Old Jan 31, 2011, 11:21 AM
Gyroguru is offline
Find More Posts by Gyroguru
Joined May 2005
Jr xp-7202 works fine as salve (student) but not as a master (teacher). Please help !
I am trying to set up my JR XP-7202 radio as the Master/Teacher and the JR XF-631 as the Slave/Student buddy box. When I hold down the trainer rocker button, nothing happens. The trainer button does changes the trim on the flaps. I tried to change the trainer to the right side and still not able to make it work. I also tried in Normal and P-Link mode.
However, when I set my XP-7202 as a Salve/P-Link (student), I am able to control the model with XF-631 as a primary (teacher) by pressing and holding down the trainer button. Everything works fine.
I would appreciate any suggestions.
Gyroguru is offline Find More Posts by Gyroguru
Old Jan 31, 2011, 05:35 PM
Gyroguru is offline
Joined May 2005
XP7202 Manual
http://www.horizonhobby.com/ProdInfo...o_Manualv2.pdf
XF631 Manual
http://www.jrradios.com/ProdInfo/Fil...219-manual.pdf
Old Jan 31, 2011, 10:59 PM
Ken Barnes is offline
Find More Posts by Ken Barnes
S.F. Bay Area, California, USA
Joined May 2005
Gyro,
You want to teach someone to fly. You have a XP-7202 transmitter.
If the person you want to teach, has an airplane/helicopter, and a XF-631 transmitter. In this case the 631 is the master transmitter, and your transmitter is the slave. If you want to use your transmitter as the master, you must program the students model into one of your transmitters model memories . The master transmitter is always the transmitter that normally would fly the model.
One more thing the 631 is an FM (PPM) only transmitter, the 7202 can operate as either a FM (PPM), or a PCM transmitter. The trainer function requires that the slave transmitter be set to FM (PPM). The master transmitter can be either FM (PPM), or PCM depending on the receiver in the model. If you want to use your 7202 as the master, with a model that is flown with a 631 you need to use an empty model memory on your transmitter, program that memory for the model, and set it to send a FM (PPM) signal. Pages 35, and 36, of the 7202 manual explain how to change the transmitters modulation to either FM (PPM), or PCM.
Ken Barnes is offline Find More Posts by Ken Barnes
Old Feb 01, 2011, 02:21 PM
Gyroguru is offline
Joined May 2005
The XP7202 is for me and the XF631 is for my son. Both of these radios were converted to Corona 2.4.
The XF631 is straight forward. The PPM signal was cut from the FM board and wired to the Corona 2.4 board.
The XP7202 was almost straight forward. On XP7202, the PPM signal is sent to the synthesizer board and there appears to be some feedback to the mail board. This connector which was removed per instruction from JETI which might cause an issue. This is the step 5 picture.
I am not using the JETI module but did use the MX16 instructions. See the pictures.
Thanks.
Old Feb 01, 2011, 04:52 PM
Gyroguru is offline
Joined May 2005
This is the cable which is disconnected after the 2.4Ghz module was installed which might have affected the trainer function.
Old Feb 01, 2011, 08:34 PM
Joined May 2005
I didn't know your transmitters were modified. I have no idea if modifying the transmitters with add on 2.4 boards, would affect the trainer function.
Could I ask where you got the wiring schematic for the transmitter? I might want to get the schematics for the JR transmitters I own.
Ken
Old Feb 02, 2011, 08:20 AM
Gyroguru is offline
Joined May 2005
For schematic, go to FCC's website:
https://fjallfoss.fcc.gov/oetcf/eas/...ericSearch.cfm
Under Grantee Code:, enter first 3 letters of FCC ID.
Under Product Code:, enter rest of the letters of FCC ID.
You should find just about everything you need to know.
Old Feb 02, 2011, 06:15 PM
Joined May 2005
Thank you Gyroguru,
I hope someone is able to help you solve your issue with the trainer function.
Discussion why it works on 40mghz but not 2.4 urs Radios 4 Jan 25, 2011 12:03 PM
Help! GSP-Altitude logged fine, but not displayed on OSD Pro, spurious rpm jumps reely340 Eagle Tree Systems 11 Jan 13, 2011 02:21 AM
Discussion Hamilton ... not as good as Madison ... but still cool logan5 Life, The Universe, and Politics 0 Nov 30, 2010 11:45 AM
Sold JR XP-7202 Transmitter 60+Retiree Aircraft - General - Radio Equipment (FS/W) 4 Nov 29, 2010 02:50 PM
Teacher / student (FX-18 / Pico Line) help Vombat Radios 3 May 08, 2005 09:09 AM
