Flyduino Mega , a Multiwii/Ardupirates/Aeroquad based aerial video platform FC
The Flyduino,
is avaiable at www.flyduino.com http://multiwii.googlecode.com/svn/t...20Flyduino.png ![]() Most actual shematic for the Flyduino! Thanks Berkely Pinout for Multiwii showen here (many thanks Alex): https://spreadsheets0.google.com/pub...EE&output=html Based on the fantastic work of Alex and Oleg. Alex famous www.multiwii.com Oleg aka Syberian also did a fantastic job in improving the Ardupirates code and supporting the Flyduino. ![]() With a Arduino Pro, you can only drive a quad and a regular receiver. For the use of a Hexa or some Cam stabilisation you have to use a ppm reciever to free some ins. With the Flyduino this problems are solved, you can fly all configurations avaiable and dont have to worry about too few ins and outs. This also true if one day the Multiwii Soft will support a octo config, which will be only possible with a Mega board and you then can still use your regular RX and handle some servos on it. ![]() Org WMP and BMA020 on 100hz ![]() FFIMU on 400HZ ![]() ![]() ![]() ![]() Oleg made a quick drawing for the Megapirate http://static.rcgroups.net/forums/at...g?d=1306981431 Thanks to Hogster a shematic for the Flyduino 1.1 ![]() this shows the serial change for Flyduino V 2.0 ![]() ![]() ![]() ![]() ![]() A redesigned Arduino Mega, which suits more our needs. It is only 5x5cm with the MK standard holes. You dont need a Breakout anymore for the cpu Board, cause you can stick everything directly, like ESC, RC,GPS (JPS connectors missing right now, have to order). -I brought out all PWM which are avaiable for Octos, Servos, whatever. -All serials (2 have pinheaders, one have a JST Connector) are brought out for GPS, LCD, wireless Data. -Analog In 8-15 are for remote controller with a 3 row pinheader. -D30-D33 are digital out for whatever you need it. This picture is taken without connected Sensors. its proved see the kinderkram post
The Pinheaders should be soldered by the customer, but the pinheaders ARE delivered with the Flyduino. It a relatively easy solder job. To make it clear you will get a Flyduino KIT with pinheaders but you have to solder yourself those supplied pinheaders. You will need a FTDI for using it with the Arduino IDE. I use a FTDI Basic myself, i think its the best, cause he will reset automatically. Thanks to Jussi, there is a very good size comparsion http://static.rcgroups.net/forums/at...g?d=1298106491 Berkelys very good diagramms are very helpfull when connecting the flyduino http://www.rcgroups.com/forums/showthread.php?t=1340771 http://multiwii.googlecode.com/svn/t...hox%20edit.png The Flyduino is prelimary ATM!! Ther diagramm shows the changes in soft warthox did for a ppm receiver A great video from Norf
Another Video which deserves the first page, thanks Warthox.
Also a great Demo, thanks Jussi.
To complete the Flyduino i did a Power distribution board and a Sensor BOB for it. The Sensor BOB have a LLC onboard. ![]() Top of the BOB for the FFIMU from Jussi ![]() Bottom of the BOB for WMP+ and BMA020 ![]() And new, the GPSBOB for the FMP04 GPS Module , PirateGPS. All adapted for our needs. ![]() Shop page is www.flyduino.com This is a cheap BMA020 and WMP+ mounted. ![]() This is a tower showen as example. ![]() Here you can see a Jumper if you want to use the 5V from the ESC. ![]() ![]() ![]() This the link to a modified Multiwii 1.7, which have the Cam Gimbal on Pin 44-46, the momentary dev. version allready have this feature. http://www.file-upload.net/download-...dMEGA.zip.html (outdated, new version of Alex contains the pinout) Divide et Impera manual here http://www.file-upload.net/download-...PERA2.pdf.html Great Video Tutorial for the MWC and WMP+ http://www.youtube.com/watch?feature...&v=IRfEnhzPkJ8 http://www.youtube.com/watch?feature...&v=BwL076avrH0 USB UART on Bottom of the Flyduino Mega
Thumbs up! Looking good in real life....!
Jussi |
Latest blog entry: AutoQuad hexacopter with Alexmos...
I asked for a 2560 before i planned this, but at the moment we can not use the aditional memory we are stuck at 128kb.
So the 2560 wont bring anything to us and in the end its no problem, cause he is pin compatible, so i only have to press a buy button. ![]() But why, it is the same chip exept the memory which we cant use and it really not that problematic to lay a2560 on board before reflow soldering, dont ya?. Sorry overead you mean the ATXMega, it a good chip, but a bit too far away from the established route, Alex can not write his code for every chip. That explains it a bit, sorry its german Quote:
Hmm ican programm him over the ICSP Header no problem, but have to read about the fuse settings, maybe thats the problem why my FTDI dont work.
Are here any Arduino specialist? I did a lot circuits before, also dealt with some MPU´s and their circuits but the arduino world is new to me so may someone can help out a bit? |
For Femtoduino, I used ArduinoISP to burn the bootloader and then I simply connected it to a Duemilanove without the uC to upload the programs. The video linked above show it at the end.
Note that you have to connect also the reset/dst of the FTDI. |
ne nix schlamassel, wie bist du denn druf
![]() No no real problem, i have just figure out some things, maybe more a driver problem on my side (microsoft factor). I also have problems with my nano and my mega clone which have usb, so give me a few hours. My problem a.t, is i am a bit over , didnt slept much last night.So i dont know how much my brain will realize anymore. The final solution will be a light and small cable going outside the copter to the ftdi, i am thinking of plain old Futaba/Graupner Servo connectors. dont like mini USB, cause its hard to reach when its mounted on a pcb inside a copter, but may it works good with your great (really) frame Norbert, dont know? I really had too much broken mini-usb plugs in my life, a real good thing will be something like a mini xlr. One original Arduino Nano arrived straight with a broken mini-USB, no joke, was no fun to solder some wires there instead, believe me. Hi Fab I tried a ArduinoISP but this not worked for me, pls have in mind i have to learn here, thats why i asked. The Arduino World is good documentated, but lots to read and many possible aproaches. First thing i have to decide for a programming systen Arduino, AVR Studio, or this third i forgot. I can take a nano a mega or a AVRISP MKII clone, many many choices. I would be niche if someone can look on the pinout posted above, thanks. |
my windows on my laptop seems to be ****** up.
I resinstall and will figure out the rest tomorrow it seems to be only my stupdness and little bit windows xp, thats all. I am not able to burn with the ArduinoIDE and my AVRISP MKII, failure. allready deinstalled the AVRSTUDIO and Jango driver, but still no sucess. I mena this is no problem with especially my board i also have a nano and a mega here which is the same. After the reinstall i may try AVRdude, ca tomorrow, really tired now. |
You can always try to program the device directly using ISP, bypassing the bootloader.
To do this you only need to change the upload.using=bootloader option in the arduino preference.txt file and put the name of the programmer you are using. In this way just connect the ISP cable and do upload from the arduino ide. i used this for some tests on a 644 board i'm working on and it works very well. At least in osx the file is located in <home>/library/Arduino/preferences.txt in the arduino program folder there is a "programmer.txt" file that lists all the isp programmer configured with arduino. |
Back again.
Thanks toshirotamigi, will try to edit that. I am able to burn with AVR Studio, but didnt figured the right fuse settings out, so i went back to ArduinoIDE cause he will do fuse settings automatically but it has problems with the jungo driver. I now have a fresh reinstall on my testing laptop, i will avoid using AVRStudio and will try your hint first. |
| Thread Tools | |
| New Product Please let me introduce myself | jimaquo | Dock Talk | 7 | Oct 27, 2010 02:27 AM |
| Let me introduce the DEMON!!!! (Transparent covering and eliptical wing!!!) | modest-master | Sport Planes | 7 | Aug 25, 2002 11:46 PM |
| Let me introduce Angelis 280/400, Benjamin, Zombi (ARFs) | modest-master | Parkflyers | 17 | Mar 14, 2002 01:20 PM |
| Let me introduce the "NIKE" | modest-master | Electric Sailplanes | 3 | Mar 07, 2002 05:20 AM |
