Old Aug 16, 2011, 03:05 AM
jevermeister is offline
Find More Posts by jevermeister
jevermeister's Avatar
Deutschland, SH, Kiel
Joined Jul 2011
Hi,
I am experimenting with flight time right now and I wonder, ho much mAh you take out of your LiPos?
I got 2200mAh LiPos, how many mAh is good for the LiPo?
What is your experience?
Nils
jevermeister is offline Find More Posts by jevermeister
Old Aug 16, 2011, 05:33 AM
alteskind is offline
Find More Posts by alteskind
Deutschland, Schleswig-Holstein, Kiel
Joined Jan 2011
Originally Posted by Warres1 View Post
I did not have access to a scope, so I used the DMM to verify a voltage. When you say look for mounting points, do you mean the transmitter settings? The Arduino code under the rc functions has mincheck 1100 and maxcheck 1900. Sorry I don't understand all the rc and Arduino terminology, I am new to this hobby. I will do more research and talk with the guy at the hobby store. He has a Gaui with a Spektrum radio. Thank you very much for your comments.
Motors can not start
Calibration of the ACC was not done in the GUI
Gas value of 1100 (the GUI control)
D / R set in the transmitter, so you do not roll or YAW reach 1100 to 1900
Intrinsic calibration after connecting the battery, wait no (green LED still flickering)
No connection between the receiver and MWC Board
YAW and / or roll side rotated (reversed)
Excerpt from microcopters.de
I was able to calibrate the system in the MultiWiiConf1_7 software. I could see the signals on the screen as I moved the quad.
The transmitter does have a D/R Expo setting. I have left this in the default setting.
When I applied power to the quad I waited for the flashing light to stop before moving or turning on the transmitter. The quad was level when I turned on power.
The roll and yaw appear to be correct based on my movements of the quad and the movements in the Conf tool. I did notice that there is a setting to reverse the yaw direction.
Kind Regards,
Steven Warren
mincheck + maxcheck are used by arduino to check if your sticks on Tx are in end-positions.
if you dont reach 1100 and 1900 in GUI by moving your sticks to their end-points, the motors cant be started.
this is, because the arduino still "thinks", that sticks are not in their end-position.
in case you dont reach the 1100/1900 in GUI there are 2 possible solutions:
1. if your Tx has Endpoint adjustment, u have to put throw to 120 or 125%, in order to let the arduino know, that your sticks are in end-position.
after doing that do not forget to calibrate your ESCs again to the new range.
2. one other possibility is to edit mincheck /maxcheck in arduino sketch to a point your Tx rcan reach. ( i did it for my cheap HK Tx to 1180 and 1750. it works, but may affect other functions, shorter throw wont make control of copter easier ....)
alteskind is offline Find More Posts by alteskind
Old Aug 16, 2011, 05:50 AM
Katch is offline
Find More Posts by Katch
FC flux'd
Katch's Avatar
Joined Jan 2007
Originally Posted by jevermeister View Post
Hi,
Nils
You want to check the pack with a multimeter after flying and make sure it isn't discharging below 3v per cell (S number x 3) - this voltage is the same regardless of the rate mah of the pack.
Also as a general rule you should take out no more than 80% of the batteries capacity. So a 2000mah pack should be discharged 1600mah. Your computerized charger will show you how many mah the pack takes when fully charged.
General LiPo care charge to no more than 4.2v per cell - (so 3s is 12.6v fully charged) and never discharge lower than 3v per cell. I like to keep my 3s packs closer to 10.5v volts after discharge as dropping to 9v all the time will shorten the life of the pack.
Katch is offline Find More Posts by Katch
Old Aug 16, 2011, 07:13 AM
aBUGSnightmare is offline
Find More Posts by aBUGSnightmare
Joined Jul 2011
Hi Paul,
the new sensor BOB looks great (very similiar to my DIVIDE et IMPERA! board ):
Any news on the flyduspider arms?
aBUGSworstnightmare
P.S. By the way: I like the FLYDUSPIDER name! Sry, can't understand the hype about 6 or 8 'legs'
Originally Posted by Goofy23 View Post
sorry guys really busy atm.
The spider looks cool! similar leg orientation then the Flyduspider.
Also know the only german name, whats the dutch for it?, but may wont sound cool (at least the german wont "weber"), i will stay with the Flyduspider.
Some more before i fall to bed.
This is a TO-92 3.3V voltage regulator on warthox MWC Board.
Its a LE33CZ a L78L33 will do also, almost all in in TO92 should do.
The new sensor bob arrived, but i am afraid i wont have more time to test and solder it today.
Will be done tomorrow, also will be added in the shop tomorrow.
This picture shows the allready mounted damping.
The board is for all sensors avaiable, some can be mounted almost plug n play.
Also some more features on it, more tomorrow.
aBUGSnightmare is offline Find More Posts by aBUGSnightmare
Old Aug 16, 2011, 07:15 AM
Joined Jul 2011
me neither!
Love the name...
Old Aug 16, 2011, 09:28 AM
kinderkram is offline
Find More Posts by kinderkram
OS Sponsor
kinderkram's Avatar
Germany, NRW, Dusseldorf
Joined Jun 2010
me neither!
Love the name...
Spiderman has only 2 legs and has become world famous - so what?
While we're into it: I like the design and the name of this guy.
It's a wolf spider "Pirata Montanus"
kinderkram is offline Find More Posts by kinderkram
Old Aug 16, 2011, 10:58 AM
st99 is offline
Find More Posts by st99
st99's Avatar
United States, PA, Uniontown
Joined Jan 2005
Flyduspider 8
Nice pic Kindergram.
Now you have me thinking about making a Flyduspider 8. That would look and really sound good. The rear legs on that spider in the pic stretches out like the original Flyduspider.
Hmmmmm, Flyduspider 6 and a Flyduspider 8. Sounds good to me.
st99 is offline Find More Posts by st99
Old Aug 16, 2011, 12:27 PM
jonnypaletta is offline
Find More Posts by jonnypaletta
Switzerland
Joined Jun 2011
@Paul, I preferred the square version of Flydusense...
QuadX frame, square Flyduino and round Flydusense
I love your square black boards... and wait for GPS BOB (if possible square and black )
jonnypaletta is offline Find More Posts by jonnypaletta
Old Aug 16, 2011, 01:33 PM
hubibubi is offline
Find More Posts by hubibubi
hubibubi's Avatar
Deutschland, SA
Joined May 2011
Trick
Hello Warthox,
You fly like a crazy, when the may say so, I love it.
When I look at your flight controllers I've noticed several times that you have not soldered pins with which you program the trick then, laboratory clamps?
Thank hubibubi
hubibubi is offline Find More Posts by hubibubi
Old Aug 16, 2011, 04:07 PM
Goofy23 is offline
Find More Posts by Goofy23
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
no prob, will have both bobs, its just a option.
Oh yes very similar to yours nightmare, you are right, great board, nice printing.
Goofy23 is offline Find More Posts by Goofy23
Old Aug 16, 2011, 04:09 PM
Goofy23 is offline
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
will be back into copters tomorrow, today was too long cant answer on all atm.
Old Aug 16, 2011, 11:51 PM
Warres1 is offline
Find More Posts by Warres1
Joined May 2011
Thank you for the information on the min/maxcheck function. Once I changed the setting on the transmitter to reach the 1100/1900 values the motors started working. Unfortunately I then ran low on voltage from the battery and then the sensors went crazy. I will charge the battery and complete the calibration.
Thanks again to everyone for all the information. I can't wait to get this flying.
Kind Regards,
Steven Warren
Warres1 is offline Find More Posts by Warres1
Old Aug 17, 2011, 06:06 AM
Joined Jul 2011
Hi there,
just got the shipping confirmation of my BMA020 order from ELV!
They seem to have stock again (website says they can ship ex stock again; got a letter from them yesterday, telling me that my order will ship in KW46 ).
--> I think Paul will also have stock again soon!
Rgds
aBUGSworstnightmare
Originally Posted by M4d_D View Post
hi,
what about the bma020 in your shop paul ? dont you sell them anymore ?
cheers
Old Aug 17, 2011, 06:32 AM
Goofy23 is offline
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
Thanks!
yep, ordered quite some, hope to have em soon.
Old Aug 17, 2011, 10:18 AM
Goofy23 is offline
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
i think the Flyduspider stays the Flyduspider, it s a unique name, at least, and most copter fliers are no biologist i think.
New Product Please let me introduce myself jimaquo Dock Talk 7 Oct 27, 2010 02:27 AM
Let me introduce the DEMON!!!! (Transparent covering and eliptical wing!!!) modest-master Sport Planes 7 Aug 25, 2002 11:46 PM
Let me introduce Angelis 280/400, Benjamin, Zombi (ARFs) modest-master Parkflyers 17 Mar 14, 2002 01:20 PM
Let me introduce the "NIKE" modest-master Electric Sailplanes 3 Mar 07, 2002 05:20 AM
