Old Jan 30, 2011, 11:33 AM
rcpilot_971 is offline
Find More Posts by rcpilot_971
United States, CA, Rocklin
Joined Sep 2003
Question
Charging 6 4s 3300 in parallel with the Icharger 206b
hello
im verry new to all this electric chargers and power supplys and I have been reading through the threads on the Icharger 206b and the powerlab8 learned a lot in the past few days but cant figer out what charger would work best for what I want it to do I have narowed it down to two chargers so hear is what I want to do
I have 6 nano techs 4s 3300 I want to charge all of them in parallel at 2c or maybe 3c my qustion is will the I charger 206b and the 350 PS handle this and about how long will it take to charge all 6 batteries
or would I be better off with a powerlab8 and two power supplys at 24v and 94amps
Thanks Tim
rcpilot_971 is offline Find More Posts by rcpilot_971
Old Jan 30, 2011, 12:07 PM
tjinguy is offline
Find More Posts by tjinguy
TJin(Guy + Tech)
tjinguy's Avatar
United States, NM, Socorro
Joined Jun 2008
Originally Posted by rcpilot_971 View Post
hello
Thanks Tim
Sounds like you have read many pieces of info and are having trouble putting it together. To answer your first question, some math is required.
6(4s * 2C) = max wattage needed
6(16.8V * 2(3.3)) = 665W
6(16.8V * 3(3.3)) = 1000W
That is now many watts you would need but you also have to take the maximum number of amps required into account.
6*2(3.3) = 40A
6*3(3.3) = 60A
So you can see that there is no charger made today that will charge 6x 3300 4s packs at 3C but there is one that will do them at 2C, the PL8. Actually there is another but it would require you to split the packs up into 2 sets of 3.
As for your second, that is a function of 2C and 3C charge rates, estimated to be 35min and 25min respectively.
tjinguy is offline Find More Posts by tjinguy
Old Jan 30, 2011, 01:00 PM
Joined Sep 2003
6*2(3.3) = 40A
6*3(3.3) = 60A
man this stuff is confusing
so how maney 4s 3300 could I charge @ 3c with Icharger and power supply and how maney with the powerlab8 and will the lowerlab do it faster than the I charger 206
Thanks Tim
Old Jan 30, 2011, 01:07 PM
dirtyballs is offline
Find More Posts by dirtyballs
Bart
Netherlands
Joined Oct 2010
2 is the max then at 3C for the 206B.
But make a blok of 2 by 3, 8S3P and the PL8 will do 4C
It's al in the numbers.
DB,
dirtyballs is offline Find More Posts by dirtyballs
Old Jan 30, 2011, 02:40 PM
tjinguy is offline
TJin(Guy + Tech)
tjinguy's Avatar
Joined Jun 2008
That is not helpful. Please don't introduce things such as this when the OP is trying to learn the basics.
The 206B is rated at 300W or 20A max. So lets figure out what the max charge rate it for 4S on a 300W charger.
300W / 16.8V = 17.8A
That is lower than the max 20A limit, so you can use the whole wattage output. Now divide by 3.3A to find out what C you can charge at
17.8A / 3.3A = 5.4C
That means you can charge a single pack at 5.4C or divide it up by parallel charging. So to answer your question though, you can almost charge 2 4s 3300 packs at 3C (actually 2.7C each) on a 206B.
Old Jan 30, 2011, 04:39 PM
Joined Sep 2003
Time wise would that be 20min at 3c and 30min at 2c
Old Jan 30, 2011, 04:42 PM
tjinguy is offline
TJin(Guy + Tech)
tjinguy's Avatar
Joined Jun 2008
It is more like 25min and 35min for 80% discharged packs, though it varies depending on how far you discharge the packs and is influenced buy both the charger and settings.
Old Jan 30, 2011, 09:27 PM
Joined Sep 2003
ok thanks
I think im going to order the icharger and 350 power supply
Thanks Tim
Old Jan 31, 2011, 09:17 AM
Ben-Rod is offline
Find More Posts by Ben-Rod
HOW HIGH DOES IT GO???
Ben-Rod's Avatar
Jacksonville, Florida
Joined Nov 2004
ok thanks
Thanks Tim
Get it from David at progressive rc and you wont regret it...happy charging/flying.
Ben
Ben-Rod is offline Find More Posts by Ben-Rod
Old Jan 31, 2011, 09:37 AM
Joined Sep 2003
Ben
Yeh that is where I was plannig on buying it from
thanks
Old Jan 31, 2011, 10:10 AM
_Sergey_ is offline
Find More Posts by _Sergey_
Ugly planes do not fly
_Sergey_'s Avatar
United States, MA, Boston
Joined Mar 2007
One thing is you can have 1000W capable charger but if power supply can only provide 12V the max amps will be limited to 14A or so on 4S. Am I right?
_Sergey_ is offline Find More Posts by _Sergey_
Old Jan 31, 2011, 11:37 AM
tjinguy is offline
TJin(Guy + Tech)
tjinguy's Avatar
Joined Jun 2008
That is dependent on the charger and power supply. The big iChargers can output 500W off 12V, so that would give you a full 30A on 4s but it would require a 12V 50A power supply. The PL8 will do almost 600W on 12V but would require 60A of 12V input.
Old Jan 31, 2011, 08:22 PM
Joined Sep 2003
so with the Icharger and the 350 watt power supply would I be able to get 20 amps
what I would like to be able to do is charge 2 4s 3300 in parallel @ 3c would this = 19 amps out of the Icharger 206b ? or would I be better off with a powerlab8 and a 24v 94amp power supply
Thanks Tim
Old Jan 31, 2011, 08:43 PM
lipoflyer is offline
Find More Posts by lipoflyer
lipoflyer's Avatar
Australia
Joined Nov 2010
the amps that these chargers are putting out these days are scary, in a good way!
lipoflyer is offline Find More Posts by lipoflyer
Old Jan 31, 2011, 09:03 PM
_Sergey_ is offline
_Sergey_'s Avatar
Joined Mar 2007
Thanks Tim
I own iCharger 206b. The max amps I can get out of 12V supply (deep cycle battery or PC power supply) charging 4S is 14-15A. You can get up to 20A if power supply can provide more than 12V.
Discussion ICharger 208B and 6S JST-XH Balance Cable for Parallel Charging norstaroption Batteries and Chargers 8 Oct 23, 2011 05:47 PM
Discussion Which cells in 6 x 6S Parallel Charging UnixMover FMA Direct 17 Feb 01, 2011 07:19 PM
Discussion got my new fma 4s gold charger, have some charging in parallel questions... get dustd Batteries and Chargers 6 Jan 19, 2011 08:59 AM
Discussion Can I use this adapter for parallel charging in 206B? avt Batteries and Chargers 5 Oct 29, 2010 03:14 PM
Discussion Serial charging with iCharger 206B W.alter Batteries and Chargers 8 Jun 02, 2010 04:45 AM
