| Thread Tools |
| This thread is privately moderated by TheTick, who may elect to delete unwanted replies. |
Spark #2
Almost ready for maiden.
AUW around 12lbs (used cheap fish scale) Stumax 110-45 Neu 1524/1.5y CC160hv Medium timing Gens Ace 30c 12s 5300 A123 rx pack. No regulator. No switches. Airpower electronic valves for retracts and brakes. CG 150mm Full throttle static results with 82mm exhaust diameter: 6375 watts peak. 6kw after 5sec. 5.8kw after 10sec. Gens Ace pack holds at 44.4v (3.7v/cell) at 131 amps. CC160hv with cooling fan peaks at 137F after six 10 second runs with 20 seconds breaks between each run at half throttle. Used 3000 mah. I used a large 5v cooling fan on the controller to avoid cutting vents in the plane. It seems to be doing a good job and only weighs .5 ounces. While running, I can feel the air exit out the tail of the plane. In the air, it should run even cooler. I'm shopping for a non LED fan as this one is obnoxiously bright. Speed was the focus of this build and I believe I chose the right fan for the task. Hoping to maiden in a week or so. I'll try to get video and radar. Ben Update: Video of speed runs
I cant wait to see that video! Thats a ton of power!
Latest blog entry: Getting into FPV while KISS
Very happy with the setup. Fly's great and lands easy. Thinking about going to 11s 5800 which weigh the same as my 12s 5300.
Dang that's moving! are you considering moving the timing up?
Hi Ben it was nice meeting you at Sepulveda ! Your Spark looks sharp, Herbert
Latest blog entry: BAe Hawk 90mm EDF
| Thread Tools | |
| Help! 2 Stroke no spark help? | FighterCat57 | Racing Boats - Internal Combustion | 10 | Nov 24, 2010 02:06 PM |
| Discussion Need Spark Arrestor | Reco | Batteries and Chargers | 7 | Oct 07, 2010 10:04 PM |
| Question CRRC 26R Spark Plugs | shuglu72 | Engines | 3 | Sep 18, 2010 08:54 AM |
| Discussion Shorted lipo, huge spark melted cutters | flying-things | Batteries and Chargers | 65 | Sep 17, 2010 07:10 PM |
| Video TJ100 power Spark 10s 2.7kw | Tamjets | Electric Plane Talk | 0 | Aug 08, 2008 04:02 AM |
