Old Aug 15, 2011, 01:11 AM
Goofy23 is offline
Find More Posts by Goofy23
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
to me it sound like a mounting problem, to ,measure the pwm signal can be difficult with a regular multimeter as its a PWM signal, but you meassured a voltage, thats good.
Please have a look for the mounting points 1100 and 1900.
Set yout TX to 125% to have more range.
Goofy23 is offline Find More Posts by Goofy23
Old Aug 15, 2011, 02:03 AM
flow23 is offline
Find More Posts by flow23
Deutschland
Joined Jul 2011
Originally Posted by Goofy23 View Post
yep ok, right kinderkram allready said it, a spider have 8 legs.
Hmm, i wouldnt have a problem with another name, will see.
Oh btw. i had studied biology, but only for a half year.....so
Add the two "legs" from the landing gear and you have your spider :=
flow23 is offline Find More Posts by flow23
Old Aug 15, 2011, 10:01 AM
hubibubi is offline
Find More Posts by hubibubi
hubibubi's Avatar
Deutschland, SA
Joined May 2011
Originally Posted by Warres1 View Post
After many weeks I have finally completed my quad build. I currently have MultiWii 1.7 loaded in Flyduino v2.0 board. The only problem is that the motors will not spin. I have checked that the motors and ESC are functional by connecting each to the receiver Throttle port. I then connected the quad to the computer using a USB cable and FTDI, launched MultiWiiConf 1.7 and was able to see that all transmitter functions were working correctly. I measured the PWM pin for each motor port (2,3,5, and 6) and it measured 2.5V with a DMM. I am not sure what should be checked next. Can anyone provide any ideas.
Kind Regards,
Steven Warren
Flyduino v2.0, Flybution, Flydusense with BMA020 and WM+, Castle Thunderbird ESC, Eflite Park 370, Spektrum DX8 and AR8000
Motoren lassen sich nicht starten
· Kalibrierung von ACC wurde in der GUI nicht vorgenommen
· Gaswert über 1100 (in der GUI kontrollieren)
· D/R im Sender eingestellt, so dass YAW oder Roll nicht 1100 bis 1900 erreichen
· Eigenkalibrierung nach Anschließen des Akkus nicht abgewartet (grüne LED flackerte noch)
· Keine Verbindung zwischen Empfänger und MWC-Board
· YAW und/oder Roll seitenverdreht (reversed)
Auszug von microcopters.de
Motors can not start
· Calibration of the ACC was not done in the GUI
· Gas value of 1100 (the GUI control)
• D / R set in the transmitter, so you do not roll or YAW reach 1100 to 1900
· Intrinsic calibration after connecting the battery, wait no (green LED still flickering)
• No connection between the receiver and MWC Board
· YAW and / or roll side rotated (reversed)
Excerpt from microcopters.de
hubibubi is offline Find More Posts by hubibubi
Old Aug 15, 2011, 10:36 AM
alteskind is offline
Find More Posts by alteskind
Deutschland, Schleswig-Holstein, Kiel
Joined Jan 2011
nice
fehlt nur noch:
der copter steht zu stark geneigt, oder der gyro gaukelt das vor
missing
copter is not levelled
alteskind is offline Find More Posts by alteskind
Old Aug 15, 2011, 11:03 AM
whiteturbo is offline
Find More Posts by whiteturbo
Registered MisUser
whiteturbo's Avatar
Bristol UK
Joined Oct 2009
Hiya,
Bought a new DX8 to go with my Flyduspider and am unsure about a couple of things
Do i have to recalibrate my esc's and should throttle trim be in the middle or bottom like a heli.
(i did ask this in the multiwii forum first but the first question wasn't answered and ide like a concensus on the second)
Ray
whiteturbo is offline Find More Posts by whiteturbo
Old Aug 15, 2011, 02:12 PM
st99 is offline
Find More Posts by st99
st99's Avatar
United States, PA, Uniontown
Joined Jan 2005
Some have 6 legs
Sorry guys, but some spiders have 6 legs and some also have 4 legs. Just for fun I did a google image search and found out this info.
st99
st99 is offline Find More Posts by st99
Old Aug 15, 2011, 02:38 PM
warthox is offline
Find More Posts by warthox
Joined Aug 2009
test of the new mwc fw 1.8 with the flyduino mega + ff imu from jussi.
pid settings are default.
0:03 - gyro only
0:54 - gyro, acc, mag
1:23 - mag test
1:47 - baro test
3:15 - acc test
3:31 - throw away
4:00 - pilot test
mwc quad - flyduino + ff imu (4 min 34 sec)
warthox is offline Find More Posts by warthox
Old Aug 15, 2011, 02:56 PM
wilco1967 is offline
Find More Posts by wilco1967
Winterswijk, Netherlands
Joined Jun 2007
st99
As kids, we used to pull out a few legs from a spider... Easier than modifying the number of legs on a Flyduspider.....
(or was it a long legged mosquito as we called them....mwhoa ....... who cares... same principle.....)
But now I come to look at it..... THIS already has 6 legs.....
Now what's the english name for this ? Does that sound better than Flyduspider ?
wilco1967 is offline Find More Posts by wilco1967
Old Aug 15, 2011, 03:56 PM
Gaza07 is offline
Find More Posts by Gaza07
Gaza07's Avatar
United Kingdom, England, Nottingham
Joined Nov 2002
That is a daddy long legs or thats what we used to call them when we were kids, have a look HERE
Gaza07 is offline Find More Posts by Gaza07
Old Aug 15, 2011, 04:03 PM
Goofy23 is offline
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
sorry guys really busy atm.
The spider looks cool! similar leg orientation then the Flyduspider.
Also know the only german name, whats the dutch for it?, but may wont sound cool (at least the german wont "weber"), i will stay with the Flyduspider.
Some more before i fall to bed.
This is a TO-92 3.3V voltage regulator on warthox MWC Board.
Its a LE33CZ a L78L33 will do also, almost all in in TO92 should do.
The new sensor bob arrived, but i am afraid i wont have more time to test and solder it today.
Will be done tomorrow, also will be added in the shop tomorrow.
This picture shows the allready mounted damping.
The board is for all sensors avaiable, some can be mounted almost plug n play.
Also some more features on it, more tomorrow.
Old Aug 15, 2011, 05:20 PM
mxspode is offline
Find More Posts by mxspode
If it flies, I will crash it
mxspode's Avatar
USA, CO, Westminster
Boards are looking good Paul. Surface mount makes good sense when you are having very large numbers produced by a board house but considering the state of affairs with the current Multicopter community and the constant addition of newer component parts TH just makes more sense in the long run. I for one am not offended by threw hole designs.
Nice work,
Rob...
mxspode is offline Find More Posts by mxspode
Old Aug 15, 2011, 05:22 PM
chris24g is offline
Find More Posts by chris24g
United States, CA, Hayward
Joined Apr 2006
st99
sorry, dude.
any spider that has less than 8 legs probably is really pissed at the kid who pulled 'em off.
Best Regards,
Peter Parker
chris24g is offline Find More Posts by chris24g
Old Aug 15, 2011, 05:52 PM
st99 is offline
st99's Avatar
Joined Jan 2005
Originally Posted by chris24g View Post
sorry, dude.
Best Regards,
Peter Parker
There was quite a few on google images. All my life I have heard that 6 legged spiders are not dangerous. Dont know for sure.
Go to google,click on images, then type in "6 legged spiders"---you will see them.
Either way, The "flyduspider" is the only spider that I like,!! ha ha
I am waiting for my (spider frame) to arrive. Probably another week it will arrive and I can start my build.
Take care,
st99
Old Aug 15, 2011, 09:43 PM
birdofplay is online now
Find More Posts by birdofplay
Retired CAD guy
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
since we cant seem to get off this Spider thang ...
a quick google of Daddy Long legs yeilds a Spider aka arachnid (8legs) vs insect (6 legs)
I'm sure there may be some localities that have some spindaly insects named Long Legs.
Actually MOST Spiders FLY, just not with wings !
birdofplay is online now Find More Posts by birdofplay
Old Aug 16, 2011, 12:05 AM
Warres1 is offline
Find More Posts by Warres1
Joined May 2011
I did not have access to a scope, so I used the DMM to verify a voltage. When you say look for mounting points, do you mean the transmitter settings? The Arduino code under the rc functions has mincheck 1100 and maxcheck 1900. Sorry I don't understand all the rc and Arduino terminology, I am new to this hobby. I will do more research and talk with the guy at the hobby store. He has a Gaui with a Spektrum radio. Thank you very much for your comments.
I was able to calibrate the system in the MultiWiiConf1_7 software. I could see the signals on the screen as I moved the quad.
The transmitter does have a D/R Expo setting. I have left this in the default setting.
When I applied power to the quad I waited for the flashing light to stop before moving or turning on the transmitter. The quad was level when I turned on power.
The roll and yaw appear to be correct based on my movements of the quad and the movements in the Conf tool. I did notice that there is a setting to reverse the yaw direction.
Kind Regards,
Steven Warren
Warres1 is offline Find More Posts by Warres1
New Product Please let me introduce myself jimaquo Dock Talk 7 Oct 27, 2010 02:27 AM
Let me introduce the DEMON!!!! (Transparent covering and eliptical wing!!!) modest-master Sport Planes 7 Aug 25, 2002 11:46 PM
Let me introduce Angelis 280/400, Benjamin, Zombi (ARFs) modest-master Parkflyers 17 Mar 14, 2002 01:20 PM
Let me introduce the "NIKE" modest-master Electric Sailplanes 3 Mar 07, 2002 05:20 AM
