Old Jan 29, 2011, 12:25 PM
If in doubt, add accelerant
Lberry.88's Avatar
United Kingdom, England, Stansted Mountfitchet
Joined May 2007
Easysky Cessna 182
Easysky is another new company out to try and knock the big boys from their perch. As their website states, they specialise in research and development and their website seems to suggest that they have a number of excellent ideas in development; their spring loaded motor mount seems particularly innovative. They currently have a J3 Cub, a Brushless Sport Plane (another Eastystar type pusher) and a Cessna, for me it was only ever the Cessna 182. At 170g, the 6A brushless EPO plane that seems perfect for teaching beginners, with a spring mounted motor and lightweight design it seemed like a perfect fit.
The Box
The box arrived in its own sturdy shipping box, inside was the main box full of components separated into their own shipping bags to avoid damage.
Inside the box
Fuselage with servos, pushrods,6A esc and motor
Wing with servo and pushrods installed
Bent wire main gear and spring loaded nose gear
Decal sheet
Glue
Rear undercarriage
Prop (x2 - yes a spare!) and spinner
Horns, linkages and screws
Screwdriver and alan key
2S Lipo 500 mAh battery
Required
Receiver
Transmitter
Lipo Charger
Extra Lipos (you'll need them)
The fuselage and wings come with pre cut surfaces and 1x 8g aileron servo and 2 1.5g Elevator and rudder servos installed. The motor is a 1822/2600KV brushless outrunner turning a 5x5 prop.
The kit comes out of the box almost assembled - there is very little required of the user. Once the kit is laid out in front of you its is apparent that it will be a simple build. The manual comes on a CD - its a pdf that is only 12 pages long - of which 2 are assembly instructions, though if you have built anything before the manual is pretty academic!
All that is required of the user is to attach the control horns to the pre-recessed points, glue the horizontal stab and wings to the fuselage and add the receiver. These tasks were completed with ease - I used the supplied glue for the build, a rubber cement, but a 5 min or 90 second epoxy would work equally well, to attach the control horns and the H-stab. I squared up the tail with the wings. I had to put on the wings to make sure everything was square. Though the instructions do not mention it, I added a small amount of glue to the underside of the wing for added security, and a fillet of glue under the wings. I had to remove the cowl to adjust the nose wheel direction - but this was the only time that I was required to be 'free thinking'. It was simply a case of removing the four screws - allowing me to take a look at the motor mount (see below) - and adjusting the screwlock to centre the wheel.
Now would be a good time to point out quite a neat little design feature for this plane, the avionics bay is accessed by a 'door' complete with hinges on the side of the fuselage. Whilst this is a nice addition it does restrict the access to the RX and battery. This is further compounded with the nose gear pushrod expending right through the compartment AND the esc having to fit in there too. I eventually got the RX velcro'ed to the rear wall of the fuselage ( I later moved the RX further toward the nose for CG adjustment), and was able to progress to decal application! I have chosen to use a Hobbyking DSM2 receiver with the orange case taken off to save some weight, this allows me to bind it to my DX6i along with all my other micro/ultra micro planes.
The motor mount
Some of you may have seen on this thread one of the features of this plane is its spring loaded motor mount, a mount that is designed to flex on impact - hopefully removing some of the energy, thus not damaging the motor. It was this design that initially got me interested in the plane in the first place. In reality the mount does exactly what it says it does, its and ingenious piece of design that uses the spring tension to hold the motor until there is force applied against it. All in all the mouton seems light and small.
rere
Note on the decals and foam
The instruction manual provides only one view of the plane in its final state, I had to go to the Easysky website to find further images to complete the decals. Because of the semi-scale nature of the plane, the manufacturers have added the ribs to the TE of the wings and H-stab. When it comes to applying some of the decals I found it easier to slice the rib effect off with a knife than try to get plastic decals to stretch and bend over them. The foam itself was of high quality, there were no shipping defects and the finish of the EPO was smooth, no graining as you occasionally see on some really cheap planes.
Once the decals were applied and the glue had dried I was able to connect the horns to the rods and set up the throws. The manual gives no indication so I set up my DX6i to give low rates of 70% throw with 40% expo and high rates of 100% and +30%. These will be evaluated after the first few flights. Fortunately the CG position was stated in the manual and I found that I had to move the RX and batter as far forward as I could to ensure a good balance. I’m not sure if this is because I had removed the 4g of plastic case on the RX; but it is worth noting for future experience. I am using the ultra micro velcro stuff that comes with the Parkzone/Hobby zone planes to secure the battery. There doesn't appear to be any other option, i didn't fancy letting it stay loose in there!
That’s it - a simple PNP, now its off to the field!
__________________________________________________ __________________________________________
Due to my impatience I chose a very windy day to maiden her, but I am pleased to say she handled the wind well.
Take off
I opted to ROG for my first flight, I pointed her into the wind, increased the throttle and she smoothly lifted off after a 10 foot run. There was also a pleasing lack of torque roll. She climbed out with authority, executed a couple of banked turns and settled her down for a few passes. I had set my DX6i on low rates – 50% throw with +30% expo, but I found that the it didn’t have much authority in the turns, so flipped it to full throws with +30% expo.
General flight characteristics
She is very stable in the air – her stalls were slow and predictable and very easy to recover from. She also doesn’t seem to exhibit any tip-stalling tendencies She will happily fly around (even in strong wind) at half throttle, and will loop at 2/3.
Aerobatics
With ailerons she is able to roll, but with the control rods in the highest hole on the horns aerobatic performance was limited. The next flight I will increase to maximum throws and see how she does. She has loads of power, the little brushless motor and 5x5 prop gives her a fairly quick top speed, and she was able to loop 4 times without loosing too much altitude.
Landing
Landing was simple, point her into the wind and slowly reduce the throttle, a little flair at touchdown and cut the throttle. Very stable, very smooth and very easy! No hint of tip stall either.
Is this for beginners?
Yes! The Cessna is stable in the air with plenty of power if you get into trouble. Take off and landing is a doddle, and if you get into trouble she will right herself. Only problem is that EPO can sometimes be brittle, but the spring loaded motor mount should save you having to replace the motor after any heavy impacts.
I have been very pleased with this little plane, the quality of the components seems very good, and her flight characteristics are excellent.
Pros
Well-made airframe with quality decals
Nice door hatch design for the battery compartment
Straightforward build
Lots of power from the brushless motor
Very nice flight stability and general handling
Cons
Installation of the receiver is difficult
Lberry.88 is offline Find More Posts by Lberry.88
Old Feb 02, 2011, 03:56 PM
Lberry.88's Avatar
Joined May 2007
Update: After getting her down from a tree (see my blog) i have put a GWS 5030 x 3 prop on her. Weather looks bad for the next week or so but will try and fly her as soon as the weather clears!
Old May 06, 2011, 06:31 PM
Manila Ninoy Intl, Philippines
Joined Nov 2001
I got one of the RTF sets for testing.
I like it. The foam molding is very good and it has lots of neat features.
It is not a floater. It has quite a high wing loading which helps when it's windy, but also means it has to be flown fast.
I didn't actually use the radio that came with it. I used a DX6i and was able to use dual rates.
This is necessary.
The servos have the control rods mounted on the outer holes of the servo arms, giving too much throw, even when the easy connectors are mounted at the top of the control surface horns.
The elevator and rudder servos are not readily accessible, to allow the control rods to be moved down a couple of holes on the servo arms, so all adjustment has to be in the transmitter (and the stock RTF transmitter has no dual rates).
Unfortunately, most buyers of the RTF will be beginners, so these will be overcontrolled into lots of crashes, testing the motor mount to the max.
Most definitely not for beginners, but it is an excellent Mini sport scale plane, which has 4 channels, real servos, a brushless motor and a steerable nose gear.
deadduck is offline Find More Posts by deadduck
Old May 10, 2011, 10:59 AM
Jack Xie
tymodel's Avatar
China
Joined Nov 2009
Use a 3.7V battery will be better for beginners.
tymodel is offline Find More Posts by tymodel
Discussion Huge 73" Foam Cessna 182 (Tian Sheng EPO Cessna 182) I_Gotts_Ta_Fly Foamies (Kits) 1221 Jun 16, 2013 04:52 AM
New Product EasySky 4CH Micro Cessna B/L WingSpan 555mm tymodel Micro RTF 4 Dec 24, 2010 07:53 PM
Mini-Review EasySky - Get Your Gift For Free!! (Cessna, Super J3 Cub or "Dolphin" KIT Version) tymodel Micro RTF 0 Dec 22, 2010 03:41 AM
For Sale NIB Eflite Cessna 182 bushpilotx1 Aircraft - Electric - Airplanes (FS/W) 11 Oct 11, 2010 01:35 PM
Sold Flyzone Cessna 182 Select Scale **Price Reduced** hbsurfer Aircraft - Electric - Airplanes (FS/W) 4 Sep 09, 2010 09:05 PM
