Old Aug 13, 2011, 10:32 AM
M4d_D's Avatar
Joined Dec 2006
hi,
what about the bma020 in your shop paul ? dont you sell them anymore ?
cheers
M4d_D is offline Find More Posts by M4d_D
Old Aug 13, 2011, 10:44 AM
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
i will do when they are back in stock, last info was 13 weeks! so its may better to dont accept preorders.
Goofy23 is offline Find More Posts by Goofy23
Old Aug 13, 2011, 03:30 PM
M4d_D's Avatar
Joined Dec 2006
lol
one more thing : what about the prop sets , i like these props because they are very balanced and stiff
but i need 3 "normal" props for my tri , which would mean i need to buy two sets ... cant you sell single props ? i know that its difficult to store all these things but it would still be great
Old Aug 13, 2011, 04:18 PM
RTFM // copter damaged
warthox's Avatar
Joined Aug 2009
Originally Posted by r0sewhite View Post
Markus, aren't we nice guys?
we are
Originally Posted by Goofy23 View Post
yep agree, at least the summer here in germany is not beeing worth called summer, but, let me see, oh it seems its the sun out there shining, hope it will dry your swamp a bit Alteskind, the southern guys are allready out flying i guess.
i was flying the hole day
warthox is offline Find More Posts by warthox
Old Aug 13, 2011, 05:19 PM
hubibubi's Avatar
Deutschland, SA
Joined May 2011
my FlyduSpider
This time my FlyduSpider, for an original 8" propeller model next to a pimped for 10 inch propeller.
The larger model has a detachable mount GoPro. There were renewed only in accordance with the arms, thus not affecting the front surface and a camera I can top touched down. the regulator I have arranged in another plane, thus there is a frame from 3 plates.
10 inch spider, Premium 18A ESC, KDA 20-26M, 3S2200 LiPo, Flyduino FC v1.0 + Jussi 9DOF IMU 1.22L.
8 inch Spider: Keda ESC 12A, KDA 20-26M, 3S2200mAh, FC: Paris v3 9DOF 1.22L IMU or Flyduino with JussiH IMU
Soft is the current version v1.8 on it
Description: FlyduSpider 8" und 10"Name: CIMG3833.jpg
Description: 8" FlyduSpiderName: DSC_0076.jpg
Description: 10" FlyduSpider
hubibubi
hubibubi is offline Find More Posts by hubibubi
Old Aug 14, 2011, 02:37 AM
Joined Jul 2011
Attachment 4209811Attachment 4209813Attachment 4209812
hubibubi
Hi hubibubi,
both are looking great!
I have some questions on the 10in spider:
1.) what type of landing gear do you use (comes from which heli)?
2.) did you cut one of Pauls frame plates to form the upper deck or did you rebuild one from scratch?
aBUGSworstnightmare
aBUGSnightmare is offline Find More Posts by aBUGSnightmare
Old Aug 14, 2011, 02:55 AM
Joined Jul 2011
Originally Posted by M4d_D View Post
lol
Hi M4d_D,
why do you need 3 "normal" props for your Tri?
You need 2 CCW (9 and 10) and 1 CW (11) --> you have one CW for spare (--> always try to crash your front left prop since you have one for spare).
aBUGSworstnightmare
Old Aug 14, 2011, 03:02 AM
AutoQuad Team
kinderkram's Avatar
Germany, NRW, Dusseldorf
Joined Jun 2010
hubibubi
Very nice and clean build!
Are these the black arms (available soon) in Paul's shop?
kinderkram is offline Find More Posts by kinderkram
Old Aug 14, 2011, 04:00 AM
Deutschland
Joined Jul 2011
flow23, yes rosewhites guide is very good, the I2C direct connection is a new way, i also didnt do it myself and dont know if further mods are needed, i think yes a bridge to change the i2c adress or something.
Okay, I got it working now. When do you release a guide concerning the leds on your flyduspider board and what they are for? I'm very interested in that.
flow23 is offline Find More Posts by flow23
Old Aug 14, 2011, 04:23 AM
pbw
arachnida
pbw's Avatar
Belgium
Joined Aug 2008
Always wondered why you guys call it FlyduSpider, it's not an octo after all?!? FlyduBee or FlyduWasp is more like it!
arachnida
pbw is offline Find More Posts by pbw
Old Aug 14, 2011, 06:34 AM
Winterswijk, Netherlands
Joined Jun 2007
cam stab
Hi guys !
Does anyone have the cam stabilization working from pin 44/45 on the Flyduino 2.0 board.
I'm running MultiWii 1.8.
The code seems to output already on pin 34 + 44 for tilt, and 35 + 45 for roll by default.
Code:
#define DIGITAL_TILT_PITCH_PINMODE pinMode(34,OUTPUT); pinMode(44,OUTPUT); // 34 + 44
  #define DIGITAL_TILT_PITCH_HIGH    PORTC |= 1<<3;PORTL |= 1<<5;
  #define DIGITAL_TILT_PITCH_LOW     PORTC &= ~(1<<3);PORTL |= 1<<5;
  #define DIGITAL_TILT_ROLL_PINMODE  pinMode(35,OUTPUT); pinMode(45,OUTPUT); // 35 + 45
  #define DIGITAL_TILT_ROLL_HIGH     PORTC |= 1<<2;PORTL |= 1<<4;
  #define DIGITAL_TILT_ROLL_LOW      PORTC &= ~(1<<2);PORTL |= 1<<4;
I've connected the +5V from ESC at channel 3 (ESC @ ch 2 is powering the board), but I cannot get the servo's to respond. Power is available at 44-46, but no PPM signal present as it seems.
I've also uncommented #define SERVO_TILT, and marked camstab in the GUI.... Nothing
Also tried the modified 1.7 version from a couple of pages back, also nothing.
A 'lost model beeper' goes crazy when connected to either 44/45/46, so it seems no PPM signal is being sent.
BTW: Receiver / sensors are connected, and working properly
Am I missing something ?
wilco1967 is offline Find More Posts by wilco1967
Old Aug 14, 2011, 06:39 AM
Alexinparis's Avatar
Paris, France
Joined Jun 2009
Originally Posted by wilco1967 View Post
Hi guys !
Code:
Hi,
There is a bug in the code here, causing no signal on the indicated PINs
replace this part instead, and it should work.
Code:
#if defined(MEGA)
  #define LEDPIN_PINMODE             pinMode (13, OUTPUT);pinMode (30, OUTPUT);
  #define LEDPIN_SWITCH              PINB  |= (1<<7); PINC  |= (1<<7);
  #define LEDPIN_ON                  PORTB |= (1<<7); PORTC |= (1<<7);
  #define LEDPIN_OFF                 PORTB &= ~(1<<7);PORTC &= ~(1<<7);
  #define BUZZERPIN_PINMODE          pinMode (32, OUTPUT);
  #define BUZZERPIN_ON               PORTC |= 1<<5;
  #define BUZZERPIN_OFF              PORTC &= ~(1<<5);
  #define POWERPIN_PINMODE           pinMode (37, OUTPUT);
  #define POWERPIN_ON                PORTC |= 1<<0;
  #define POWERPIN_OFF               PORTC &= ~(1<<0);
  #define I2C_PULLUPS_ENABLE         PORTD |= 1<<0; PORTD |= 1<<1;       // PIN 20&21 (SDA&SCL)
  #define I2C_PULLUPS_DISABLE        PORTD &= ~(1<<0); PORTD &= ~(1<<1);
  #define PINMODE_LCD                pinMode(0, OUTPUT);
  #define LCDPIN_OFF                 PORTE &= ~1;      //switch OFF digital PIN 0
  #define LCDPIN_ON                  PORTE |= 1;       //switch OFF digital PIN 0
  #define STABLEPIN_PINMODE          pinMode (31, OUTPUT);
  #define STABLEPIN_ON               PORTC |= 1<<6;
  #define STABLEPIN_OFF              PORTC &= ~(1<<6);
  #define DIGITAL_SERVO_TRI_PINMODE  pinMode(2,OUTPUT); //PIN 2 //also right servo for BI COPTER
  #define DIGITAL_SERVO_TRI_HIGH     PORTE |= 1<<4;
  #define DIGITAL_SERVO_TRI_LOW      PORTE &= ~(1<<4);
  #define DIGITAL_TILT_PITCH_PINMODE pinMode(34,OUTPUT);pinMode(44,OUTPUT); // 34 + 44
  #define DIGITAL_TILT_PITCH_LOW     PORTC &= ~(1<<3);PORTL &= ~(1<<5);
  #define DIGITAL_TILT_ROLL_PINMODE  pinMode(35,OUTPUT);pinMode(45,OUTPUT); // 35 + 45
  #define DIGITAL_TILT_ROLL_LOW      PORTC &= ~(1<<2);PORTL &= ~(1<<4);
  #define DIGITAL_BI_LEFT_PINMODE    pinMode(6,OUTPUT);
  #define DIGITAL_BI_LEFT_HIGH       PORTH |= 1<<3;
  #define DIGITAL_BI_LEFT_LOW        PORTH &= ~(1<<3);
  #define PPM_PIN_INTERRUPT          attachInterrupt(4, rxInt, RISING);  //PIN 19, also used for Spektrum satellite option
  #define MOTOR_ORDER                3,5,6,2,7,8,9,10   //for a quad+: rear,right,left,front   //+ for y6: 7:under right  8:under left
  #define DIGITAL_CAM_PINMODE        pinMode(33,OUTPUT); // 33
  #define DIGITAL_CAM_HIGH           PORTC |= 1<<4;
  #define DIGITAL_CAM_LOW            PORTC &= ~(1<<4);
  //RX PIN assignment inside the port //for PORTK
  #define THROTTLEPIN                0  //PIN 62 =  PIN A8
  #define ROLLPIN                    1  //PIN 63 =  PIN A9
  #define PITCHPIN                   2  //PIN 64 =  PIN A10
  #define YAWPIN                     3  //PIN 65 =  PIN A11
  #define AUX1PIN                    4  //PIN 66 =  PIN A12
  #define AUX2PIN                    5  //PIN 67 =  PIN A13
  #define CAM1PIN                    6  //PIN 68 =  PIN A14
  #define CAM2PIN                    7  //PIN 69 =  PIN A15
  #define ISR_UART                   ISR(USART0_UDRE_vect)
  #define V_BATPIN                   A0    // Analog PIN 3
  #define PSENSORPIN                 A2    // Analog PIN 2
#endif
Alexinparis is offline Find More Posts by Alexinparis
Old Aug 14, 2011, 06:42 AM
hubibubi's Avatar
Deutschland, SA
Joined May 2011
Originally Posted by aBUGSnightmare View Post
Hi hubibubi,
aBUGSworstnightmare
Hi aBUGSworstnightmare
The frames are from the landing Gear TRex 700 and yes I have cut out a center plate, the rear part.
I had yet to see the pipes in there but not so good, I have also asked the landing skids as if the spider was on a jump.
Hi kinderkram,
No, I 11,5x11,5x1,5mm alloy 4knt have degreased, primed and painted with black, then painted over with paint rally. That's what I always do.
hubibubi
Old Aug 14, 2011, 07:15 AM
M4d_D's Avatar
Joined Dec 2006
Hi M4d_D,
aBUGSworstnightmare
sure i can use cw and ccw props but i can also use only one type and since i also ordered normal sf props ( eg at giantcod ) in sizes which should work good with the motors but which i cannot get as pusher , i need 3 normal props...
and i find that the tilted rear motor looks cool in the air ^^
Old Aug 14, 2011, 07:36 AM
Joined Jun 2007
Hi Alexinparis,
Great !... Works now
Thanks a lot
BTW, do you plan on enabling pin 46 for cam trigger ? (now only 33).
Not that I need it, but as it is availble on Flyduino, why not
Thanks again !
Originally Posted by Alexinparis View Post
Hi,
Code:
#if defined(MEGA)
#endif
New Product Please let me introduce myself jimaquo Dock Talk 7 Oct 27, 2010 02:27 AM
Let me introduce the DEMON!!!! (Transparent covering and eliptical wing!!!) modest-master Sport Planes 7 Aug 25, 2002 11:46 PM
Let me introduce Angelis 280/400, Benjamin, Zombi (ARFs) modest-master Parkflyers 17 Mar 14, 2002 01:20 PM
Let me introduce the "NIKE" modest-master Electric Sailplanes 3 Mar 07, 2002 05:20 AM
