I was lucky.... Mine failed after landing. Mine is still in mint condition, not a ding or scratch. My elevator servo just locked in the fully up position after landing. More than once but only once after a flight. I don't know if it has something to do with low voltage as I did notice a correlation to well used batteries but it was strange that it was only my elevator servo. J
It seems some of the servos had faulty potentiometers.
It's hard to maintain confidence when there appears to be no clue as to why they fail. As I said my only correlation was I observed the faults at or near LVC levels although nothing improved when I switched my ESC to a castle. I suppose there are many hundreds sold and flying well and it is just those that experience faults that seek forums like this. If mine did not have the issue observable on the ground between flights, I probably would have assumed RX or pilot issues and not gone looking for this thread. J |
Joined Mar 2011
So I'm not alone.
I had a servo failure today on the Carbon Z. I was lucky as it happened when I plugged up the battery and turned on the switch. The right aileron when full down on its own, five seconds passed, then it went full up on its own, and stuck right there. In flight, this would have been a $300 failure as it has been for many. I'll report this to Horizon but I'm also replacing the servo while that argument goes on. I've actually had good experiences with HH. We'll see. I'll never be comfortable flying this plane again, regardless. Only two flights...
airport west
Joined Aug 2010
hi l have had the same fault on my ailron servo to and crashed the carbon z and l emailed horizon but they told me to ring O'Reilly Model Products-Distributor but they were no help at all so l emailed horizon and they told me to
(The only other option would be to send the plane to us for replacement I am sorry that they will not help you out. If you would like to send it here for a evaluation you are more than welcome to but could cost as much as the plane its self.) l would not trust another carbon z again |
Australia
Joined Dec 2007
WOW glade I came across this thread. (no crash for me yet)
I have one from Model Flight in Adelaide. Mine has only had x1 5min test flight. The test pilot was very very gentle with it and touched down like a feather. Now do I risk flying it without changing over the servo's ? This is my first plane after a 10 year break. (never used digital servo's before) I actually rang the store when I put it together because the elevator servo was making so much noise... cherping morse code.. They told me it was normal. I now know they all do it a bit. But the elevator one is so loud that when setting up the throw's and dual rates. Because of the anoying noise; I just wanted to put the plane in the oven and kill it ! |
Scottsdale Arizona
Joined Dec 2009
Joined Mar 2011
Set up questions
As a recent purchaser of this Carbon-Z Yak-54, I found these threads extremely interesting. The question I have to the gents who had elevator- or aileron-servo failure is in two-parts:
1st The manual has specific set ups as to where the pushrods are attached to the control horns and for measuring the control throws. Were these followed? I'm sure they were, but I'm just wondering. 2nd The manual also says that if you are flying the Yak at high speeds, then the low rates should be used. Were these servo failures the result of ripping around and then suddenly pulling hard on the elevator stick or rolling when the controls were on high rate? Again, just wondering. I look forward to your replies. |
Good questions and I will re-check my throws when I get back to OZ. I have to say that mine did not fail in flight but - lucky for me after landing.
I purchased my model PNP so it was pre-built with rods etc. I checked all throws and set the TX as recommended before flight. I have been flying mine aerobatic as opposed to 3d so I have never put mine on full high rates yet. The only correlation I have found with regard my servo malfunction is that I landed and checked my battery levels. Out of a 3000mah 4s pack I had according to my PL-8 charger only 4% fuel left. Elevator servo went full up before removing the pack. In hindsight I was foolish and flew again with new packs and had no problems as I was convinced that after checking everything it may have been a poor servo connection fixed during the pre-flight check over. Still no crash. Later when checking the model at home, and checking prop balance, I plugged in a well drained pack.... 8% fuel remaining..... elevator servo malfunctioned full up. I replaced it. I still have the offending servo, the model is near immaculate, no dings at all. Normally I would just throw an untrusted component but kept this in case the manufacturer wishes to examine. I'm not loooking for replacement or compensation. I just want to make sure I do not damage person or property with my models, so I am happy to help where I can. J |
| Thread Tools | |
| Discussion NEW!!!! E-Flite Carbon-Z Yak 54 BNF/PNP!!! | DFflyer | 3D Foamies | 3561 | Yesterday 12:56 PM |
| Cool New E-flite Carbon-Z Yak 54 | miksta115 | Electric Plane Talk | 39 | Oct 11, 2011 10:05 AM |
| New Product E-Flite Carbon-Z Yak 54 (48'' Wingspan 940 Watts!) | Get Real | 3D Foamies | 1066 | Feb 22, 2011 10:21 PM |
| Discussion E-flite Carbon-Z Yak 54 | shoeler | Sport Planes | 3 | Dec 19, 2010 08:39 AM |
