Old Jan 30, 2011, 03:42 AM
PLD is offline
PLD
Find More Posts by PLD
PLD
Magicsmoke maker
PLD's Avatar
Australia, QLD, Charters Towers
Joined Dec 2003
Build Log
Altimeter switch / LED-Alert for being 'too high'
With R/C activities coming under a lot more scrutiny these days, we have to do our best to keep within the rules that are laid out to us for the fields we have.
One of the most commonly violated rules seem to be the height/altitude ceiling (300~400' AGL).
After being approached a few times by various people and finally last month, I decided to see what I could do any put together an independent altitude alert system.
The operation is very simple - there's a single button the board which you press X times for X00' altitude (eg, 4 times for 400'). I might change this to 50' increments but for now it'll be 100'. The altitude is saved until you change it again, a single LED on the board will blink out the number to you as a reminder. The board will automatically reset the ground-level to what ever height the plane is set at at the time of being turned on.
The precision of the unit will be about 10~20', so if you set it to 400' AGL you'll have the alarm trigger at 400' +/-20'. I could have built it with a lot more precision but considering that with normal flying we rarely can hold more than 10' altitude precision for long.
On the BACK of the board will rest a nice bright 1W LED, I've not yet worked out what colour to use for optimal visibility but I'm starting with Amber with ~35 lumens output (I can get green at 65 lumens but it's a lot more expensive). Now, as we all have different wants/needs I'll ALSO be producing a version of the board without the LED but with a 2 pin header to let you plug in your own choice of LED/alarm (up to 1A current).
The board is only 1x1", it'll have 4 mounting holes. The LED on the back (for the ones built with that) is only about 8mm diameter and has a beam about 120~140 degrees wide.
The whole system can be powered by a 2S lipo or LiFe or a 5~6 cell Ni pack. I strongly recommend not putting this on your receiver power bus because of the load it'll induce when firing the LED off for the alert.
The cost will be somewhere between $50 and $60 AUD, depends on the numbers I can get sold as the pressure sensor costs quite a lot of money and only when I get to units of 100 orders does it drop down to a sane level.
Paul.
PLD is offline Find More Posts by PLD
Old Jan 30, 2011, 03:53 AM
PLD is offline
PLD
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
I should point out that the LED will be 'strobed' to provide maximum visual impact.
Old Jan 30, 2011, 04:26 AM
BulletMaster is offline
Find More Posts by BulletMaster
Chillaxin dude!
BulletMaster's Avatar
Newcastle, NSW, Australia
Joined Apr 2003
interesting concept Paul... watching this one.
BulletMaster is offline Find More Posts by BulletMaster
Old Jan 30, 2011, 04:40 AM
bigiain is offline
Find More Posts by bigiain
Joined Jun 2006
I'd take one of them.
I'm happy to pre order / pre pay if you're sure enough of your ~$60 price point.
A suggestion, in case you're interested, I'd like this to be able to be plugged into my throttle channel and have the esc pluged into it so it can kill the motor above the pre-set altitude.
big
bigiain is offline Find More Posts by bigiain
Old Jan 30, 2011, 04:41 AM
PLD is offline
PLD
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
It's obviously more of a safety/compliance device than anything really "bling" worthy
The boards have already been put into production but with the Chinese new year I'm not sure as yet when they'll arrive here.
Testing is going to be interesting, I dare say quite a bit of driving up and down the local hills
Paul.
Old Jan 30, 2011, 04:46 AM
PLD is offline
PLD
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
Big,
Right now, to provide a throttle-inhibit facility I'd have to change the controller chip or lose the LED-beacon functionality. Actually, the more I think of it the more likely it'd be a separate, slightly more advanced product.
Paul.
Old Feb 04, 2011, 12:17 AM
PLD is offline
PLD
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
Hey there folks, just back in finally after being 'lost' for a week due to TWO cyclones hitting the coast during the week.
Anyhow, just had a thought, I could try add a remote-RF alarm option too to the altitude alert, so that you could have it in your pocket and it'll beep when you exceed the preset.
Paul.
Old Feb 05, 2011, 12:03 AM
PLD is offline
PLD
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
Haven't had word yet from the PCB factory, though I would expect them to have the boards ready to ship this week.
Old Feb 05, 2011, 02:38 AM
pheonix3 is online now
Find More Posts by pheonix3
Perth, Western Australia
Joined Jun 2009
G'day Paul, great idea mate. My thoughts would be the rf alarm in your pocket would be much more useful than trying to spot a led at height. Keep it up though :-) I'm forever wondering 'how high is my model?'
Cheers Matt
Paul.
pheonix3 is online now Find More Posts by pheonix3
Old Feb 05, 2011, 04:04 AM
PLD is offline
PLD
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
Phoenix,
I'll be offering a swathe of variants. The integrated LED unit will likely be the cheapest option, the RF version going for moderate amount more, such is the unfortunate nature of more features
The real proof of usefulness is going to be when I finally get my hands on these boards and get to build the first couple.
Paul.
Old Feb 06, 2011, 02:47 AM
mustangsforme is offline
Find More Posts by mustangsforme
Monash, S.Aust.
Joined Apr 2004
I will be watching developments here Paul....very handy.
Another electronic idea suggestion.....
A friend asked me today if I knew of a warning device that amounts to a stall warning!!! Both he and I (mature years) can let a model on final approach (Flying towards ourselves) get too slow, and cause a tip stall. Nasty. Thinking about it, all we need is a speed device on similar principles to the altimeter. IE, we pre-set a speed, and it sounds an alarm if the model drops below that speed. Something to think about anyway
Cheers,
Adrian
mustangsforme is offline Find More Posts by mustangsforme
Old Feb 08, 2011, 02:17 AM
Joined Jun 2009
Thanks for the update Paul. Good work on these inovative RC electronics :-)
Cheers,
Matt
Phoenix,
Paul.
Old Feb 08, 2011, 03:36 AM
PLD is offline
PLD
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
Still no sign of the PCBs yet - I dare say that I won't hear anything until about the 11~12th (as the factories probably don't come back online for a day or so after the end of the Chinese New Year).
Paul.
Old Feb 09, 2011, 03:30 PM
PLD is offline
PLD
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
Boards have been FedEx'd ... another 5 days they might be here.
Old Feb 13, 2011, 11:47 PM
PLD is offline
PLD
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
Boards have arrived.
I've hand-assembled one, so far the pressure sensor is showing up quite good - giving me 3.90V which translates to 97.22kPa which in turn translates to 390~400m altitude which is correct for this area (the airport is at 1300' ~ 396m).
Now, that was the easy bit... the hard bit is going to be ensuring that the analysis of the voltage (3.90V etc) is done correctly by the opamp and AVR combination.
Paul.
Question For Turnigy High Density R/C LED Flexible Strip owners RC toy Night Flying 20 Jun 30, 2011 02:18 PM
Help! Noob alert: Too good to be true? c131frdave Batteries and Chargers 11 Oct 13, 2010 07:58 AM
Sold How High Altimeter $33 shipped Conus glider90 Aircraft - General - Radio Equipment (FS/W) 1 Sep 01, 2010 04:16 PM
Discussion Symptoms of voltage being too high? Kmart FPV Talk 7 Feb 03, 2010 10:43 PM
Is there such a thing as motor being too powerful/prop being too big? simingx Power Systems 9 Jan 28, 2003 07:36 PM
