 on a quad with flyduino mwc board + freeimu ms.
0:34 low altitude aerobatics
1:30 acc emergency activation
2:11 frisbee
mwc quad // mixed fw 1.8 stuff (3 min 2 sec)
New Product Please let me introduce myself jimaquo Dock Talk 7 Oct 27, 2010 02:27 AM
Let me introduce the DEMON!!!! (Transparent covering and eliptical wing!!!) modest-master Sport Planes 7 Aug 25, 2002 11:46 PM
Let me introduce Angelis 280/400, Benjamin, Zombi (ARFs) modest-master Parkflyers 17 Mar 14, 2002 01:20 PM
Let me introduce the "NIKE" modest-master Electric Sailplanes 3 Mar 07, 2002 05:20 AM
